> 914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS
Curbandgutter
post Mar 25 2013, 01:12 PM
Well the dream begins. I'm embarking on the building of a 914 project. Here is the candidate. Bought a roller from LA area. Looks like its not going to be too much rust. Firsts thing will be to strip it. Taking front fenders and rear quarters off. Then sending to Cal Blast for media blasting. I look forward to the knowledge that I can gain from fellow enthusiasts. Plan on taking a lot of pics Stay tuned......
DISCLAIMER: Do not attempt to duplicate anything that is mentioned or illustrated in the entirety of this thread. I do not make any warranties of any kind. If you try to build what I am doing, you take full risk. Do not try this. It may be dangerous to your health and may get you killedAttached Image
jd74914
post Jun 21 2016, 11:40 PM
Its alive
Sweet! You don't see too many people doing FEA iterations on chassis. (IMG:style_emoticons/default/smilie_pokal.gif)
What software package is that? Almost looks like Ansys APDL or maybe more like Grape? You're modeling with beam elements or trusses? Can you glue a shell element floor on to better match reality? In one of the racecars I worked on laminating a thin carbon shear panel on the floors increased stiffness by 25-30% (experimentally verified via twist test too).
I think you're seeing artificially high loads in N43A because of the huge open box in the cockpit. If you add triangulation near the doors and closer the floor I bet you'll move some of that load path (if my visual FEA makes any sense haha).
Your loading seems a little weird. Why load the lower arms so highly in the vertical direction? They shouldn't see all that much vertical force since it's really all desisted by the spring/damper unit. Why not model the suspension in as an infinitely stiff member and then load with bump, lateral, and longitudinal forces? Then you wouldn't have to draw a free body diagram to figure out point loads.
With actual loading N36B might be more heavily loaded than you think (and in some combined weird bending/buckling mode so it probably needs a big safety factor). If you're doing frame stiffness twisting it (via moment about the front suspension nodes with the back fixed) seems more widely accepted than loading one side. There is a good SAE paper on it, I might be able to find it somewhere.
Sorry if you know all that stuff already. I'm not a mechanics guy by any means but I've spent a bunch of time doing chassis design/analysis for some tube frame racecars and a Lotus.
Curbandgutter
post Jun 22 2016, 09:44 AM
QUOTE(jd74914 @ Jun 21 2016, 10:40 PM) *
Now that's what I'm talking about! (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) Love this kind of input. Now to answer some of your questions. The lower A arms were not loaded, what you are seeing is the 3 points where the suspension cradle is bolted to the chassis. The 900 lb vertical load represents a 5g load on the wheel. The next step will be to simultaneously load a 900 lb load in a downward fashion on the opposing suspension cradle support points to create a couple, or rather twisting of the frame as you mentioned. I will be running the same scenario at the rear and then run another scenario to simulate bending forces in the frame. I will go ahead and model the floor and both firewalls with plate elements and see what happens. Might as well model the "longs" as well. this will give a better representation of the behavior.
I'm modeling with beam elements with fixed joints in all directions being that the joints will be notched and welded.
I would love to get my hands on that SAE paper. I'm sure that I will learn a couple of things.
jd74914
post Jun 22 2016, 09:58 PM
Its alive
QUOTE(Curbandgutter @ Jun 22 2016, 10:44 AM) *
(IMG:style_emoticons/default/beerchug.gif) I get worried that people will take offense to comments like those sometimes.
Gotcha, I just looked at your pictures again; didn't realize the 996 stuff was all on a subframe. Now it all makes sense.
Looking at that model again it might get stiffer if you switch from the bent front windshield frame halo-style bar rearward facing bars like found in a non-halo cage. Then you'd spread the longitudinal bars (N44 and N43 maybe) out towards the edges moving them further from your head and building a better node at the windshield corners. I just get scared seeing cross-bracing put hoops in bending. It might also be worth switching around some of the triangulation (ie: in front of and behind the door) to meeting at the same places to form some "super nodes." I noticed on the full tube chassis that this seemed to help stiffness without any weight penalty. The x-bracing on top and bottom of the rear might make maintenance very difficult. I did this over a chain drive differential in the name of stiffness and really hated myself for it after the fact. You could probably get most of the stiffness with a bolted shear panel. Hopefully that makes some sense; I can draw it tomorrow really quickly too.
The 5g load is pretty conservative; I've always designed around 3g bump, 2g lateral, and 2g longitudinal loading (though not all at the same time since tire friction circles limit the combined grip) and haven't had many problems. Your analysis plan sounds good to me! Unfortunately I'm at a conference right now and having trouble remoting into my regular computer to look but I'll check for the paper as soon as I get home.
Totally unrelated to the design stuff, but when you notch everything be sure to drill small holes in all of the receiving tubes at the joints. Being able to back purge while welding makes the whole process much better. You have less problems with oils, etc. running out and end up with much higher quality welds. (IMG:style_emoticons/default/smile.gif)
Curbandgutter   914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3   Mar 25 2013, 01:12 PM
kg6dxn   :wttc:   Mar 25 2013, 07:07 PM
BMiller   Welcome aboard! :beer2:   Mar 25 2013, 08:00 PM
pcar916   :beer2: Good luck! :wttc:   Mar 25 2013, 08:26 PM
KaptKaos   Cool!! Where are you in SoCal?   Mar 25 2013, 09:14 PM
Elliot Cannon   Come to the G&R swap meet. Lots of stuff ther...   Mar 25 2013, 10:15 PM
rpmmaxxed   Come to the G&R swap meet. Lots of stuff the...   Mar 26 2013, 02:02 AM
Curbandgutter   Come to the G&R swap meet. Lots of stuff the...   Mar 26 2013, 12:23 PM
carr914   :wttc: and Elliot, wasn't there a Cage in Zo...   Mar 26 2013, 05:25 AM
Elliot Cannon   :wttc: and Elliot, wasn't there a Cage in Z...   Apr 12 2013, 11:48 AM
monkeyboy   Generally cages are unsafe in street cars because ...   Mar 26 2013, 08:39 AM
Curbandgutter   Generally cages are unsafe in street cars because...   Mar 26 2013, 12:19 PM
andys   Ok, you got my attention.......which twin cam V8? ...   Mar 26 2013, 09:48 AM
Curbandgutter   Ok, you got my attention.......which twin cam V8?...   Mar 26 2013, 12:14 PM
carr914   Generally cages are unsafe in street cars because...   Mar 26 2013, 12:19 PM
rpmmaxxed   Generally cages are unsafe in street cars becaus...   Mar 26 2013, 12:34 PM
Joe Sharp   The party thread. http://www.914world.com/bbs2/in...   Mar 26 2013, 05:27 PM
Curbandgutter   The party thread. http://www.914world.com/bbs2/i...   Mar 27 2013, 10:20 AM
Curbandgutter   I have most of the car stripped. Making a rotisse...   Apr 12 2013, 11:14 AM
Elliot Cannon   I have most of the car stripped. Making a rotiss...   Apr 12 2013, 11:53 AM
Curbandgutter   I can personally recommend the Sheridan body. ...   Apr 12 2013, 03:29 PM
Curbandgutter   Well here are some more pictures of the progress. ...   Apr 15 2013, 02:51 PM
bulitt   Well here are some more pictures of the progress....   Apr 15 2013, 03:06 PM
Curbandgutter   More pics   Apr 15 2013, 02:52 PM
Curbandgutter   Bundle of wires   Apr 15 2013, 03:01 PM
BMiller   Good job so far. Keep it up! :beer2:   Apr 15 2013, 09:05 PM
Jgilliam914   Take good care of that Harness! Your gonna nee...   Apr 16 2013, 01:00 PM
Curbandgutter   Thank you for the suggestion. Also with respect t...   Apr 16 2013, 02:22 PM
Curbandgutter   I'm also planning on removing the center tunne...   Apr 16 2013, 02:38 PM
effutuo101   keep it up! a lot of work ahead, but it will b...   Apr 18 2013, 03:35 PM
Curbandgutter   Well it has been a while but I have been collectin...   Aug 4 2014, 01:13 PM
Elliot Cannon   Well it has been a while but I have been collecti...   Aug 4 2014, 02:10 PM
ThePaintedMan   We're gonna have to see some pictures. If we...   Aug 4 2014, 06:43 PM
BIGKAT_83   Well it has been a while but I have been collecti...   Aug 5 2014, 08:01 AM
Curbandgutter   Well it has been a while but I have been collect...   Aug 5 2014, 11:50 AM
Justinp71   Sounds like a good project... funny, one just sold...   Aug 4 2014, 01:31 PM
Curbandgutter   Sounds like a good project... funny, one just sol...   Aug 4 2014, 04:44 PM
Curbandgutter   damm iphone will not hook up to my computer. I...   Aug 4 2014, 04:11 PM
76-914   You need that harness up to the 14pin connector at...   Aug 4 2014, 06:23 PM
Curbandgutter   George, Thank you....I know what you mean. Hopefu...   Aug 4 2014, 06:47 PM
Curbandgutter   OK here are some pictures.   Aug 4 2014, 06:51 PM
Curbandgutter   It's been a while......life happens. I'm ...   Jun 7 2016, 07:15 PM
rick 918-S   How'd I miss this? Belated :wttc:   Jun 7 2016, 08:44 PM
Curbandgutter   How'd I miss this? Belated :wttc: Thanks.   Jun 16 2016, 06:23 PM
arkitect   Can't wait to see more. Dave   Jun 8 2016, 06:21 AM
Curbandgutter   Well here is the rotisserie that I made. I took t...   Jun 14 2016, 02:29 PM
76-914   Looking forward to this. Damn nice rotisserie. Joh...   Jun 16 2016, 06:55 PM
Curbandgutter   Looking forward to this. Damn nice rotisserie. Jo...   Jun 17 2016, 09:15 AM
Curbandgutter   Well since I have to wait until my sand blast kit ...   Jun 17 2016, 09:46 AM
87m491   Wow, a ton of adjustment (and adjusters!) on t...   Jun 17 2016, 09:52 AM
2mAn   Im not sure which body kit you are looking for but...   Jun 17 2016, 10:14 AM
Curbandgutter   Im not sure which body kit you are looking for bu...   Jun 17 2016, 10:35 AM
2mAn   I've really thought it through and finally ca...   Jun 17 2016, 10:57 AM
Curbandgutter   I've really thought it through and finally c...   Jun 17 2016, 11:18 AM
Andyrew   [quote name='2mAn' post='2360624' date='Jun 17 20...   Jun 17 2016, 03:14 PM
Mueller   Neat project. For mounting the suspension, what a...   Jun 17 2016, 10:34 AM
Curbandgutter   Neat project. For mounting the suspension, what ...   Jun 17 2016, 10:42 AM
76-914   Damn Bubba, your in my backyard. PM me your addres...   Jun 17 2016, 02:05 PM
Curbandgutter   Damn Bubba, your in my backyard. PM me your addre...   Jun 17 2016, 02:35 PM
Curbandgutter   And here is the front suspension. I'll be pow...   Jun 17 2016, 07:56 PM
Curbandgutter   Here is the mock up of the rear suspension along w...   Jun 18 2016, 06:07 PM
Andyrew   Looks sweet! Lots of work, but that kind of wo...   Jun 18 2016, 07:38 PM
Curbandgutter   Looks sweet! Lots of work, but that kind of w...   Jun 19 2016, 09:20 PM
r_towle   Challenging exhaust.....   Jun 18 2016, 10:12 PM
Curbandgutter   Challenging exhaust..... It used to be challeng...   Jun 19 2016, 09:24 PM
Mueller   Challenging exhaust..... It used to be challen...   Jun 19 2016, 09:52 PM
Curbandgutter   [quote name='Curbandgutter' post='2361479' date='...   Jun 19 2016, 11:02 PM
Curbandgutter   Little teaser as to what the frame will look like.   Jun 19 2016, 11:02 PM
Andyrew   Little teaser as to what the frame will look like...   Jun 19 2016, 11:15 PM
Curbandgutter   Little teaser as to what the frame will look lik...   Jun 20 2016, 10:22 AM
Randal   Little teaser as to what the frame will look like...   Jun 21 2016, 11:17 AM
Mark Garriott   Little teaser as to what the frame will look lik...   Jun 21 2016, 01:13 PM
Curbandgutter   Little teaser as to what the frame will look lik...   Jun 21 2016, 03:14 PM
Randal   [quote name='Randal' post='2362089' date='Jun 21 ...   Jun 21 2016, 03:41 PM
76-914   I went to Rudy's Saturday to check out his pro...   Jun 21 2016, 09:08 AM
Mueller   I went to Rudy's Saturday to check out his pr...   Jun 21 2016, 09:25 AM
Curbandgutter   I went to Rudy's Saturday to check out his p...   Jun 21 2016, 03:16 PM
Curbandgutter   I went to Rudy's Saturday to check out his pr...   Jun 21 2016, 03:18 PM
914forme   :confused: The top of that rollbar must be 2...   Jun 21 2016, 12:21 PM
Curbandgutter   Well I started to analyze the frame and found that...   Jun 21 2016, 03:43 PM
Chris914n6   http://www.914world.com/bbs2/uploads/post-15637-1...   Jun 27 2016, 08:54 PM
jd74914   Sweet! You don't see too many people doing...   Jun 21 2016, 11:40 PM
Curbandgutter   Sweet! You don't see too many people doin...   Jun 22 2016, 09:44 AM
jd74914   Now that's what I'm talking about! ...   Jun 22 2016, 09:58 PM
Mueller   Are you going to model the suspension? If so chec...   Jun 22 2016, 02:07 PM
Curbandgutter   Are you going to model the suspension? If so che...   Jun 22 2016, 03:18 PM
914forme   The next item on the list is to build the frame...   Jun 22 2016, 03:33 PM
Curbandgutter   I am making it out of 4x4 tubing. The tubing has ...   Jun 22 2016, 05:35 PM
Curbandgutter   I am making it out of 4x4 tubing. The tubing has...   Jun 22 2016, 06:02 PM
Curbandgutter   Thank You JD. I appreciate your excellent input.   Jun 23 2016, 10:30 AM
Curbandgutter   2g Lateral Load at rear yields a 1/16" latera...   Jun 23 2016, 08:01 PM
jd74914   2g Lateral Load at rear yields a 1/16" later...   Jun 23 2016, 10:08 PM
Curbandgutter   I'm feeling pretty good about this chassis :ch...   Jun 23 2016, 08:05 PM
Curbandgutter   That did it. Since the lower frame is flush with ...   Jun 24 2016, 11:52 AM
jd74914   That did it. Since the lower frame is flush with...   Jun 27 2016, 09:09 AM
Curbandgutter   It uses thick tubing for the main hoops and thinne...   Jun 27 2016, 04:51 PM
Curbandgutter   Well the material came in for the the chassis tabl...   Jun 27 2016, 04:56 PM
76-914   Hey Rudy, I almost stopped by today but then I tho...   Jun 27 2016, 06:12 PM
Curbandgutter   No more connections. We used to be in the industr...   Jun 27 2016, 06:35 PM
jd74914   It uses thick tubing for the main hoops and thinn...   Jun 27 2016, 07:00 PM
9 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 19th April 2025 - 03:16 AM
