> Muellers Honda V6 914 project, Put 70 miles on this engine swap, now to drop broken motor
Mueller
post Oct 1 2015, 08:42 PM
914 Freak!
Greeting Earthlings!
Got my 1st of many 914's back in '96 or so...'75 with a bad 1.8, installed new motor, drove it for a while and took apart...sold or cut it up, I don't remember...I've repeated that process about 4 times. Then finally in '07 I sold my last 914 along with my trailer and sold or gave away almost everything I had Porsche related except for a few small models and tee shirts. If you look at my member number, I have been around for a long time...I even have a "Smilie" (IMG:style_emoticons/default/MDB2.gif)
At the beginning of '15 I mentioned to a co-worker I'd like another 914 and we made a deal for his in which I was able to make payments and I paid it off last week. ($200 a month for a grand total of $2000)
The car:
1973 which originally had a 1.7 in it. The PO installed a 2.0 bus motor with megaquirt on it and drove it for a few years and parked it about 4 years ago due to no more compression in cylinder #3.
I knew the car had some engine compartment rust in the hell hole, but it is worse that I thought it had, but I still think I got an okay deal on the car considering I was able to make payments and I knew the history of the car before I even considered buying it.
5x130mm redrilled /4 hubs with extra long studs up front with slide on spacer and bolt on 5x130 to 5x130 bolt on spacer in the back, not keen on either end.
Plans:
Install 1.8 motor I picked up from McMark after I fix a few broken exhaust studs (not Marks fault)
Redo all suspension bushings and possibly the shocks (I think it has KYB's)
Undecided on the wheels, now it has 16x7 53mm offset Phonedials with 205/50/16s.
Fix hell hole.
Fix up the interior.
Do "something" with the turn signals front and back, I don't like 'em (IMG:style_emoticons/default/screwy.gif)
Body needs some straightening and paint for sure. I might toss the green Porsche decal(s) for nothing at all or a different color.
Below are pictures as the car sits across the street. Why across the street and not at my house? Well, I made a deal with the wife that my on going 6 year project car will be driving before I bring the 914 home, that will happen once I install the entire front suspension, install a wiring harness and finish building the engine and install that also.
So possibly before the end of the year the 914 will be home!
Mueller
post Jun 27 2016, 08:33 AM
914 Freak!
Started to work on the 1.7 engine....
4 out 8 exhaust studs are broken, I started to spray them with a penetrate, next will be welding nuts to them and hopefully they screw right out!
I popped off the valve covers and it is very, very clean in there, no sludge. I drained the oil and it was nice and clean (for engine oil, hahaha)
Time to clean off all the tin from it sitting for a few years, and install L-Jet instead of the current D-Jet (so all the D-Jet stuff will be for sale)
Debating whether or not to pull the heads, I figure at this point it might not be a bad idea so I can do a quick inspection. I was a little surprised that it does not have the 911 swivel adjusters, no idea yet if these rockers can be modified for using them or not.
Mueller   Muellers Honda V6 914 project   Oct 1 2015, 08:42 PM
Mueller   Picture of me and my twins, I told them we'll ...   Oct 1 2015, 08:45 PM
Jeff Bowlsby   You know Mike, that's a lot of 914 for 2 bills...   Oct 1 2015, 08:58 PM
Mueller   To be honest with you, I couldn't have told yo...   Oct 1 2015, 09:11 PM
shoguneagle   Mike, I like the car you purchased and as Jeff say...   Oct 1 2015, 10:53 PM
Krieger   Looks like a great project! See if you can ge...   Oct 1 2015, 11:40 PM
ConeDodger   A build-off challenge might be just what you need ...   Oct 1 2015, 11:46 PM
OllieG   Hi Mike, Did you ever own a white, later sprayed ...   Oct 2 2015, 02:10 AM
A&P Mech   Looks like a great starting point. I can't wai...   Oct 2 2015, 05:57 AM
Olympic 1.7   Well, I made a deal with the wife that my on go...   Oct 2 2015, 06:05 AM
tdgray   I think I'm getting old (okay I know I am)...i...   Oct 2 2015, 08:51 AM
Mueller   I think I'm getting old (okay I know I am)......   Oct 2 2015, 10:10 AM
OllieG   [quote name='tdgray' post='2246461' date='Oct 2 2...   Oct 2 2015, 10:43 AM
Andyrew   You gonna put roller bearings in the suspension? :...   Oct 2 2015, 10:24 AM
RobW   Let me know when you need a hand or a part. Love t...   Oct 2 2015, 11:20 AM
RobW   Shouldn't your daughters have cats in their ha...   Oct 2 2015, 11:20 AM
madmax914   So Mike was the motor built by McMark? What intern...   Oct 2 2015, 12:27 PM
Mueller   So Mike was the motor built by McMark? What inter...   Oct 2 2015, 02:11 PM
914forme   Say Grasshopper :wub: God luck Mike, and yes it n...   Oct 2 2015, 02:18 PM
matthepcat   I vote you do the custom drilled bolt pattern for ...   Oct 2 2015, 02:27 PM
2mAn   I vote you do the custom drilled bolt pattern for...   Jun 29 2016, 03:26 PM
Johny Blackstain   Mike- I agree w/ the gang; go for the grasshopper ...   Oct 2 2015, 02:53 PM
Mueller   Mike- I agree w/ the gang; go for the grasshopper...   Oct 2 2015, 03:13 PM
Mueller   Still in the hunting and gathering stages of the b...   Oct 12 2015, 10:47 PM
Chris H.   Dang that's almost junkyard cheap. You gonna ...   Oct 12 2015, 11:12 PM
Andyrew   Nice!   Oct 12 2015, 11:24 PM
76-914   Which power plant you going with??   Oct 13 2015, 07:48 AM
Mueller   Which power plant you going with?? My 1.7 while...   Oct 13 2015, 02:35 PM
76-914   Turbo that puppy. McMarks pulled pretty good.   Oct 13 2015, 03:27 PM
Mueller   Turbo that puppy. McMarks pulled pretty good. ...   Oct 13 2015, 10:58 PM
76-914   [quote name='76-914' post='2251444' date='Oc...   Oct 14 2015, 09:38 AM
Andyrew   [quote name='76-914' post='2251444' date='Oc...   Oct 14 2015, 09:42 AM
Mueller   I found a drawing online that has the bolt hole lo...   Oct 14 2015, 02:46 PM
Mueller   No physical progress...just virtual progress :) O...   Oct 24 2015, 10:40 AM
Andyrew   Ya... Thats awesome... I would love to employ yo...   Oct 24 2015, 01:28 PM
Mueller   Ya... Thats awesome... I would love to employ y...   Oct 25 2015, 01:10 PM
Andyrew   [quote name='Andyrew' post='2256394' date='Oct 24...   Oct 25 2015, 02:41 PM
Mueller   [quote name='Andyrew' post='2256394' date='Oct 2...   Oct 25 2015, 03:27 PM
trojanhorsepower   I like the little computer, where did you get it? ...   Oct 25 2015, 06:21 PM
Mueller   Best Buy, I'd bet you can find them cheaper on...   Oct 25 2015, 06:27 PM
trojanhorsepower   Cool. Does it have mic and headphone/speaker port...   Oct 25 2015, 06:34 PM
Mueller   Cool. Does it have mic and headphone/speaker por...   Oct 25 2015, 07:50 PM
Andyrew   Cool. Does it have mic and headphone/speaker po...   Oct 25 2015, 09:59 PM
mgp4591   [quote name='Mueller' post='2256814' date='Oct 25...   Oct 25 2015, 10:30 PM
Andyrew   [quote name='Mueller' post='2256814' date='Oct 2...   Oct 26 2015, 01:08 PM
madmax914   :confused: This computer conversation is making my...   Oct 26 2015, 11:56 AM
Chris914n6   LA Dismantling had a booth at SEMA. Technically a ...   Nov 4 2015, 10:50 PM
Mueller   Update per request by Jeff.... Nada, nothing don...   Dec 29 2015, 05:27 PM
Mueller   My update for sake of doing an update.... 0 progr...   Jan 24 2016, 02:23 PM
r_towle   Update?   May 30 2016, 11:39 PM
Mueller   Update? No real progress unfortunately, I did s...   May 31 2016, 10:12 AM
r_towle   I saw you talking about going to the August show s...   May 31 2016, 12:19 PM
Mueller   The car is still across the street, however I have...   Jun 24 2016, 11:07 PM
A&P Mech   Mueller, what machine control software are you usi...   Jun 25 2016, 07:34 AM
76-914   Update? No real progress unfortunately, I did ...   Jun 25 2016, 08:05 AM
Mueller   Mueller, what machine control software are you us...   Jun 25 2016, 11:11 AM
Mueller   Started to work on the 1.7 engine.... 4 out 8 exh...   Jun 27 2016, 08:33 AM
Mueller   I am glad to see that it looks like the missing ex...   Jun 27 2016, 08:39 AM
Mueller   Took heads and cylinders off tonight, didn't l...   Jun 29 2016, 01:02 AM
G e o r g e   Took heads and cylinders off tonight, didn't ...   Jun 29 2016, 08:55 AM
Marty Yeoman   93 bore x 71 stroke = 1929cc. Maybe that's wha...   Jun 29 2016, 10:43 AM
Mueller   93 bore x 71 stroke = 1929cc. Maybe that's wh...   Jun 29 2016, 02:22 PM
G e o r g e   are the pistons dished or flat? turning this into...   Jun 29 2016, 03:19 PM
Mueller   are the pistons dished or flat? turning this int...   Jun 29 2016, 04:54 PM
Mueller   July 1st update for Build-Off Challenge. Took th...   Jul 1 2016, 10:18 PM
Mueller   Figured I'd throw some of my engine rebuild pi...   Jul 5 2016, 09:32 PM
Mueller   Got some goodies in the mail today. Real 911 swi...   Jul 5 2016, 09:33 PM
Andyrew   Leakdown test yet? For some reason those valves do...   Jul 5 2016, 11:05 PM
Mueller   Leakdown test yet? For some reason those valves d...   Jul 5 2016, 11:10 PM
matthepcat   Can't wait until you put a turbo on this motor...   Jul 5 2016, 11:34 PM
Mueller   Saved for future update..........   Jul 13 2016, 02:07 PM
2mAn   Which MS setup are you using? Why are you trashing...   Jul 13 2016, 02:41 PM
Mueller   Which MS setup are you using? Why are you trashin...   Jul 13 2016, 03:19 PM
Andyrew   Megasquirt would be perfect for a turbo motor :) ...   Jul 13 2016, 04:14 PM
Mueller   I failed miserably for the 1st Build-Off Challenge...   Oct 18 2016, 08:59 AM
Mueller   I finally have a 914 at my own house after almost ...   Jan 21 2018, 08:11 PM
r_towle   Slacker thread?   Jan 21 2018, 08:30 PM
Krieger   Nice! Good to see things movin! :beer2:   Jan 21 2018, 08:44 PM
Mueller   Pictures of ugly unknown brand headers.   Jan 21 2018, 09:14 PM
tygaboy   Mike - Great to see it's back home!   Jan 22 2018, 08:48 AM
Mueller   Drove up to Pet-a-llama and hung out with Chris (t...   Jan 27 2018, 11:21 PM
tygaboy   Mike - Always great to see you! I'll have ...   Jan 28 2018, 08:40 AM
Mueller   Thanks again Chris, much better pictures than view...   Jan 28 2018, 10:37 AM
Mueller   Drilled and tapped all the exhaust stud holes for ...   Jan 28 2018, 11:33 PM
Mueller   The picture of the tube being cut is for a homemad...   Jan 28 2018, 11:44 PM
Mueller   Started to gather parts to rebuild/restore my ugly...   Feb 16 2018, 12:40 PM
Mueller   Drew up my version of a hockey puck horn pad. Wait...   Feb 25 2018, 09:48 PM
Mueller   Removed gas tank today, the rubber hoses just snap...   Feb 25 2018, 11:18 PM
Andyrew   Removed gas tank today, the rubber hoses just sna...   Feb 26 2018, 08:13 PM
Mueller   Finally test fit my new-to-me BBS wheels and measu...   Feb 25 2018, 11:32 PM
mb911   Looking good.. Keep up the good work   Feb 26 2018, 07:25 AM
Mueller   All these hoses look original to me, I'd like ...   Feb 26 2018, 05:35 PM
Chris H.   Those wheels are PERFECT Mike. Love the long stud...   Feb 26 2018, 08:17 PM
Mueller   Those wheels are PERFECT Mike. Love the long stu...   Feb 26 2018, 11:15 PM
914forme   More than likely rusty from a couple of items. Sa...   Feb 26 2018, 08:19 PM
Mueller   More than likely rusty from a couple of items. S...   Feb 26 2018, 11:03 PM
Krieger   I have not seen the plastic brake lines fail or cr...   Feb 27 2018, 12:01 AM
Mueller   My car does not have a front swaybar, never had on...   Mar 4 2018, 01:25 PM
Mueller   Had car professionally steam cleaned down in San J...   Mar 25 2018, 11:16 AM
Cairo94507   Hey Mike - I believe that is the same place where ...   Mar 25 2018, 12:01 PM
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 3rd April 2025 - 06:53 PM
