Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
Mark Henry |
Jul 9 2016, 11:54 PM
Don't used straight cut gears, my great big engine in the bug still uses a stock gear.
You can reuse the gear but you have to face the holes and sink them a bit to clear the pump, but really a new gear is only something like $30. Use the extra thrust bearing on the cam. BTW type 1 and 4 use the same thrust bearing. |
DavidSweden |
Jul 10 2016, 10:29 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:18 PM |
