Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
Mark Henry |
Jul 10 2016, 11:26 AM
On the double thrust cam bearing couple ways to go about it:
1/Buy a 2nd set of T4 bearing use the DT and toss the rest. 2/Same thing with T1, same bearing as T4, but you can get a DT set that has two DT and save the 2nd DT bearing for later. 3/ buy a set of porsche /6 intermediate shaft DT bearings, they are the same but the oil hole is in the wrong place. So make sure you use one T4 with the correct hole and the other half can be the /6 DT. You could drill the /6 bearing and use both, but I've never done that Sometimes you have to mod the bearing by filing off the lock tang, the lock tang isn't needed, I've never seen a spun cam bearing. |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:27 PM |
