> Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea!
Mueller
post Jun 29 2016, 02:47 PM
914 Freak!
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs)
Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor.
Cam will be a 9600 grind from Rabys old store
Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt.
Exhaust is older European Racing Header.
Mueller
post Jul 11 2016, 09:22 PM
914 Freak!
Still trying to find some input on whether or not the stock L-Jet will work with this 9600 RAT camshaft? (IMG:style_emoticons/default/smile.gif)
Dual Webers are calling my name, trying to avoid spending the $$$ and joining the darkside.
Mueller   Type IV rebuild / refresh thread. Nothing ground breaking.   Jun 29 2016, 02:47 PM
stugray   you can measure the valve travel without even taki...   Jun 29 2016, 02:58 PM
Mueller   you can measure the valve travel without even tak...   Jun 29 2016, 03:06 PM
OU812   Did you try the search function ? You will find m...   Jun 29 2016, 02:59 PM
Mueller   Did you try the search function ? You will find ...   Jun 29 2016, 03:49 PM
OU812   Did you try the search function ? You will find...   Jun 29 2016, 05:49 PM
John Jentz   Jake doesn't sell parts anymore, only turnkey ...   Jun 29 2016, 03:11 PM
Mueller   Jake doesn't sell parts anymore, only turnkey...   Jun 29 2016, 03:48 PM
OU812   I think Jake uses the search function . Be like J...   Jun 29 2016, 03:16 PM
rhodyguy   Saw that one coming 1/2 hour ago. Funny. No quotes...   Jun 29 2016, 03:21 PM
rhodyguy   Unless somebody had their NEW cam read, those deta...   Jun 29 2016, 04:20 PM
Chris H.   If Jake doesn't see this just call Charles at ...   Jun 29 2016, 06:05 PM
r_towle   Mike, Go to Elgin camshafts and look at what he s...   Jun 29 2016, 06:47 PM
Valy   How long did the motor run with broken head studs?...   Jun 29 2016, 08:44 PM
Mueller   Exhaust studs broken, not head studs.....   Jun 29 2016, 10:01 PM
r_towle   Exhaust studs broken, not head studs..... You ar...   Jun 29 2016, 10:13 PM
stugray   Exhaust studs broken, not head studs..... maybe...   Jun 29 2016, 10:58 PM
Mueller   I called LN Engineering, they found the specs for ...   Jun 30 2016, 10:57 AM
stugray   I called LN Engineering, they found the specs for...   Jun 30 2016, 11:23 AM
Mark Henry   I called LN Engineering, they found the specs for...   Jun 30 2016, 01:22 PM
stugray   I called LN Engineering, they found the specs for...   Jun 30 2016, 01:53 PM
G e o r g e   a thread over on the samba Jake references a web c...   Jun 30 2016, 04:50 PM
Mueller   a thread over on the samba Jake references a web ...   Jun 30 2016, 06:38 PM
maf914   It looks like the cam specs are for a split durati...   Jul 1 2016, 07:11 AM
Jake Raby   The 9600 is a straight pattern version of the 9610...   Jul 1 2016, 07:50 AM
Mueller   The 9600 is a straight pattern version of the 961...   Jul 1 2016, 07:51 AM
stugray   The 9600 is a straight pattern version of the 961...   Jul 1 2016, 08:22 AM
Mark Henry   Jake is it an FI cam? Mike said he was thinking L...   Jul 1 2016, 07:53 AM
Mueller   Jake is it an FI cam? Mike said he was thinking ...   Jul 1 2016, 10:11 AM
Mark Henry   ....is the DVD for building Type IVs available an...   Jul 1 2016, 11:45 AM
r_towle   Yup, just build it. Take your time, learn about ho...   Jul 1 2016, 01:08 PM
Mueller   Curious if I should be looking for a cheap single ...   Jul 1 2016, 06:18 PM
Mueller   I ran the part numbers on the head and the cylinde...   Jul 1 2016, 10:08 PM
Valy   That cam is a paperweight.   Jul 1 2016, 11:49 PM
r_towle   That cam is a paperweight. With the gear they ma...   Jul 5 2016, 11:47 AM
Mueller   Both heads will need a little machine work to clea...   Jul 5 2016, 11:11 AM
JOEPROPER   No head gaskets? Is that right? I didn't kno...   Jul 5 2016, 12:48 PM
Mueller   Do I have to buy a new gear for the cam or can I r...   Jul 9 2016, 07:10 PM
jcd914   Do I have to buy a new gear for the cam or can I ...   Jul 9 2016, 11:34 PM
Valy   Reuse.   Jul 9 2016, 09:19 PM
Mark Henry   Don't used straight cut gears, my great big en...   Jul 9 2016, 11:54 PM
DavidSweden   Use the extra thrust bearing on the cam. BTW type...   Jul 10 2016, 10:29 AM
Mueller   Don't used straight cut gears, my great big e...   Jul 10 2016, 10:41 AM
Tbrown4x4   Only 1 half of a cam bearing has a thrust surface....   Jul 10 2016, 11:12 AM
Mark Henry   On the double thrust cam bearing couple ways to go...   Jul 10 2016, 11:26 AM
Mueller   Looked at the bearings I took out of the motor, ma...   Jul 10 2016, 11:32 AM
Mark Henry   If that used DT bearing has a copper face and is i...   Jul 10 2016, 12:04 PM
Mueller   If that used DT bearing has a copper face and is ...   Jul 10 2016, 12:22 PM
rdauenhauer   Do I have to buy a new gear for the cam or can I ...   Jul 10 2016, 09:57 PM
McMark   Do I have to buy a new gear for the cam or can I...   Jul 11 2016, 07:19 AM
colingreene   I have a straight cut cam gear, its not honestly a...   Jul 11 2016, 09:39 AM
Mueller   I have a straight cut cam gear, its not honestly ...   Jul 11 2016, 10:01 AM
Mueller   Still trying to find some input on whether or not ...   Jul 11 2016, 09:22 PM
McMark   Induction is easy to change. Run the L-Jet and se...   Jul 11 2016, 09:28 PM
Mike Bellis   Run the L Jet and put a piggy back system or full ...   Jul 11 2016, 09:32 PM
colingreene   the right and best way to do modern ish fuel injec...   Jul 11 2016, 09:42 PM
Mueller   the right and best way to do modern ish fuel inje...   Jul 11 2016, 10:26 PM
colingreene   You might want to talk to Mark on here about it, o...   Jul 11 2016, 11:12 PM
McMark   The cam assembly lube sticks around for awhile. A...   Jul 12 2016, 06:14 AM
jim_hoyland   Any updates Mike ? I am looking at upgrading my L-...   Aug 11 2016, 12:22 PM
Mueller   Finally getting back to my engine. I picked up ne...   Oct 18 2016, 09:08 AM
Mueller   Bump for spring recommendations! Also, any wo...   Oct 26 2016, 11:08 AM
Mueller   Let's see if this one gets ignored as well :) ...   Mar 7 2017, 01:55 PM
Mark Henry   Let's see if this one gets ignored as well :)...   Mar 7 2017, 01:56 PM
Mueller   Time to start working on the engine again..... Du...   Jun 7 2017, 07:03 PM
Vacca Rabite   Time to start working on the engine again..... D...   Jun 8 2017, 07:06 AM
Mueller   Time to start working on the engine again..... ...   Jun 9 2017, 12:45 PM
McMark   I think that cam would prefer to have dual or HD s...   Jun 8 2017, 07:23 AM
Mueller   I think that cam would prefer to have dual or HD ...   Jun 9 2017, 12:43 PM
Mueller   I just did a quick measurement using my HF digital...   Aug 11 2017, 12:02 AM
McMark   More exhaust flow to compensate for the type 4s po...   Aug 11 2017, 08:41 AM
Mueller   More exhaust flow to compensate for the type 4s p...   Aug 11 2017, 11:29 AM
Keith914   Back to your original question, I suggest you eval...   Aug 11 2017, 11:59 AM
Mueller   Back to your original question, I suggest you eva...   Aug 15 2017, 12:43 AM
McMark   Did you want a 26mm pump? I can send one your way...   Aug 15 2017, 07:04 AM
Mueller   Started to clean the engine again to get it ready ...   Oct 14 2017, 08:20 PM
Mueller   Megasquirt question...really EDIS related. Older M...   Nov 7 2017, 12:15 PM
76-914   That's definitely above my pay grade. :confus...   Nov 7 2017, 05:59 PM
McMark   I'm pretty sure you can just set up your MegaS...   Nov 7 2017, 10:24 PM
Mueller   I'm pretty sure you can just set up your Mega...   Nov 7 2017, 11:58 PM
JamesM   I'm pretty sure you can just set up your Meg...   Nov 8 2017, 12:54 AM
McMark   I'm pretty sure you can just set up your Meg...   Nov 8 2017, 10:49 AM
Mueller   Thanks Mark and James. So i do not need to upgrad...   Nov 8 2017, 11:49 AM
Dr Evil   I may have an EDIS4 if you want it.   Nov 9 2017, 12:27 PM
Mueller   I may have an EDIS4 if you want it. Thanks, I e...   Nov 9 2017, 12:58 PM
Mueller   Silly question, I need to buy or make an engine st...   Nov 15 2017, 01:28 PM
914werke   Perhaps these might help?   Nov 15 2017, 07:18 PM
McMark   I haven't worked with a MegaSquirt unit yet, s...   Nov 16 2017, 08:01 AM
Mikedrevguy   Look forward to seeing this all come together. Goo...   Nov 16 2017, 08:29 AM
Mueller   Finally, some work related to my 914... Removed t...   Dec 25 2017, 02:14 PM
Mueller   Cleaned my engine, also deburred it a little bit a...   Dec 28 2017, 07:54 PM
Mueller   In case it is not in Raby's Type IV assembly D...   Jan 11 2018, 09:51 AM
Mueller   Bump for: What sealant do people use and recomme...   Jan 12 2018, 02:47 PM
76-914   Mike, it's in there somewhere but IIRC it was ...   Jan 12 2018, 03:57 PM
Mueller   Mike, it's in there somewhere but IIRC it was...   Jan 12 2018, 04:21 PM
holtby914   Did you order the DVD recently? I'd love to g...   Jan 12 2018, 06:31 PM
Mueller   Did you order the DVD recently? I'd love to ...   Jan 13 2018, 11:39 AM
Mueller   Not sure if this qualifies for being cheap or reso...   Jan 21 2018, 02:32 PM
McMark   :thumbsup: Lookin' good!   Jan 22 2018, 07:57 AM
Mueller   Dominic was nice enough to send me a straight engi...   Jan 27 2018, 11:03 PM
26 User(s) are reading this topic (26 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 10:26 PM
