Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,768 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Well I've started the process of preparing for
my 2056 GT to 2.4L six "rallye tribute" auto. Tearing into the interior I discovered some rust mites have been eating for a while. Doesn't look too extensive but will be probing some more. The exterior left long was patched a long time ago, albeit incorrectly. This was done by shop that wasn't fully up to speed on these cars and I was still a novice, well still am. I'll be doing some exploratory surgery on this left side inside and out. So I'll get this addressed before any engine install takes place. Would like to have it buttoned up for Hershey 2017. Wish me luck. " Attached thumbnail(s) ![]() ![]() |
theleschyouknow |
Senior Member ![]() ![]() ![]() Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None ![]() |
keep up the good work
somebody I think in the 2016 build off had an alternate method of drilling out the spot welds using regular bits sorry can't remember who it was or the details like bit sizes but basically it involved drilling just thru the first layer with a larger bit and 'exposing' the weld then drilling a thru hole large enough to remove most if not all of the weld then, if necessary, he reported it was easy to pry/pop the panels apart kinda sounds like 2 steps to do 1 to me but he seemed to like the results looks like you have your hands full but also that it is in good hands, have fun! (IMG:style_emoticons/default/beerchug.gif) cjl |
JoeDees |
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None ![]() |
keep up the good work somebody I think in the 2016 build off had an alternate method of drilling out the spot welds using regular bits sorry can't remember who it was or the details like bit sizes but basically it involved drilling just thru the first layer with a larger bit and 'exposing' the weld then drilling a thru hole large enough to remove most if not all of the weld then, if necessary, he reported it was easy to pry/pop the panels apart kinda sounds like 2 steps to do 1 to me but he seemed to like the results looks like you have your hands full but also that it is in good hands, have fun! (IMG:style_emoticons/default/beerchug.gif) cjl Doesn't sound exactly like my technique, but I use a cut off (so it only sticks out about 1/4" from the chuck to prevent breaking bits) 1/8" bit to start a pilot hole (aids a big bit's bite), then use something like a 3/8" bit to only go through that top layer before carefully using a seam buster tool to separate. The technique allowed for welding separate panels back together. Then again, you could be talking about somebody different... |
Lo-Fi Version | Time is now: 27th June 2024 - 08:08 PM |
