> 123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount
914_teener
post Oct 18 2017, 09:28 AM
For those in the position of having a non-functional or failing distributor there is an alternative.
I ran into this issue while building a stock 2.0 motor for my car- while trying to source parts for what I thought was a functional stock distributor.
The link is here for information: http://123ignitionusa.com.
I talked to Ed ......he is based in Ohio and he said he would do group buy discounts if others were interested.
Details:
914 models are available in the following configurations:
1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users.
4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI
5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
Coupon Code to use at checkout is: 914world
Group Buy discount is 10% off retail on any product I offer. If there are more than 10 orders the discount becomes 15% and the additional 5% will be refunded to the cc of the first ten orders.
This group buy is for shipping to any address Con US.
The group buy will run for three weeks and orders will all ship 7-10 days after the close (Nov 10).
Place all orders NOW using the coupon code, and that puts you 'on the list' but your part won't ship until mid-November.
I.ll keep the thread bumped for a couple of weeks to measure or collect interest.
Rob
10-22-2017 Edit: -Rob
Here is the confirmed ...by me....orders that we have. Mark D. (McMark) was kind enough to edit some clarifications for the type of Dizzy to get. You are ultimately responsible...that way we all learn at least something. (IMG:style_emoticons/default/beerchug.gif)
Here is the count I have:
TJB/914 -1
914_teener-1
Philip W.-1
pvollma-1
Amphicar770-1
BeatNavy-1
nditiz1-1
CMONNETT-1
Bsherrard-1
olsib914-1
pete000-1 ( Met Pete at Luftenkult) I'll vouch for him.
Morrie-1
I count 12 if for interest only, so if true that would be 15% discount off list. This will be great comparing notes on performance.
JeffBowlsby
post Oct 19 2017, 01:23 PM
914 Wiring Harnesses
So for the D-Jet model, am I to understand that:
"Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users."
This means no more need for the NLA vacuum can and the advance/retard ports it would connect to on the throttle body can be capped off? This is also a replacement solution for the trigger points.
Si? Please confirm.
What mechanism exactly replaces the trigger points and is it electronic or mechanical (can it wear out)? Can these dizzys be repaired/rebuilt/serviced either DIY or by sending back the the mfr?
If so, this sounds like a great solution for the HTF/NLA trigger points and vacuum cans.
There would be no reason now to replace D-jet injection because of HTF /non-existent parts. All wear parts are available MPS, trigger points, injectors, harnesses, sensors.
914_teener   123 Distributor Group Buy Thread   Oct 18 2017, 09:28 AM
mmichalik   Guys, Although I'm not in need of one now, I ...   Oct 18 2017, 09:47 AM
pete000   I am interested, but only in the Bluetooth program...   Oct 18 2017, 11:58 AM
Mueller   Any model of just the D-jet version you posted?   Oct 18 2017, 12:05 PM
914_teener   Any model of just the D-jet version you posted? ...   Oct 18 2017, 12:53 PM
Dr Evil   Wow! If they had one for a corvair motor I wou...   Oct 18 2017, 12:16 PM
Millerwelds   One key feature with these is they replace the old...   Oct 18 2017, 12:40 PM
Racer Chris   I'm in for one, maybe two.   Oct 18 2017, 01:10 PM
olsib914   plus one for me olsib 914   Oct 18 2017, 02:56 PM
Morrie   I am interested in a D-Jet unit, and possibly a BT...   Oct 18 2017, 02:59 PM
mmichalik   Any model of just the D-jet version you posted? ...   Oct 18 2017, 03:09 PM
BeatNavy   Sorry to be thick, but I just want to be clear: t...   Oct 18 2017, 03:22 PM
914_teener   Rob, My understanding of the Bluetooth app is tha...   Oct 18 2017, 03:42 PM
123ignitionusa   914 models are available in the following Switche...   Oct 18 2017, 06:40 PM
123ignitionusa   Hello Guys I talked to Rob and starting Monday Oct...   Oct 18 2017, 06:33 PM
StratPlayer   I've been running my123 in my DJet setup for o...   Oct 18 2017, 06:59 PM
TJB/914   I am in for one on my D-Jet F.I. engine. Tom   Oct 18 2017, 07:33 PM
TJB/914   I am in for one on my D-Jet F.I. engine. Tom I...   Oct 20 2017, 03:15 PM
914_teener   I am in for one on my D-Jet F.I. engine. Tom ...   Oct 20 2017, 05:16 PM
TJB/914   [quote name='TJB/914' post='2539869' date='Oct 20...   Oct 20 2017, 07:16 PM
914_teener   [quote name='TJB/914' post='2539869' date='Oct 2...   Oct 20 2017, 08:23 PM
McMark   I want everybody to know...and I don't know h...   Oct 21 2017, 10:30 AM
jim_hoyland   Do they make one compatible with L-Jet FI ?   Oct 18 2017, 08:08 PM
Mueller   Do they make one compatible with L-Jet FI ? Ji...   Oct 19 2017, 12:04 AM
Porschef   Do they make one compatible with L-Jet FI ? I...   Oct 19 2017, 05:35 AM
jim_hoyland   Do they make one compatible with L-Jet FI ? ...   Oct 19 2017, 06:13 AM
SKL1   I'd be interested in the one appropriate for a...   Oct 18 2017, 08:47 PM
nditiz1   I'd be interested in the one appropriate for ...   Oct 19 2017, 05:56 AM
914_teener   Obviously I.ve asked Ed to speak for this as i am ...   Oct 18 2017, 10:22 PM
pvollma   Obviously I.ve asked Ed to speak for this as i am...   Oct 19 2017, 12:59 PM
JoeD   I'm running the 123Ignition on my Raby 2270 wi...   Oct 19 2017, 05:53 AM
McMark   Mueller is right in his descriptions. I added a s...   Oct 19 2017, 07:15 AM
914_teener   Mueller is right in his descriptions. I added a ...   Oct 19 2017, 08:02 AM
nditiz1   914world code doesn't work :confused:   Oct 19 2017, 07:31 AM
Philip W.   I have been thinking about this for some time and ...   Oct 19 2017, 07:33 AM
Philip W.   Hello Guys I talked to Rob and starting Monday Oc...   Oct 19 2017, 07:35 AM
nditiz1   Thanks Phil - I missed that post :rolleyes:   Oct 19 2017, 07:55 AM
Vacca Rabite   I bought one of these for my BMW2002 when the 2002...   Oct 19 2017, 07:41 AM
mgphoto   FYI page 1 Specifications Temperature : -30 to 9...   Oct 19 2017, 08:15 AM
Vacca Rabite   FYI page 1 Specifications Temperature : -30 to ...   Oct 19 2017, 08:33 AM
Philip W.   FYI page 1 Specifications Temperature : -30 to...   Oct 19 2017, 08:43 AM
mgphoto   FYI page 1 Specifications Temperature : -30 to...   Oct 19 2017, 08:54 AM
Edward Blume   Would the GB include the /6 distributor? Anybody u...   Oct 19 2017, 08:38 AM
pete000   Would the GB include the /6 distributor? Anybody ...   Oct 19 2017, 03:24 PM
914_teener   Would the GB include the /6 distributor? Anybody...   Oct 19 2017, 06:31 PM
914_teener   95 C is 202 F Hunh....well it will be in the 90...   Oct 19 2017, 08:52 AM
mgphoto   I'm not at the debug with the manufacture yet,...   Oct 19 2017, 08:56 AM
914_teener   I'm not at the debug with the manufacture yet...   Oct 19 2017, 09:07 AM
Vacca Rabite   I'm not at the debug with the manufacture yet...   Oct 19 2017, 09:08 AM
914_teener   I agree with Zach....my coffee is kicking in.   Oct 19 2017, 09:13 AM
mgphoto   Sorry that project and gam-gam have to wait, I...   Oct 19 2017, 09:25 AM
pete000   Sorry that project and gam-gam have to wait, I...   Oct 19 2017, 03:25 PM
mgphoto   Sorry that project and gam-gam have to wait, I...   Oct 19 2017, 04:44 PM
Jett   I’m in for. DJet version.   Oct 19 2017, 09:57 AM
914_teener   Okay cool. Ed asked me to get a head count. I.ll ...   Oct 19 2017, 10:14 AM
Jeff Bowlsby   So for the D-Jet model, am I to understand that: ...   Oct 19 2017, 01:23 PM
914_teener   So for the D-Jet model, am I to understand that: ...   Oct 19 2017, 06:04 PM
Mueller   Looking at the manual, D-Jet specific distributor ...   Oct 19 2017, 01:36 PM
Jeff Bowlsby   I thought if it had 'hardcoded advance curves...   Oct 19 2017, 02:01 PM
jd74914   I thought if it had 'hardcoded advance curves...   Oct 19 2017, 02:05 PM
mgphoto   I thought if it had 'hardcoded advance curves...   Oct 19 2017, 03:15 PM
914_teener   [quote name='Jeff Bowlsby' post='2539445' date='O...   Oct 19 2017, 04:25 PM
mgphoto   Single vacuum port, if I have it correct the ...   Oct 19 2017, 04:39 PM
914_teener   Single vacuum port, if I have it correct the ...   Oct 19 2017, 05:15 PM
914_teener   I thought if it had 'hardcoded advance curves...   Oct 19 2017, 04:24 PM
rhodyguy   Who ever installed stratplayer's (Jim) should ...   Oct 19 2017, 05:19 PM
914_teener   No Kevin, Trigger points and vacuum advance can. ...   Oct 19 2017, 05:38 PM
StratPlayer   Mine is a 76 D Jet, 2056. The install was easy ju...   Oct 19 2017, 06:05 PM
914_teener   Mine is a 76 D Jet, 2056. The install was easy j...   Oct 19 2017, 06:08 PM
914_teener   .....oh yea it uses a Hall Effect sensor to trigge...   Oct 19 2017, 06:07 PM
StratPlayer   Here is the dizzy that I'm using. When it was...   Oct 19 2017, 06:08 PM
Amphicar770   I will go for one. Just need to make sure that t h...   Oct 19 2017, 07:22 PM
bandjoey   Can someone explain the Bluetooth part? What does...   Oct 19 2017, 08:09 PM
jd74914   Can someone explain the Bluetooth part? What doe...   Oct 19 2017, 09:11 PM
Jeff Bowlsby   I found the manual for these and it has a list of ...   Oct 19 2017, 09:39 PM
mgphoto   I found the manual for these and it has a list of...   Oct 19 2017, 11:20 PM
Jeff Bowlsby   Aha! They used the Bosch PN. Muchas gracias....   Oct 19 2017, 11:28 PM
euro911   OK, building up my wife's 71 1.7L motor to a 1...   Oct 20 2017, 12:36 AM
BeatNavy   Placed my order this morning. Coupon code "9...   Oct 20 2017, 06:12 AM
nditiz1   Placed my order this morning. Coupon code ...   Oct 20 2017, 09:23 AM
Philip W.   So I have a 75 2.0 but with a TB from a 73, I gues...   Oct 20 2017, 06:20 AM
pete000   Ordering today... :trophy:   Oct 20 2017, 09:36 AM
914_teener   Order Placed. This will be interesting.   Oct 20 2017, 10:42 AM
CMONNETT   Order Placed.   Oct 20 2017, 02:44 PM
914_teener   It.s okay Mark....figured :D   Oct 21 2017, 11:27 AM
Bsherrard   Just placed my order for the Bluetooth model for t...   Oct 21 2017, 11:41 AM
Morrie   Ordered my D-Jet unit today. This will be interes...   Oct 21 2017, 01:04 PM
914_teener   Ordered my D-Jet unit today. This will be intere...   Oct 21 2017, 02:04 PM
pete000   Ordered my D-Jet unit today. This will be inter...   Oct 21 2017, 10:34 PM
Morrie   With respect to the advance or retard question rea...   Oct 22 2017, 09:41 AM
SKL1   Just talked to Ed today- probably don't need ...   Oct 21 2017, 08:00 PM
olsib914   Ordered for my D-Jet stock Also have one for my Vo...   Oct 21 2017, 08:17 PM
pete000   Just ordered mine, Bluetooth version for my L-Jet ...   Oct 21 2017, 10:58 PM
Morrie   Just ordered mine, Bluetooth version for my L-Jet...   Oct 22 2017, 09:44 AM
1adam12   I thought this distributor looked familiar. I ran...   Oct 22 2017, 12:47 PM
euro911   I thought this distributor looked familiar. I ran...   Oct 22 2017, 06:53 PM
mgphoto   I thought this distributor looked familiar. I ra...   Oct 22 2017, 08:02 PM
914_teener   Weekend Bump and Count added. :bump:   Oct 22 2017, 03:51 PM
Mueller   For those have the programmable units already, any...   Oct 22 2017, 04:38 PM
euro911   Can someone post a link to Brad's write-up on ...   Oct 22 2017, 06:54 PM
4 Pages V  1 2 3 > »
38 User(s) are reading this topic (38 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 09:43 PM
