123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount |
914_teener |
Oct 18 2017, 09:28 AM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
For those in the position of having a non-functional or failing distributor there is an alternative.
I ran into this issue while building a stock 2.0 motor for my car- while trying to source parts for what I thought was a functional stock distributor. The link is here for information: http://123ignitionusa.com. I talked to Ed ......he is based in Ohio and he said he would do group buy discounts if others were interested. Details: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Coupon Code to use at checkout is: 914world Group Buy discount is 10% off retail on any product I offer. If there are more than 10 orders the discount becomes 15% and the additional 5% will be refunded to the cc of the first ten orders. This group buy is for shipping to any address Con US. The group buy will run for three weeks and orders will all ship 7-10 days after the close (Nov 10). Place all orders NOW using the coupon code, and that puts you 'on the list' but your part won't ship until mid-November. I.ll keep the thread bumped for a couple of weeks to measure or collect interest. Rob 10-22-2017 Edit: -Rob Here is the confirmed ...by me....orders that we have. Mark D. (McMark) was kind enough to edit some clarifications for the type of Dizzy to get. You are ultimately responsible...that way we all learn at least something. (IMG:style_emoticons/default/beerchug.gif) Here is the count I have: TJB/914 -1 914_teener-1 Philip W.-1 pvollma-1 Amphicar770-1 BeatNavy-1 nditiz1-1 CMONNETT-1 Bsherrard-1 olsib914-1 pete000-1 ( Met Pete at Luftenkult) I'll vouch for him. Morrie-1 I count 12 if for interest only, so if true that would be 15% discount off list. This will be great comparing notes on performance. |
JeffBowlsby |
Oct 19 2017, 01:23 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So for the D-Jet model, am I to understand that:
"Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users." This means no more need for the NLA vacuum can and the advance/retard ports it would connect to on the throttle body can be capped off? This is also a replacement solution for the trigger points. Si? Please confirm. What mechanism exactly replaces the trigger points and is it electronic or mechanical (can it wear out)? Can these dizzys be repaired/rebuilt/serviced either DIY or by sending back the the mfr? If so, this sounds like a great solution for the HTF/NLA trigger points and vacuum cans. There would be no reason now to replace D-jet injection because of HTF /non-existent parts. All wear parts are available MPS, trigger points, injectors, harnesses, sensors. |
914_teener |
Oct 19 2017, 06:04 PM
So for the D-Jet model, am I to understand that: "Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users." This means no more need for the NLA vacuum can and the advance/retard ports it would connect to on the throttle body can be capped off? This is also a replacement solution for the trigger points. Si? Please confirm. What mechanism exactly replaces the trigger points and is it electronic or mechanical (can it wear out)? Can these dizzys be repaired/rebuilt/serviced either DIY or by sending back the the mfr? If so, this sounds like a great solution for the HTF/NLA trigger points and vacuum cans. There would be no reason now to replace D-jet injection because of HTF /non-existent parts. All wear parts are available MPS, trigger points, injectors, harnesses, sensors. Yes Jeff. Here is the answer I got from Ed on the tempeture question and the vacuum port question: On the switch model there are five curves that have vacuum advance and five curves that have vacuum retard. It modulates the vacuum curve when a hose is hooked up to the device. If there's no vacuum it doesn't change the Curve. The 95 degrees has not been a problem with any other VW or Porsche applications. I.m getting it. |
Lo-Fi Version | Time is now: 28th September 2024 - 04:05 PM |
