Dr Phil’s copper 914 restoration thread- paint and body work on deck- getting fenders fixed and car repainted! New thread to document process, Update:- some finishing touches - constant , never done LOL |
DRPHIL914 |
Oct 28 2017, 11:47 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
after 8 years of ownership, and 2 years of rust repair and other such stuff, i am fuinally getting ready to take it to get the fenders repaired the reat of the way and the crappy respray sanded off and car repainted.
i wantes to start a new thread apart from the failed entry into the first rebuild contest. with the help of BillH1963 and a friend of his (Mike) i hope to have this done in 2 months! i am pulling this motor and transmission today. stripping car down this week and next week taking bare car with windows out, interior out, up to Mikes shop up near Columbia SC. They will be sanding it down by hand to the original primer and fixing and missed rust etc not repaired last year- as previously documented the floor pan rust jack points longs and pedal area were all repaired by Chis and Ed at Tangerine Racing in 2016. they also repaire the fender lips that were bent and damaged and massaged the rear fenders out to get room for the 7" fuchs. Now those will be smoothed out the rest of the way. and a proper match of L99k copper metallic ( goimg with the PPG - thanks for advice on this from Bill Dunster! will document this for fun and future reference- car is original matching numbers 2.0 with appearance group car- but i decided this week since i have 5 lug etc im goimg to back date the bumpers- none of this ruins originality as far as it cant be undone- i thint it will look better too so here we go!!! Attached thumbnail(s) |
DRPHIL914 |
Oct 31 2017, 01:36 PM
so last night I did a dry run fit to see if jack goes up high enough- check! it goes up 25" , but the jack plate where the tuna can goes is a bit tight- I have the deep one and it was hard to get it lined up properly and slipped over the deep tuna can sump so I might remove that ( guess im doing another oil change). also I have plenty of leaks here and there, possibly the stock oil cooler and a few of the push rod tubes- I did new tubes and seals back when I did all my suspension and brakes a few years ago, same time I pulled the transmission and rebuilt it at an EVIL clinic, I also did the clutch pressure plate and flywheel and RMS at that time - I can happily report that the transmission and RMS are leak free still- so glad I don't have to go down that road. - I also hesitate to do much with anything else since the compression # were good- all 4 @ 135-140 when checked by CFR- chris said no reason to do anything there, leak down was good too., so makes me thing that this car with 153,000 miles must have had some type of refresh done at some point but I have no record of it ---
for now plan is just take care of some of the leaks, then I already have brand new repowdercoated tin, intakes and air box so top end will be nice and clean. I will put no Alt belt on it while there too- ive been running what ever was there when I go it 8 years ago (IMG:style_emoticons/default/blink.gif) . - also I need to source the SS fuel lines - now will be the time- I didn't have any leaks, plastic lines are supple not brittle so I left it alone- didn't want to put it up just to do that when it didn't seem necessary. Also coming out is the fresh air box since tank is coming out too, that has never worked so now I can get one that works in there (unless someone suddenly comes up whith and AC box that will fiit there). hope to have motor out tomorrow night- will see - going to pull the rear valance just to get a few more inches but I think I[m good- it has to come off anyway though. |
Lo-Fi Version | Time is now: 28th December 2024 - 04:06 AM |
