DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
after 8 years of ownership, and 2 years of rust repair and other such stuff, i am fuinally getting ready to take it to get the fenders repaired the reat of the way and the crappy respray sanded off and car repainted.
i wantes to start a new thread apart from the failed entry into the first rebuild contest. with the help of BillH1963 and a friend of his (Mike) i hope to have this done in 2 months! i am pulling this motor and transmission today. stripping car down this week and next week taking bare car with windows out, interior out, up to Mikes shop up near Columbia SC. They will be sanding it down by hand to the original primer and fixing and missed rust etc not repaired last year- as previously documented the floor pan rust jack points longs and pedal area were all repaired by Chis and Ed at Tangerine Racing in 2016. they also repaire the fender lips that were bent and damaged and massaged the rear fenders out to get room for the 7" fuchs. Now those will be smoothed out the rest of the way. and a proper match of L99k copper metallic ( goimg with the PPG - thanks for advice on this from Bill Dunster! will document this for fun and future reference- car is original matching numbers 2.0 with appearance group car- but i decided this week since i have 5 lug etc im goimg to back date the bumpers- none of this ruins originality as far as it cant be undone- i thint it will look better too so here we go!!! Attached thumbnail(s) ![]() ![]() |
DRPHIL914 |
using the bracket from tangerine - it went well except it appears the motor mounts have never been changed and the engine bar mount bolt on one side snapped due to being rusted in the bar - iv not removed a motor but i see here that my motor mounta were not attached to he motor- just resting on the rubber mounts- crazy wndwr how long those have been in this condition?
Attached thumbnail(s) ![]() |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
DRPHIL914 |
using the bracket from tangerine - So you didn't need my special adapter with your new jack? Nope, - the jack I bought worked fine, just pulled the round jack plate off, and put yours on it the peg on the bottom of yours fit perfectly, same size so no nneed for the adaptor. - - btw at some point id like to get the adaptor you make for the side jack point in the long if you still make them. Thanks for sending that down so quickly it made the job much easier, I had help to balance the drivetrain just in case but could have done it myself if I had to. going to get with you about the SS fuel lines next- I will install once car comes back from paint. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:15 AM |
