Dr Phil’s copper 914 restoration thread- paint and body work on deck- getting fenders fixed and car repainted! New thread to document process, Update:- some finishing touches - constant , never done LOL |
DRPHIL914 |
Oct 28 2017, 11:47 AM
Dr. Phil Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
after 8 years of ownership, and 2 years of rust repair and other such stuff, i am fuinally getting ready to take it to get the fenders repaired the reat of the way and the crappy respray sanded off and car repainted.
i wantes to start a new thread apart from the failed entry into the first rebuild contest. with the help of BillH1963 and a friend of his (Mike) i hope to have this done in 2 months! i am pulling this motor and transmission today. stripping car down this week and next week taking bare car with windows out, interior out, up to Mikes shop up near Columbia SC. They will be sanding it down by hand to the original primer and fixing and missed rust etc not repaired last year- as previously documented the floor pan rust jack points longs and pedal area were all repaired by Chis and Ed at Tangerine Racing in 2016. they also repaire the fender lips that were bent and damaged and massaged the rear fenders out to get room for the 7" fuchs. Now those will be smoothed out the rest of the way. and a proper match of L99k copper metallic ( goimg with the PPG - thanks for advice on this from Bill Dunster! will document this for fun and future reference- car is original matching numbers 2.0 with appearance group car- but i decided this week since i have 5 lug etc im goimg to back date the bumpers- none of this ruins originality as far as it cant be undone- i thint it will look better too so here we go!!! Attached thumbnail(s) |
DRPHIL914 |
Nov 13 2017, 11:35 AM
Guys, I don't have a picture to post - but car was stripped down to the bare except for my dash which was new and installed last year- , I took the car to storage of my new body paint guy- Mike on Saturday- a short 90 minute drive up from beaufort/bluffton . Mike has done work for a few other guys int he area, including billh, and I am confident he is up to the task.
While there I met up with Bill to give him his swag from theOkteenerfest that he missed due to the flooding from the hurricane- so he treated me to a couple drive in some other aircool rides tail-draggers but very cool- Bill - thanks for the awesome rides and I look forward to you having a 914 actually running soon!!! while cleaning out the wheel wells I found a rust thru spot on passenger side front behind bumper and that will have to be patched, the other was drivers side wheel well but inside the back of front wheel well, at the bottom- Mike says no problem, all will be cleaned out they will be cleaning out all the undercoating out of wheel wells and off the bottom of the car, and all rust spots cut out, cleaned patched and sealed properly!!! I now have a decision to make- I'm still on the fence for doing bumper back dating- now is the time to do it or never look back , to modify the front now would be best so it gets primed sealed and painted, later would be bad to cut and grind off parts newly painted- so should I or shouldn't I ?? I really would like to do this, I think early bumpers look way better. , lighter etc. even just to do the fiberglass for now and SS later, ( probably cant afford it- ) I'd like some input from the peanut gallery - back date nor not!?? - new parts I need to get: *new rocker panels- probably RD * new carpet- * new side marker lights * I also need new bright parts- chrome trim for the rear targa sail panels * new a-pillar and side pillar interior trims needed with front top edg trim that goes under the visors, and rear targa bar trim that goes across inside top edge of targa bar. - has anyone had thse recovered?? I know Mark might eventually but this would really be awesome as Ive already done my seats and dash - I will also be installing new gauge set I have from Tim, LED etc, inside will be SWEET! will spend the next few months getting motor cleaned up and sorted out- I have to reseal , replace oil cooler seals, I already have allnew tin, and I have parts coming from Bruce Stone , - I might send the TB out to rebuild, This car has 150k miles on it just turned over on the Okteenerfest trip- so at some point the motor must have had work done because the leak down and compression numbers are very good. - no need to dig into that, just a freshing up of the cosmetics on top side. any advice about "while I am in there"? Thanks! will post pictures as they start sanding down and repairing stuff, then its prime, block paint -- 3 coats of base and 3 coats of clear , PPG L99K, Copper Metallic! |
Lo-Fi Version | Time is now: 26th June 2024 - 08:10 AM |
