> 914 Diesel build....
PatrickB
post Jul 4 2018, 04:30 AM
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure.
Had a chirp that turned into a BAD miss, valve seat issue on one cylinder.Attached Image
Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning...Attached Image
914forme
post Jul 5 2018, 08:49 AM
I used to Auto-x an A3 Jetta, loved that little car.
Fooling the actuator is pretty easy, most people just used an aquarium air valve, old school. Small restrictor will also work.
As far as the 901 goes you will be fine. The Evil Dr. will be a great resource I would look for an H or HA 5th, and play around with the rest of the gearing. His Evil one can tell you what gears can be sourced cheaply and should work with the diesel. I used to launch my 914-4 in 2nd gear at the auto-x so with the diesel you should be fine in second. That removes the weakest part of the trans.
Cooling should be easy as this engine only really produces heat under load. So a small rad should be easy. Just look at the size of the stock Rabbit Rad and calculate the cooling area. Then find something that fits. You might be able to use a couple well placed Heater cores from a large truck, and get enough airflow to keep the front trunk like Brant's oil coolers on his race car.
I love cheap builds, and mine start that way and spin out of control with while I am in their itis.
PatrickB
post Jul 5 2018, 10:43 AM
QUOTE(914forme @ Jul 5 2018, 10:49 AM) *
What |I did to fool the waste gate on the K14 was pull out one of the banjo bolts and drill a small hole to bleed a little boost off the signal line. Neater than a valve and incognito. Just keep going a little bigger hole until I get where I want to be. Apparently this engine is good for about 30 pounds without head studs. No point going that high without an intercooler though.20 pounds is lots. The K14 actually is adjustable but I was afraid of breaking the bolt off. T3 is not adjustable. Might pull the same trick on it.
As for cooling, plan is to get the engine sitting in place, then figure out what room is left. Then make a trip to a wrecking yard with a tape measure... I'd like to use the rad out of a mark 3 golf (2 fans) I have sitting here but I don't think it will fit... unless I can mount it across the front of the engine bay a little low and on an angle, air flow directed from under the car. Not counting on that. I've been running diesels for a long time and you're right, they don't make a lot of heat unless they're working hard. My kid was showing me pictures of Honda rads that might work. VW Fox should work but probably hard to find.
PatrickB   914 Diesel build....   Jul 4 2018, 04:30 AM
PatrickB   Plan is to build the car with the more tired engin...   Jul 4 2018, 04:38 AM
PatrickB   BTW I may have a complete 2L engine for sale at so...   Jul 4 2018, 04:42 AM
mb911   That will be very cool..   Jul 4 2018, 05:42 AM
914forme   As a diesel owner :headbanger: A couple of peop...   Jul 4 2018, 07:22 AM
PatrickB   As a diesel owner :headbanger: A couple of peo...   Jul 4 2018, 07:37 AM
Porschef   Extremely cool. Having had an ALH Golf for some ti...   Jul 4 2018, 07:43 AM
914forme   The 914 converted with an ALH did about 60+ MPG, i...   Jul 4 2018, 08:03 AM
Porschef   Should have keep that engine, found a FWD Passa...   Jul 4 2018, 08:17 AM
PatrickB   Car was previously owned by a body shop owner, onl...   Jul 4 2018, 08:40 AM
poorsche914   Subscribed :) I have wanted to do a TDI conversi...   Jul 4 2018, 08:52 AM
Porschef   ... Wow, never seen that. Kinda like 914 meets...   Jul 4 2018, 09:07 AM
PatrickB   Good eye. Ford probe bumpers grafted on, then bo...   Jul 4 2018, 09:16 AM
Porschef   Which now really makes it a perfect candidate for ...   Jul 4 2018, 09:35 AM
PatrickB   Anyone know if this one ever got finished? PM had ...   Jul 4 2018, 12:02 PM
914-d   One of my project is a 914 diesel...here are a few...   Jul 4 2018, 10:20 AM
JRust   Hey that body work was done tastefully. All the qu...   Jul 4 2018, 10:22 AM
914forme   Yes I think it got done, have not talked with him ...   Jul 4 2018, 12:29 PM
Dave_Darling   I'm wondering about the gearbox... The gearin...   Jul 4 2018, 02:03 PM
porschetub   I'm wondering about the gearbox... The geari...   Jul 19 2018, 01:36 AM
PatrickB   I'm wondering about the gearbox... The gear...   Jul 19 2018, 03:30 AM
porschetub   [quote name='porschetub' post='2630615' date='Jul...   Aug 25 2018, 10:30 PM
PatrickB   [quote name='porschetub' post='2630615' date='Ju...   Aug 26 2018, 03:55 AM
Chris H.   Very unique bodywork. Looks well done. Wonder how...   Jul 4 2018, 03:21 PM
914-d   I'm wondering about the gearbox... The geari...   Jul 4 2018, 03:22 PM
914forme   What you need for these is an 6 speed out of a Aud...   Jul 4 2018, 03:45 PM
914-d   Might use that trans on the next one. I have a gu...   Jul 4 2018, 04:04 PM
914forme   I do the same thing but use a guy in England.   Jul 4 2018, 04:47 PM
PatrickB   Using the 901 trans. The engine I'm using is ...   Jul 5 2018, 04:34 AM
Dave_Darling   Maybe a taller ring and pinion and bring all the g...   Jul 17 2018, 12:35 PM
PatrickB   Maybe a taller ring and pinion and bring all the ...   Jul 17 2018, 03:43 PM
914forme   I used to Auto-x an A3 Jetta, loved that little ca...   Jul 5 2018, 08:49 AM
PatrickB   I used to Auto-x an A3 Jetta, loved that little c...   Jul 5 2018, 10:43 AM
PatrickB   How critical is it to have the crankshaft of the e...   Jul 17 2018, 03:58 AM
914forme   To answer your question if it was just the engine,...   Jul 17 2018, 06:34 AM
PatrickB   To answer your question if it was just the engine...   Jul 17 2018, 03:35 PM
Dr Evil   Very cool! Always wanted to see something like...   Jul 17 2018, 08:17 AM
PatrickB   Very cool! Always wanted to see something lik...   Jul 17 2018, 03:38 PM
Chris H.   Yes the Vanagon diesel oil pan allows you to turn ...   Jul 17 2018, 12:21 PM
914forme   To add off Dave's ideas, the Speedo fix is muc...   Jul 17 2018, 01:03 PM
Porschef   I don't know the gearing letters, but maybe a ...   Jul 17 2018, 01:47 PM
PatrickB   I don't know the gearing letters, but maybe a...   Jul 17 2018, 03:44 PM
Dave_Darling   I don't know the gearing letters, but maybe a...   Jul 17 2018, 10:29 PM
PatrickB   I don't know the gearing letters, but maybe ...   Jul 18 2018, 03:35 AM
Dr Evil   I don't know the gearing letters, but maybe ...   Jul 18 2018, 09:33 AM
PatrickB   [quote name='Dave_Darling' post='2630295' date='J...   Jul 19 2018, 03:25 AM
914forme   Can you give me a ballpark of what the revs will...   Jul 19 2018, 12:56 PM
PatrickB   Did a little more cutting.... can't get the en...   Jul 17 2018, 06:37 PM
PatrickB   need to clean up the cuts a little more, do some w...   Jul 17 2018, 06:50 PM
Porschef   Keep on keepin' on... :beer2: :beer2:   Jul 17 2018, 08:02 PM
Porschef   Ahhh, that explains it. Cool. :beer2:   Jul 18 2018, 10:43 AM
Dr Evil   I thought the little diesels like to rev high, tho...   Jul 19 2018, 01:26 PM
PatrickB   I thought the little diesels like to rev high, th...   Jul 19 2018, 02:30 PM
Dr Evil   I thought the little diesels like to rev high, t...   Jul 20 2018, 12:18 PM
PatrickB   [quote name='PatrickB' post='2630777' date='Jul 1...   Jul 20 2018, 12:47 PM
PatrickB   double post...   Jul 20 2018, 12:52 PM
Chris914n6   re:position... RH has trans blocks that move the ...   Jul 20 2018, 02:52 PM
Porschef   Is there a specific year group of the trannys that...   Jul 26 2018, 04:25 AM
PatrickB   Engine is mounted, working on trying to put a rad ...   Aug 6 2018, 01:31 PM
PatrickB   Open to thoughts from those that have done other s...   Aug 8 2018, 04:34 AM
914forme   What wall thickness is the crossbar? What I don...   Aug 8 2018, 06:51 AM
PatrickB   What wall thickness is the crossbar? What I don...   Aug 8 2018, 10:36 AM
PatrickB   Not the best picture but shows the construction of...   Aug 8 2018, 11:03 AM
Chris914n6   You need a drivers side engine mount. No doubt abo...   Aug 8 2018, 03:25 PM
PatrickB   You need a drivers side engine mount. No doubt ab...   Aug 9 2018, 05:22 AM
stownsen914   Agreed with reinforcing your crossbar where the no...   Aug 9 2018, 07:29 AM
PatrickB   Agreed with reinforcing your crossbar where the n...   Aug 9 2018, 09:45 AM
Rob-O   subscribed!   Aug 20 2018, 10:47 AM
PatrickB   subscribed! You were right, at least the ma...   Aug 25 2018, 05:12 PM
PatrickB   Honda rad installed. Lower rad hose from mk 2 jett...   Aug 20 2018, 01:59 PM
2mAn   I had visions of a watercooled VW motor install......   Aug 21 2018, 10:59 AM
914forme   :rotfl: Your not going with a trash can stack poki...   Aug 26 2018, 08:25 AM
PatrickB   Rad in, custom water outlet from back of head fo...   Sep 2 2018, 08:11 AM
tomeric914   The exhaust is straight up just until I get to t...   Sep 2 2018, 01:38 PM
914forme   The exhaust is straight up just until I get to ...   Sep 2 2018, 03:41 PM
PatrickB   [quote name='tomeric914' post='2644848' date='Sep...   Sep 2 2018, 06:54 PM
Porschef   No shit... Well would you look at THAT!! ...   Sep 2 2018, 08:56 AM
Rob-O   Nice!   Sep 2 2018, 11:39 AM
PatrickB   Nice! Lots to do yet.... Need some fuel line...   Sep 2 2018, 12:37 PM
Rob-O   [quote name='Rob-O' post='2644820' date='Sep...   Sep 2 2018, 03:20 PM
Porschef   Really impressed with the conversion, it seems to ...   Sep 3 2018, 06:07 AM
PatrickB   Really impressed with the conversion, it seems to...   Sep 3 2018, 05:16 PM
PatrickB   Road block.... Hooking fuel lines. No return line ...   Sep 4 2018, 06:52 PM
PatrickB   Had it fired up today but the injection pump ran o...   Sep 8 2018, 02:56 PM
Chris H.   Terrycable will make you one. I had one made a fo...   Sep 8 2018, 03:58 PM
PatrickB   Terrycable will make you one. I had one made a f...   Sep 8 2018, 04:17 PM
PatrickB   IT'S ALIVE!! https://youtu.be/6BwvBVN...   Sep 9 2018, 06:00 PM
Rob-O   Cool...but we need something longer than six secon...   Sep 9 2018, 06:18 PM
PatrickB   Cool...but we need something longer than six seco...   Sep 9 2018, 06:34 PM
914forme   I say rock the stack, just except it, and move on....   Sep 9 2018, 07:16 PM
Dave_Darling   For the throttle, perhaps you could take inspirati...   Sep 9 2018, 07:42 PM
PatrickB   For the throttle, perhaps you could take inspirat...   Sep 10 2018, 04:45 PM
PatrickB   Too much coal too.... Engine would already do that...   Sep 10 2018, 03:21 AM
PatrickB   Had it out for a drive for 20 minutes or so, got a...   Sep 11 2018, 06:37 PM
PatrickB   First time out at the autocross with the diesel. A...   Sep 15 2018, 04:06 PM
Dr Evil   First time out at the autocross with the diesel. ...   Sep 18 2018, 01:42 PM
PatrickB   First time out at the autocross with the diesel....   Sep 18 2018, 04:30 PM
914forme   lots of Civic Rads that are of "better" ...   Sep 18 2018, 06:57 PM
PatrickB   Got the tach working tonight with the help of an a...   Sep 19 2018, 06:40 PM
PatrickB   Should update this thread. Got the throttle cable,...   Jul 6 2019, 05:14 PM
- Lo-Fi Version Time is now: 18th April 2025 - 05:08 AM
