33 Pages V « < 9 10 11 12 13 > »
> Fix a six, Like Neil Young says...rust is an insomniac
Speedo
post Mar 31 2016, 08:08 PM
Post #201
QUOTE(DCJosh @ Mar 31 2016, 05:30 PM) *
This thread has me afraid of what I might find.
This was a "dry" car. I paid what I felt was fair given that I was pretty sure...what I was going to find. After sandblasting I found way more than I ever anticipated. Thank god this was not an east coast car...sorry Luke!
But, there is a tremendous amount of satisfaction bringing the chassis back after finding all the "problems". These cars are "erector sets" for adults. And the restorations become addictive. Engine rebuilds are a piece of cake compared to bringing back a rusty chassis...me thinks.
Speedo
Speedo
post Mar 31 2016, 08:31 PM
Post #202
Oh and Brant.....
I am reminded. Maybe I have actually morphed?
post Jun 20 2012, 06:57 PM
Post #40
you're moving much too fast to be a real 914 guy...
all this in 2 weeks and the thing isn't on jack stands yet
you need to slow down for a year or two if you want to be a true teener fan....
Ferg
post Apr 1 2016, 10:24 AM
Post #203
QUOTE(Speedo @ Mar 31 2016, 06:31 PM) *
Oh and Brant.....
Post #40
Whoops (IMG:style_emoticons/default/lol-2.gif)
Speedo
post Apr 3 2016, 01:05 PM
Post #204
Before I re-attach the bottom of the latch panel and outer rear quarter, I want to evaluate the access I need to finish up the longitudinal repair under the hell hole. I have looked through a lot of threads on this repair...many ways to skin this cat. RD steel for the inner longitudinal confused me. Top of mine appeared to be two layers, their panel was one layer and looked like my inner steel. This thread cleared it up...
http://www.914world.com/bbs2/index.php?sho...p;#entry2325382
I will now deconstruct and evaluate.
Speedo
post Apr 6 2016, 07:12 PM
Post #205
I realize that you guys have seen tons of hell hole repairs before. So if you are bored with this sitcom, don't watch. As I am new to 914s, and having never repaired this area...I am going to try to repair my car as true to the original construction process as possible, while strengthening this area. You have seen this before...Attached Image
Outer top of the longitudinal and obviously why it was kicked off the teamAttached Image
The inner reinforcement which I was considering reusing. However, it is swiss cheese currently. I could weld up the holes and extend a patch to replace the forward rusted area....but how much of its original reinforcement quality would remain?
Speedo
post Apr 6 2016, 07:35 PM
Post #206
I made a buck to help shape the innerAttached Image Attached Image
Fitted and trimmed but notice I had to trim the outer long lower to be able to attach the inner reinforcement. This will get spot welded/rossetted to the outer patch.
I used the RD outer long as a template for the patch
This is a PIA but it will be stronger in the long runAttached Image
Speedo
post Apr 6 2016, 07:45 PM
Post #207
Continuing with the outer patchAttached Image
Fitting the inner...which has to be exact so the outer lays snugly over the innerAttached Image
Trimmed Attached Image
The inner needs to be carefully positioned so that when the outer patch is laid over it, the rosettes can be easily welded in creating the strength necessary. Yes it would have been easier to splice in the top of the RD repro piece and be done with it. Cleaned out the long and primed it for welding. I cannot shape and trim the outer patch till the inner is welded and finished. My pressure relief valve on my compressor crapped itself....today. Otherwise I would have been welding.
porschetub
post Apr 7 2016, 12:42 AM
Post #208
No one is bored speedo,having seen you carve up rotten 911's on the bird,what you are doing is same shit different car really.
Good work following with interest (IMG:style_emoticons/default/beerchug.gif)
Cairo94507
post Apr 7 2016, 06:42 AM
Post #209
Michael
I love these restoration threads. Talk about seeing behind the curtain to what makes our cars the wonders they are. The talent we all see here and other build threads is very impressive. (IMG:style_emoticons/default/smilie_pokal.gif)
Luke M
post Apr 7 2016, 06:51 AM
Post #210
Hi Lars,
The repair looks good. The problem with the RD part (which is actually a AA part) is that it's missing the smooth outer sheet metal. I was told it's just a cosmetic piece that could be added by the end user.
When that replacement part was designed it was made in a thicker gauge metal so there was no need for the outer sheet metal. Obviously anyone could tell that there was a repair done if it was left as is. RD was nice enough to offer building me an outer shell but I decided to look for an NOS replacement part.
I did locate a new NOS right long but it's currently not for sale.
So my backup plan is to buy a good or at least better section from a parts car.
Keep up the good work ... (IMG:style_emoticons/default/beerchug.gif)
Speedo
post Apr 11 2016, 07:09 PM
Post #211
Inner reinforcement is done and trimmed...feels pretty solid. I used a sleeve on both ends.Attached Image Attached Image
Which should add even more rigidity to the repaired area. Clecoes to align and rosettes to secure Attached ImageAttached Image
And secured and trimmed. I am pleased with how this inner panel turned out. It will
provide a great form for fitting the outside longitudinal repair. Attached Image
Speedo
post Apr 11 2016, 07:29 PM
Post #212
I now need to finish the outer patch to the longitudinal. My original piece fabricated using the RD 14 gauge "all in one" wasn't as close as I wanted...it ended up being short. I didn't have a way to fit the RD piece in that area to determine the fit, without cutting it up...so I went on faith. Here is the fit of my piece.Attached Image
And here is how short the fabricated piece is, fitting tight to the wheel housing wallAttached Image
No big deal, I added an extension. Preliminary fitmentAttached Image
Massaged a bit Attached Image
And starting to roll the edges to mimic the original contour of the factory outer longitudinalAttached Image
Once trimmed this will get buttoned up and I will be able to address the battery support and tray
brant
post Apr 12 2016, 07:13 AM
Post #213
Great work.
Speedo
post Apr 15 2016, 07:37 PM
Post #214
I'm about to close up the hellhole. I have a new pedestal and battery tray (thanks Ferg) and am wondering about positioning both on the repaired longitudinal. Are there any measurements I need to be concerned with?
Speedo
Speedo
post Apr 15 2016, 08:09 PM
Post #215
Looking forward to not working in the engine compartment. This longitudinal repair is going to be robust. I have not considered welding in the plate reinforcement kit for the car for a couple reasons...1) it is a real six, 2) it will be driven but not tracked, and 3) it will not receive a monster engine. Comments are welcome.
Wanted the outer long cap to fit tight. So I need to trim and massage it.Attached Image
I want it to look clean (recognizing it is buried in the engine compartment and pretty much obscured by the battery tray) so everything needs to be close tolerance. Attached Image
Fit, positioned and drilled for rosettes.
This is a long ways from what I started with...much different than the replacement one piece RD partAttached Image
Speedo
post Apr 15 2016, 08:20 PM
Post #216
A little bit more fitting is required. Comparison to the RD repro...Attached Image
Not to dis RDs repro parts as they are what I consider to be the best repro parts out there...but they still are not perfect. My cap on the long is particular to my car which was built "sort of" by hand in the factory 46 years ago.Attached Image
The assistant Attached Image
Cairo94507
post Apr 15 2016, 09:43 PM
Post #217
Michael
Terrific job. I appreciate the effort you are putting in, especially since it is a Six.
I added the inner Engman kit in my Six just because I know these cars can flex. I also am putting a 3.2 in mine and though I will not be racing the car, I know the 3.2 has double the HP and torque of the stock 2.0. I figured it goes on the inside and will be invisible when finished. Shhhhhh....don't tell anyone it is installed.
Speedo
post Apr 17 2016, 07:42 PM
Post #218
I continue to look at other longitudinal repair threads. People are all over the spectrum with how the repair is approached. I am very comfortable with my repair.
Replacing the inner sleeve...as well as "sleeving" the patch makes sense for me.
New vs oldAttached Image
No reason not to make this permanent Attached Image
I am challenged with weather at this point...don't like to weld in a closed environment. But the garage door opened is about 29 degrees because of this...Attached Image Attached Image Attached Image
Speedo
post Apr 17 2016, 07:59 PM
Post #219
I will weld this in this afternoon...if I can open the garage door, but I need to accomplish a small repair to keep the juices flowing. Battery support was replaced at one point...and not very well. Here is my support and tray... Attached Image Not the best of shapeAttached Image
Part of the problem is the previous repair and part of the problem is what was needed to remove the stand from the weakened longitudinal. Attached Image Attached Image
I removed the support from the tray Attached Image
It wasn't in great shape.
Speedo
post Apr 17 2016, 08:33 PM
Post #220
So with the stand removed from the tray....there were some areas that needed attention. This needs to be repaired...Attached Image
And this Attached Image Attached Image
Made some repairsAttached Image
And reshaping Attached Image
- Lo-Fi Version Time is now: 24th November 2024 - 05:18 PM
