33 Pages V « < 27 28 29 30 31 > »
> Fix a six, Like Neil Young says...rust is an insomniac
Speedo
post May 30 2021, 05:11 PM
Post #561
Also I was preparing to install the tail light housings and couldn't remember where my wiring notes ended up. The L and R turns are obvious, but need to figure out what goes to 54, 58, RF and 31. Obviously running lights, brake lights, back up and ground. If someone has those handy that would help. (IMG:style_emoticons/default/rolleyes.gif)
Speedo
post Jun 20 2021, 05:44 PM
Post #562
Big day...got my lift back (IMG:style_emoticons/default/biggrin.gif)
Son came home for two weeks to push through the post-paint re-assembly of his 72 1.7 yellow beast. Had to spend some time going back and forth to the painter to get it right. Done except for the interior. Very nice.
Speedo
post Jun 20 2021, 05:46 PM
Post #563
This changes everything. No more crawling under the dolly. My knees are thankful.Attached Image
Speedo
post Jun 20 2021, 05:48 PM
Post #564
Almost...
Speedo
post Jun 20 2021, 05:49 PM
Post #565
Liftoff...
Speedo
post Jun 20 2021, 05:51 PM
Post #566
Time to finish up the suspension and send my wheels off to Al Reed.Attached Image
Speedo
post Jul 3 2021, 05:15 PM
Post #567
Started cleaning up my oil tank...bad decision. What looked solid covered in road grime wasn't. Small perforations along the top seam where the rear wheels picked up debris and deposited it there. It held moisture which over time ate through the copper and then the steel. As the perforations were along the top edge, it suffered no obvious leaks. Rest of the tank is very solid so I am going to repair this one. No sense in mig welding it, and as it is not structural, I think I can get by with brazing it. Pretty small holes. Once brazed it will get completely wire brushed and sealed. Before...
Speedo
post Jul 12 2021, 06:06 PM
Post #568
During...
So the brazing went well and the tank was wire brushed and etched. It looks pretty sketchy at this point...completely de-nuded
Speedo
post Jul 12 2021, 06:08 PM
Post #569
And after...
Treated to a couple liberal coats of POR 15 and it looks much better.Attached Image
Speedo
post Jul 13 2021, 06:51 AM
Post #570
Working away on the front suspension. Something very satisfying about bolting up fresh parts. Slight dilemma with my bump steer modification...upper two U-joints were binding.
Figured out where the binding was happening, and removed about an 1/8th on the washer and binding disappeared so everything got tightened back up.
Speedo
post Aug 5 2021, 06:05 PM
Post #571
Could this be the correct mirror for my 6? Wasn't where it was supposed to be...but it is long and narrow with the correct base.
post Aug 5 2021, 07:34 PM
Post #572
914-6 GT in waiting
QUOTE(Speedo @ Aug 5 2021, 08:05 PM) *
Looks correct to me.
Root_Werks
post Aug 6 2021, 03:12 PM
Post #573
Village Idiot
Having a lift is a game changer. My last shop had one and I used it often. Looking great!
Cairo94507
post Aug 6 2021, 03:18 PM
Post #574
Michael
That is definitely the correct mirror for your Six. (IMG:style_emoticons/default/beerchug.gif)
Speedo
post Aug 14 2021, 06:09 PM
Post #575
Suspension and brakes
Speedo
post Aug 14 2021, 06:10 PM
Post #576
These front brakes are monsters
Speedo
post Aug 14 2021, 06:14 PM
Post #577
Rears are done except for dust shields and e-brakes. New coil overs and hardware. PET does not show where the bracket that supports the front of the rear brake dust shield goes. Is it under the head of the bolt and lock washer?
Speedo
post Aug 14 2021, 06:15 PM
Post #578
And the frosting on the cake...
Speedo
post Aug 14 2021, 06:17 PM
Post #579
Waiting for the tires to arrive and get mounted...then I will have a roller after many years.
Oil tank install tomorrow... (IMG:style_emoticons/default/smile.gif)
KELTY360
post Aug 14 2021, 06:25 PM
Post #580
914 Neferati
Oh man! You show the box and not the goodies? Guess I’ll have to be in suspense til the next edition. Love following this build.
- Lo-Fi Version Time is now: 24th November 2024 - 01:53 PM
