39 Pages V < 1 2 3 4 > »
> '73 Resto & Suby 6 Conversion, or a primer on "How to convert your 914 to a Subaru 3.0"
76-914
post Jan 20 2013, 11:40 AM
Post #21
QUOTE(Jeffs9146 @ Jan 19 2013, 07:35 PM) *
OK this is the first time I have seen this thread and I have to say it........don't climb under the car on those jack stands!! (IMG:style_emoticons/default/blink.gif)
This is a must read! Jack Stands
Yea, I read that. Did you read this? http://www.914world.com/bbs2/index.php?sho...=139114&hl= Besides these jacks stands, fully collapsed, are 19.5" which would allow for me and a most of my tools. (IMG:style_emoticons/default/biggrin.gif) Thanks for looking out for me though. (IMG:style_emoticons/default/beerchug.gif)
post Jan 20 2013, 10:05 PM
Post #22
I got around to welding on the r&l long stiffners before I ran out of wire. First thing was to get it supported on the killer jack stands. These were perfect because I wasn't under the car and they are low enough that I can get my ancient ass in & out when welding.
Next was to level it. I used the bubble and the electronic app. Both work great.
I then marked 3 spots on each door and measured the gaps before I began welding onto the longs.
post Jan 20 2013, 10:06 PM
Post #23
When I was banging around bracing the panels with 2 x's I knocked the big urethane floorboard piece loose. I was going to work around it if possible just to preserve that OG floor so this is a plus.
A little more scraping with the razor. mineral spirits to remove the old glue and remaining tar and this too will be clean in 20 min's.
Talk about Engman Quality. Look at the fit between the rear and left piece.
Same view but tacked up
FourBlades
post Jan 20 2013, 10:10 PM
Post #24
From Wreck to Rockin
Nice work man! (IMG:style_emoticons/default/piratenanner.gif)
John
post Jan 20 2013, 10:23 PM
Post #25
Here is another view of the same corner but with the top of the corner piece now formed to meet the rounded corner.
A close up of that "formed" piece. Me thinks beat to death is more appropriate.
And this is where I'm at until I get by the welding shop and restock my .023.
That bottom right hole that is blown wasn't cleaned (IMG:style_emoticons/default/headbang.gif) so I'll move left 3mm and tack it in the seam where it is clean.
post Jan 22 2013, 09:01 PM
Post #26
I finally finished the welding of the Engman kit. I didn't purty it up for these pic's. I still need to grind down a few welds, vacuum and prime the bare spots. It looks like Hell now but a little Wurth's and some paint will clean it up. I'm glad that I ran out of the .023 because I also bought some .030 and had much better results on the longs w/ the .030. Faster = less heat. Doors shut just as sweet as before. It's back on the ground. Into the Hell Hole and on to the firewall patch next. I need to clean up some p/o welds around the hinges and battery tray. I think they attempted arc welding. Looks like a mud dabbers nest. (IMG:style_emoticons/default/lol-2.gif) I guess I had better start thinking cooling while I'm in the cut n patch mode. (IMG:style_emoticons/default/idea.gif)
post Jan 24 2013, 10:13 PM
Post #27
and
jimkelly
post Jan 25 2013, 03:52 AM
Post #28
Delaware USA
fantastic pics (IMG:style_emoticons/default/aktion035.gif)
do you plan to seam seal the entire perimeter and perferations? (IMG:style_emoticons/default/popcorn[1].gif)
post Jan 25 2013, 01:24 PM
Post #29
Thx Jim, and yes I have some Wurth's seam sealer that will go on before I paint it.
post Jan 25 2013, 01:51 PM
Post #30
Just got off the phone after discussing metal shrinkage with Ceasar (phatt911) and realized that this might be of some use to those considering a stiffner kit. As shown in an earlier pic, I measured the door gap at 3 equidistant locations on both doors prior to any welding on the long portions. I did NOT brace the door but did this instead. After leveling (and that is a trick) the car I would weld 3 spots (front, middle and rear to keep the weld spots spread out) on one side and then move to the other side and repeat. Never welding any area unless the metal was cool enough to place my dinkus upon. If additional time was needed I would do some grinding instead. After 6 or 8 welds on each side I would check the door gaps again. I welded all of the vertical spots (or sides) before doing the tops. The shrinkage that I experienced was .37mm after welding the sides. After welding the top portions the shrinkage increased to 1mm nominally. Or .63mm. Amazing! Half the area and half as many holes as the sides, yet twice the shrinkage. I had suspected this might be the case and had therefor left the top on during construction just in case. I think that bracing the door is the more prudent action but I like to test the water for myself from time to time and these are my results. Disclaimer: Your results will probably vary. (IMG:style_emoticons/default/smoke.gif)
andys
post Jan 25 2013, 02:04 PM
Post #31
Here are my before and after dimensions. Red is after, units are in inches. The lower parts of the door gap didn't change much, so I omitted those.
Andys
post Jan 25 2013, 05:40 PM
Post #32
Similar results. Within .01" (.027mm) +/- of each other. (IMG:style_emoticons/default/beerchug.gif)
eric9144
post Jan 25 2013, 06:01 PM
Post #33
(IMG:style_emoticons/default/popcorn[1].gif) This should make the Dawn Patrols more interesting, now we're all going to have "stiffy" envy (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/av-943.gif)
Chris H.
post Jan 26 2013, 07:28 AM
Post #34
Top notch details on the Engman install. Thanks a lot for posting.
post Jan 26 2013, 07:01 PM
Post #35
So I started with the firewall patch/repair today. Here is the psg side before cutting.
and this was the drv side
some beginning cuts removing just the rust areas and then enlarging the cuts in preparation for final trimming.
Post #36
lfjuysblfc
stateofidleness
post Jan 27 2013, 12:33 AM
Post #37
*subscribed*
in the same boat. i'll take all the knowledge i can get! (never touched a welder before.. got one for christmas. this'll be my first "small" project with it)
post Feb 1 2013, 06:10 PM
Post #38
So while I wait for the "correct" size of steel to patch the firewall I thought I would clean up the engine compartment and see if I could find anymore rust. There is a bunch of the old mat stuck to it..........
And this looks a little suspicious. Rivets and a rough finish on the panel.
Then there is the matter of this booger by the PO.
So I drill out the rivets and look what I find. Has anyone seen these before. Obviously stamped steel so mfg'd by someone.
Once they're out this is all that was left of the tray. The pedestal was in good shape but I doubt I will relo a batt here.
Couple of pic's while getting cleaned. These holes need to be welded up
And a small patch here
One booger mostly ground down
Post #39
%90 clean. A little more here and there then patch n prime. The side wall behind the batt cleaned up pretty good, too. A little pitted so it will be treated to a phospho shower.
The rest has cleaned up quite well.
post Feb 3 2013, 06:15 PM
Post #40
So I need to fill some holes where the batt tray was riveted to the panel. If you look closely you can see the copper spoon thru the holes.
and now they're ground down and gone
a shot of primer to ward off the rust gods
Here is another spot that needs to be filled. Oops, (IMG:style_emoticons/default/chair.gif) I need to re-size these pic's and continue in the next post.
- Lo-Fi Version Time is now: 2nd April 2025 - 02:07 AM
