41 Pages V « < 4 5 6 7 8 > »
> 914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS
Curbandgutter
post Jun 27 2016, 09:41 PM
Post #101
I see what you mean but just think how much better this car will be than stock. Or even those that only are able to reinforce the longs. I think I'll be all right.
Andyrew
post Jun 28 2016, 08:15 AM
Post #102
Spooling.... Please wait
So your not planning on gutting the chassis and putting this tube frame under it? Because that what it sounded like.
Curbandgutter
post Jun 28 2016, 01:34 PM
Post #103
No I'm not gutting the entire chassis but I am removing quite a bit from the rear. It will not have the rear strut towers, transmission mounts, engine support, rear suspension attachment points, rear lower trunk sheet metal and engine sheet metal wrap around.
Curbandgutter
post Jul 9 2016, 08:14 AM
Post #104
Well I've had to take a break to prepare for my son's wedding. I've taken little windows of time and worked on the chassis table thoug. It's almost complete just need to add the webs for the trusses and it's ready to mount the 996 on it first. I'm going to compile xyz coordinates for all of the suspension pick up points on the 996 and then transfer those coordinates onto the 914. That way I will keep the same suspension geometry that the factory had. I'll also be doing a twist test on the 996 and on the 914 pre-tube chassis and post tube-chassis. It will be interesting to note how much better the 914 chassis will be. I'll be taking all of the measurements with a laser plummet and a laser distance measure....stay tuned.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
jd74914
post Jul 10 2016, 03:53 PM
Post #105
Its alive
QUOTE(Curbandgutter @ Jul 9 2016, 09:14 AM) *
Sweet table! Very very nice! (IMG:style_emoticons/default/drooley.gif) You work fast!
I've always wanted twist measurements; they should be really interesting. I've built solid "shocks" and twisted some formula cars. It's relatively easy to do and really neat to see how the results compare to FEA expectations. Unfortunately, our FEA was always a bit optimistic because it didn't include finite stiffnesses for all of the suspension joints.
It would be really interesting if you could twist it a few times after the tube frame with and without the engine, belly pan, etc. just to see how much incremental stiffness each piece adds.
csdilligaf
post Jul 11 2016, 10:30 AM
Post #106
Looks like your moving along well. I did a 914 with 993 suspension a long time ago with an LS6 and G50-52. I had the rotisserie and set up and a welding table For the suspension set up. With no room to store the stuff I got rid of it and now I have a new 914 project starting and was planning on making all the stuff again. As you know it is a huge investment and a lot of work. How about right after you get your chassis set up and of the table you do mine and recover some of the money you have in all this effort? I am just down the road in San Diego. Also here is another thread that you may have seen but its always good to see what others have going and see how they went about things.
http://www.914world.com/bbs2/index.php?sho...219539&st=0
Looking good so far and I will be following the progress. And here is a shot of my 914Attached Image
Curbandgutter
post Jul 11 2016, 12:39 PM
Post #107
CSDIILIGAF hey that 914 you did with the 993 suspension looks killer. Let's talk about using my rotisserie and frame table. I'm thinking that I can just rent it out to you for an extended period of time. That way your cost will be a fraction of the cost to make and I get a little back for my investment. PM me and give me your contact information I'm sure I can learn from someone who's done it already. Glad to have you commenting.
Curbandgutter
post Jul 11 2016, 12:43 PM
Post #108
JD74914 Instead of using the solid shock idea, which is a cool idea by the way, I was thinking of just setting the car up on 3 jack stands on the frame table, clamping them down and loading the wheel that doesn't have the jack stand under it. What do you think? Is there a better way? And yes I would like to test the twist under various conditions. We're just going to geek out and have fun with the numbers as well as the final product. (IMG:style_emoticons/default/biggrin.gif)
Curbandgutter
post Jul 12 2016, 10:17 AM
Post #109
Does anyone have a good idea as to how to set up a jackstand with some form of a clamp to attach to bottom of longs? Taking all good suggestions. Bad ones (IMG:style_emoticons/default/screwy.gif) will be ridiculed (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) . Just kidding of course but yeah let me know how you'v e done it or saw someone else do it. BTW no Mo-Clamps those are North of $200 each.
Curbandgutter
post Jul 12 2016, 11:32 AM
Post #110
I'm thinking of welding these to the end of a 2x2 post and using them instead of a jack stand. They are cheap and will do the job.
914forme
post Jul 12 2016, 11:38 AM
Post #111
Weld a block of steel on one side, and tap for 2 3/8" bolts, add another on the others side and pinch the seem. Add knurling if you want between the jaws. Stands will need to be able to move as this design is not self centering.
Our weld C clamps to the to of the jack stands.
Or weld a set of nuts to steel plates, weld steel plates under the rockers, bolt them to the fixture and grind them off once done.
Put wooden blocks under the rockers, drill holes through the rockers , wooden blocks, and fixture, use all thread, bolt it down.
I am guessing this is to do twist testing.
I would weld three legs down, and not use jack stands, as you will have to strap the car down anyways
Use weldable trailer rings onto the logs, put what ever you want under it, ratchet it down with welded rings on your fixture.
Trailer rings can be found that are rated for 18,000 of force per ring, and cost about 12.50 per ring plus shipping. Then some big straps, or chain. Or just load binders.
914forme
post Jul 12 2016, 11:41 AM
Post #112
QUOTE(Curbandgutter @ Jul 12 2016, 01:32 PM) *
Cast, thinking they will break at the bolt hole as you apply force diagonally to them.
Curbandgutter
post Jul 12 2016, 12:23 PM
Post #113
914FORME I like your idea about the trailer rings. Yes that will be necessary to be able to hold the car down for the twist test. I'm going to hold down into concrete with a wedge anchor. I do believe that the clamps that I have are rated for 750lbs. I'm going to give them a shot and see what happens.
Curbandgutter
post Jul 13 2016, 10:41 AM
Post #114
Well look at what came it today. The parts look to be first rate. Everything is USA made with the exception of a wand piece that is made in Germany. The company told me that they stand by their product and that if I'm not happy with the results that they will take it back. We will see. Supposedly they were able to do 1 sf per 1 min and 15 secs. Not bad at all.
Curbandgutter
post Jul 17 2016, 07:02 PM
Post #115
Well chassis table is complete. I measured it with a survey grade level and it is straight to 1/64th or 15 thousands of an inch. Now I can start about with actually working on the 914 rather than building all of the infrastructure (Rotisserie, Chassis Table, Sand Blast Cabinet). I guess I could have done it on the concrete floor and then have a twisted frame. But I couldn't live with myself. Rather, I'm doing it this way though because I just can't do this not knowing if my work is straight. However I have 3 weddings to attend in the next 2 months so my weekends are going to be used up in nonsense (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) cause you know where I would rather be.
The order of work will be as follows.
First load 996 and measure and do a twist test.
second wet sand blast 914 on rotisserie
repair rust and epoxy primer
fourth put 914 on chassis table and do baseline twist test then start building tube chassis
mbseto
post Jul 18 2016, 09:17 AM
Post #116
Wow. That's a sweet piece of work.
Curbandgutter
post Jul 19 2016, 11:35 PM
Post #117
Thanks bud.
jd74914
post Jul 20 2016, 06:35 AM
Post #118
Its alive
QUOTE(Curbandgutter @ Jul 11 2016, 01:43 PM) *
It all depends on what you want to get out of it.
The clamping jack stands sound like a good idea you're most concerned with seeing changes in chassis stiffness and comparing to your FEA model. It's certainly easier than making solid shocks and hub adapters to clamp to the table and would produce really interesting data. I would love to see how close the FEA comes to actual!
On the other hand, it doesn't give you a great feeling on the stiffness of the whole system. I like to think of the chassis as a huge bracket which holds the suspension together; basically something that connects the dots. The most important reason to have a stiff chassis (besides impact safety which is a whole other design arena) is to remove an additional "spring" from your suspension. A flexy chassis can make suspension tuning difficult since it is sometimes tough to tune around that unknown spring. I did hub connections for my twist tests because I wanted hub-to-hub stiffness to understand the whole system. There can be a shocking amount of compliance in suspension mounts and components which you will miss if just doing a pure chassis twist. I have read that OEMs spend millions of dollars making sure mounting compliance is minimizes which is something the normal person isn't able to do.
Since you're keeping the stock suspension measurements, perhaps making hub adapters which bolt to the table wouldn't be so bad since you could use them multiple times and on both chassis? Just thinking out loud. I really do like the clamping jack idea too, the above were jut things to think about. (IMG:style_emoticons/default/smile.gif)
QUOTE(Curbandgutter @ Jul 12 2016, 12:32 PM) *
Those should do the trick! They can hold a stupid amount on i-beams so I don't see why they wouldn't work on a flange.
jd74914
Post #119
Its alive
Your table is awesome BTW! I'm super jealous!
Curbandgutter
post Jul 20 2016, 01:42 PM
Post #120
JD74914 your responses are always so on the spot and I really do appreciate them. It is what makes these forums. With respect to the twist test incorporating the compliance in the bushings, tie rods, etc., I agree wholeheartedly. However, what I am trying to do is to get a chassis stiffness so that I know how to set up the springs. My current 996 suspension needs new bushings and ball joints, so checking it in this fashion will be counterproductive for my purposes. As you may already know, a rule of thumb is that if your suspension stiffness is more than 10% of the chassis stiffness, then a portion of the chassis will be flexing and absorbing the loads instead of it going into the springs and dampeners. This condition will give a horrible ride and will cause premature cracks in the chassis. I suspect that this happens quite often when people put a really stiff spring on a stock 914 chassis. As would be my case if I just used the springs off of a car that weighs 3274 lbs and placed them in a car that weighs 2100 lbs.
The chassis torsional stiffness that I will check will be:
1) The baseline existing 914;
2) The 914 with the longs stiffened;
3) The 914 with the steel roll cage;
4) The 996 in stock form (oh oh).
My intent is to help other teener's so that they can see if stiffening the longs truly works. And if so, how well? It will be very interesting to me and to others, I suspect.
I've been reading that a typical torsional stiffness for a sports car is somewhere between 10000 and 20000 ft-lbs/degree. Also, F1 cars are much higher than 20,000 ft-lbs/degree.
I hope to load the 996 on the chassis table this weekend. Them I'm off camping to Sequoia so I won't be updating for about one week.
BTW I really did like the way the chassis table turned out. It's nice to know that what you are basing everything off of is straight and true. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 19th April 2025 - 07:47 AM
