siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,458 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
siverson |
siverson |
siverson |
914
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,925 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Nice! There moving right along! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,559 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
I think it's safe to say they are all rusted out in the battery box area. The more Scotty cleaned in mine, the more he found...and my car is a damn solid car (in 914 terms).
Good work getting it fixed when you see it! |
siverson |
From May 1977 when he was still Irish Green... But has the 15" Fuchs that it still has today - originally had steelies.
-Steve Attached thumbnail(s) ![]() |
trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Man that looks great! What are you going to tackle next?
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,788 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Me and My Six 1979, Irish green all the way (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) ![]() |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Best Color Ever. (IMG:style_emoticons/default/aktion035.gif)
siverson |
The car is running and drivetrain-wise is pretty solid now. The plan is to put a couple hundred miles on it to work out all the kinks, and then take the rest of it apart for a full repaint (leaving the engine in). And that time I'll also refurbish the suspension, brakes, gas tank, new carpet, etc and then have a pretty nice little six! -Steve |
siverson |
I haven't seen this before. Maybe it's just early car vs late car, but the thin sound padding on the firewall was sprayed/melted on. On all the later cars I've seen this is just a sheet the peels (usually falls) off.
siverson |
The wires were embedded in it a bit...
-Steve ![]() ![]() |
siverson |
Why you should fix a loose rear window... Especially if you live in Portland.
-Steve Attached image(s) ![]() |
siverson |
When I started to pull up all the tar. Note there are no "carpet hold downs" on the main floor board. They aren't on either side, but the factory tar is still everywhere.
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,841 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
siverson |
> what your showing in the pic should just peel off.
I agree, it "should", but something happened to this one. It was glued/melted on to the the firewall, and also onto the backpad. It did come out eventually though. -Steve |
rick 918-S |
That's weird about the carpet holders....
sixnotfour |
my six has no carpet holders and factory carpet has no holes. 0390
siverson |
Well that's news to me. I'll leave it as-is. (IMG:style_emoticons/default/smile.gif) -Steve |
Lo-Fi Version | Time is now: 18th April 2025 - 04:41 AM |
