16 Pages V  1 2 3 > »
> PIX, Pix Of Enlightenment
veekry9
post Oct 15 2013, 07:37 PM
OldMember
Group: Retired Members
1978 RT overhead
HotRod Hessian
Spyder
His later model,Imperator.
Top View
WankelPower
What to do in Sweden.Building flat eights,a great idea.
Driveby V8,MB powered.
OneMillionHeartBeats
Can'tBeDone?
DifficultToDo
McMark
post Oct 15 2013, 07:43 PM
914 Freak!
More of the 8-cyl Type IV
post Oct 15 2013, 08:00 PM
Resident German
QUOTE(McMark @ Oct 15 2013, 06:43 PM) *
(IMG:style_emoticons/default/cheer.gif)
boxsterfan
post Oct 15 2013, 08:19 PM
914's are kewl
(IMG:style_emoticons/default/chowtime.gif)
carr914
post Oct 15 2013, 08:23 PM
Racer from Birth
QUOTE(McMark @ Oct 15 2013, 09:43 PM) *
But why Carbs vs MFI or Slide-Valve Injection?
McMark
post Oct 15 2013, 08:25 PM
914 Freak!
Those aren't carbs. They're ITB fuel injection.
Chris H.
post Oct 15 2013, 08:29 PM
Mark you could turbo the sh!t out of that.
McMark
post Oct 15 2013, 08:31 PM
914 Freak!
(IMG:style_emoticons/default/happy11.gif)
veekry9
post Oct 15 2013, 08:38 PM
OldMember
What Lind accomplished hadn't been attempted here in North America.
No doubt the same vibration characteristics were present as Porsche's version.
A masterpiece in ingenuity and fortitude to complete.He speaks Porsche very well.
(Edit:08/18/16):
https://www.youtube.com/watch?v=OZWeNPi2XkE
http://www.enginebuildermag.com/2016/01/ko...ft-free-engine/
http://jalopnik.com/what-its-like-to-ride-...gine-1529865968
(IMG:style_emoticons/default/rolleyes.gif)
Some kind of wonderful.
Opens up a whole new life for piston engines,so very programmable.
Kudos.
post Oct 16 2013, 01:37 AM
Resident German
QUOTE(veekry9 @ Oct 15 2013, 07:38 PM) *
Actually, if you do some reading, that is the very reason why Porsche went to a center driven cooling fan that ran off a 90 degree angle drive on their flat /8 racing engines.
It is quite an eye opener to read about their vibration issues with the long crank and how they went about solving those issues.
Dave_Darling
post Oct 16 2013, 09:58 AM
914 Idiot
I thought the firing order thing was how they finally solved the vibration problems in the 908 motors?
Some of the 908s, at least, used an upright fan that is very similar to the standard 911 one.
When they built the "912" engine (for the 917) they used a center take-off as the only option. The long crank twisted too much to have the take-off at the end.
--DD
bandjoey
post Oct 16 2013, 10:54 AM
bandjoey
Donor Motor for the Limo? (IMG:style_emoticons/default/biggrin.gif)
post Oct 16 2013, 11:19 AM
Resident German
QUOTE(Dave_Darling @ Oct 16 2013, 08:58 AM) *
I can't remember where i read that article, it was an interview with the guy who designed the 908 engine.
Old Pano maybe???
It's a really interesting read ...
veekry9
post Oct 17 2013, 02:22 PM
OldMember
So.
I recently took possession of two(2)2.7L(164") Corvair engines.
(IMG:http://www.914world.com/bbs2/style_emoticons/default/biggrin.gif)(IMG:http://www.914world.com/bbs2/style_emoticons/default/biggrin.gif)
I doubt it would be as simple as merely welding sawn,machined cases together,
(IMG:http://www.914world.com/bbs2/style_emoticons/default/smlove2.gif)
then,installing a custom crank and cam.The problem then becomes the cylinder heads.
Metal joining technology has come a long way since '65.
Look,if that guy out there in boonville Norway(er..corr Sweden) can do it,what,if only money,is stopping us(me)?
It is a matter of will.Luke,do or not do.
(IMG:http://www.914world.com/bbs2/style_emoticons/default/welder.gif)
(edit:08/14/16):
-------------------------------------------OOOOOOOOOOOOOOOOOOOOOOOOO-----------------------------------------------------
http://www.alfabb.com/bb/forums/boxer-engi...-8-project.html
Hmmm..Seems the flat eight affliction is not confined to Porsche enthusiasts,it's catching.
(Edit:08/17/16):
The context,an answer to a question posed to 'engine dorks' about crankenrods.
HD
You could use a knife and fork rod set,the pistons in line,radially.
The advantage of the 'boxer' design is the cancelling of the primary unbalance forces.
Pointers:
https://www.google.ca/webhp?sourceid=chrome...a%20boxer%20six
https://www.google.ca/webhp?sourceid=chrome...boxer+animation
https://www.google.ca/webhp?sourceid=chrome...nd%20g%20forces
The crankshaft is connected to the wristpin by the,'connecting rod',holding the piston,with the piston,or 'wrist' pin.
https://www.youtube.com/watch?v=l-KSsaH-3b0
Dorks,and Boffins,working at Porsche,MercedesBenz,Ferrari,and other manufacturers,for centuries.
You can join them here,bring a slide rule.
https://www.google.ca/webhp?sourceid=chrome...+degree+florida
11,768 m/s² 1200Gs - Deceleration of a woodpecker's head!
(IMG:style_emoticons/default/blink.gif)
'Boxer': Pistons move in opposite directions,a crankpin for each piston.
https://www.youtube.com/watch?v=j_g_K0nyGHQ
180* 'Flat' 12: Pistons move in same direction,sharing the same crankpin,like the V-12.
https://youtu.be/j_g_K0nyGHQ?t=23
https://www.youtube.com/watch?v=j3CkVwtOPX4
The 911 motor is a 'Boxer',the 917's motor (912) is not.
Because the length of the crank is greater with the boxer configuration.
https://www.youtube.com/watch?v=m3KdpzL3Hkk
https://www.youtube.com/watch?v=_o8E4WCC4F8
(IMG:style_emoticons/default/drooley.gif)
Need to know:
http://www.pattakon.com/
http://www.pattakon.com/pattakonEduc.htm
http://bestplay.pk/watch/V6PGO03K6cI
Like the Merlin V12 engine above,the 180* flat engine has 6 crankpins,just like the Boxer Six.
The crank is offset 3" to grind the 6" stroke crank,27L.
https://www.youtube.com/watch?v=xbZ9RD6BTMw
http://www.e31.net/engines_e.html
Technology Terminology,for to make communicate.Some,obviously,are not on the same page.
Needing a part,called a part store,"Do you sell 'whatchyamacallits',for my motor thingy?".
(IMG:style_emoticons/default/lol-2.gif)
The reason for the forked 'Connecting Rod',is performance,the reduction of engine weight.
The HD,and the RR,have their cylinders opposite each other,in the same plane.The greater complexity of manufacture was a calculated compromise.
The weight of the crankshaft was reduced,as the secondary unbalance forces were nulled by the inline cylinders,less vibration.
The shared crankpin of the 917 engine's side by side,'conrods',are the result,also,of a compromise in the cost of manufacture,and simplicity
The proposal for such forked rods,in the initial design stages of the 917 engine,was rejected,as their mass was unsuitable for the high rpm engine.
Two different applications,two different results,both of which excelled in their field.
https://www.google.ca/webhp?sourceid=chrome...iston%20engines
https://www.google.ca/webhp?sourceid=chrome...connecting+rods
http://www.practicalmachinist.com/vb/antiq...-merlin-306661/
http://www.craftsmanshipmuseum.com/Tomlinson.htm
http://www.speedwaymotors.com/Scat-932911-...troke,3181.html
https://rideapart.com/articles/birth-harley...on-v-twin-motor
RR Merlin crank.Forged,hollow,tubular and light.Sheffield.
http://bbs.homeshopmachinist.net/threads/4...ine-Restoration
http://www.practicalmachinist.com/vb/gener...ankshaft-73615/
The finish anvil below,one of _.
Looking to make a piston engine?
(IMG:style_emoticons/default/evilgrin.gif)
So,yeah,a flat 180-12 engine can have the cylinders inline,the boxer's must be offset.The offset distance is the thickness of the web,rod and journal,if any.
A method to circumvent the offset,with minimal complexity.:
Boxer Cranks
MercedesBenz auto V12
Bmw auto V12
Diamler Benz DB 605 V12 Crank
912 Shafts
https://www.google.ca/webhp?sourceid=chrome...+917+engine+fan
Twin Supra V12 crank,heavy man.
So,you were thinking of a flat 12 914.
http://www.enginelabs.com/engine-tech/cran...ght-crankshaft/
A passion for the 914,shared with others.
https://www.google.ca/webhp?sourceid=chrome...ahn&tbm=vid
http://forums.pelicanparts.com/porsche-911...-flat-12-a.html
http://gtspirit.com/2013/12/29/remarkable-...al-porsche-917/
911+911=flat12!
The freedom to do a build of your own,a personal vision,and version of your 914.
Mike Bellis
post Oct 17 2013, 06:56 PM
Resident Electrician
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.cdn.turner.com-10496-1382057818.1.jpg)
veekry9
post Oct 17 2013, 07:27 PM
OldMember
QUOTE(kg6dxn @ Oct 17 2013, 08:56 PM) *
Pie in the sky ramblings of malarky.
After the Cosmic Rain
The whatif of gearheads everywhere is what makes all of this wrenching so worthwhile.
Certainly,few of us here are motivated only by $$reward.Rather,we support the specialists out there.
They need the money,you need the 'stuff',
A MS Paint drawing from the '90s,to show the kids how to use the pc,called it 'Veloce'.
veekry9
post Oct 21 2013, 07:23 PM
OldMember
https://www.youtube.com/watch?v=D4IR6Ukv7gk
Isdera
Eberhard Shulz.
He started out as the Erator GTE builder and developed into a wonderful designer.I even like his first off.
There's a youtube of it being thrashed through the black forest.
A showcase of the builders dream realized.A successful talent in auto design.
https://www.youtube.com/watch?v=dr7dnobhDFI
Midengined straight-6 or V8 sports type.
Oh Yeah,
Made the cover of Road+Track.
Then Years later,tested at speed by Paul Frere,
176MPH=Stable,Tight.(Yes:176mph).As timed by R+T.
https://www.youtube.com/watch?v=TOeTKlCPOss
sixnotfour
post Oct 21 2013, 07:43 PM
QUOTE(veekry9 @ Oct 17 2013, 01:22 PM) *
So.
I recently took possesion of two(2)
merely welding sawn cases together,
then installing a custom crank
and cam.Then the problem becomes the cylinder head.
Look,if that guy out there in boonville norway can do it,
what,if only money,is stopping us?(me)
Luke,do or not do.(IMG:http://www.914world.com/bbs2/style_emoticons/default/welder.gif)
Why on earth would you bother with a push rod engine ?? (IMG:style_emoticons/default/confused24.gif)
Mike Bellis
post Oct 21 2013, 07:49 PM
Hmmmmm?!?!?!? (IMG:style_emoticons/default/blink.gif)
veekry9
post Oct 21 2013, 08:13 PM
OldMember
QUOTE(kg6dxn @ Oct 21 2013, 09:49 PM) *
Velly interestink.
I presume the 'trunk'is in the middle,or perhaps the fuel tank has been relocated to the vacant engine bay.
For lack of a better description a VW-914-T1-4.For those whose inclinations are bug-love.Does it work?
Sure.
- Lo-Fi Version Time is now: 3rd April 2025 - 08:12 PM
