16 Pages V < 1 2 3 > »
> PIX, Pix Of Enlightenment
bandjoey
post Oct 16 2013, 10:54 AM
bandjoey
Donor Motor for the Limo? (IMG:style_emoticons/default/biggrin.gif)
post Oct 16 2013, 11:19 AM
Resident German
QUOTE(Dave_Darling @ Oct 16 2013, 08:58 AM) *
I thought the firing order thing was how they finally solved the vibration problems in the 908 motors?
Some of the 908s, at least, used an upright fan that is very similar to the standard 911 one.
I can't remember where i read that article, it was an interview with the guy who designed the 908 engine.
Old Pano maybe???
It's a really interesting read ...
veekry9
post Oct 17 2013, 02:22 PM
OldMember
Group: Retired Members
So.
I recently took possession of two(2)2.7L(164") Corvair engines.
(IMG:http://www.914world.com/bbs2/style_emoticons/default/biggrin.gif)(IMG:http://www.914world.com/bbs2/style_emoticons/default/biggrin.gif)
I doubt it would be as simple as merely welding sawn,machined cases together,
(IMG:http://www.914world.com/bbs2/style_emoticons/default/smlove2.gif)
then,installing a custom crank and cam.The problem then becomes the cylinder heads.
Metal joining technology has come a long way since '65.
Look,if that guy out there in boonville Norway(er..corr Sweden) can do it,what,if only money,is stopping us(me)?
It is a matter of will.Luke,do or not do.
(IMG:http://www.914world.com/bbs2/style_emoticons/default/welder.gif)
(edit:08/14/16):
-------------------------------------------OOOOOOOOOOOOOOOOOOOOOOOOO-----------------------------------------------------
http://www.alfabb.com/bb/forums/boxer-engi...-8-project.html
Hmmm..Seems the flat eight affliction is not confined to Porsche enthusiasts,it's catching.
(Edit:08/17/16):
The context,an answer to a question posed to 'engine dorks' about crankenrods.
HD
You could use a knife and fork rod set,the pistons in line,radially.
The advantage of the 'boxer' design is the cancelling of the primary unbalance forces.
Pointers:
https://www.google.ca/webhp?sourceid=chrome...a%20boxer%20six
https://www.google.ca/webhp?sourceid=chrome...boxer+animation
https://www.google.ca/webhp?sourceid=chrome...nd%20g%20forces
The crankshaft is connected to the wristpin by the,'connecting rod',holding the piston,with the piston,or 'wrist' pin.
https://www.youtube.com/watch?v=l-KSsaH-3b0
Dorks,and Boffins,working at Porsche,MercedesBenz,Ferrari,and other manufacturers,for centuries.
You can join them here,bring a slide rule.
https://www.google.ca/webhp?sourceid=chrome...+degree+florida
11,768 m/s² 1200Gs - Deceleration of a woodpecker's head!
(IMG:style_emoticons/default/blink.gif)
'Boxer': Pistons move in opposite directions,a crankpin for each piston.
https://www.youtube.com/watch?v=j_g_K0nyGHQ
180* 'Flat' 12: Pistons move in same direction,sharing the same crankpin,like the V-12.
https://youtu.be/j_g_K0nyGHQ?t=23
https://www.youtube.com/watch?v=j3CkVwtOPX4
The 911 motor is a 'Boxer',the 917's motor (912) is not.
Because the length of the crank is greater with the boxer configuration.
https://www.youtube.com/watch?v=m3KdpzL3Hkk
https://www.youtube.com/watch?v=_o8E4WCC4F8
(IMG:style_emoticons/default/drooley.gif)
Need to know:
http://www.pattakon.com/
http://www.pattakon.com/pattakonEduc.htm
http://bestplay.pk/watch/V6PGO03K6cI
Like the Merlin V12 engine above,the 180* flat engine has 6 crankpins,just like the Boxer Six.
The crank is offset 3" to grind the 6" stroke crank,27L.
https://www.youtube.com/watch?v=xbZ9RD6BTMw
http://www.e31.net/engines_e.html
Technology Terminology,for to make communicate.Some,obviously,are not on the same page.
Needing a part,called a part store,"Do you sell 'whatchyamacallits',for my motor thingy?".
(IMG:style_emoticons/default/lol-2.gif)
The reason for the forked 'Connecting Rod',is performance,the reduction of engine weight.
The HD,and the RR,have their cylinders opposite each other,in the same plane.The greater complexity of manufacture was a calculated compromise.
The weight of the crankshaft was reduced,as the secondary unbalance forces were nulled by the inline cylinders,less vibration.
The shared crankpin of the 917 engine's side by side,'conrods',are the result,also,of a compromise in the cost of manufacture,and simplicity
The proposal for such forked rods,in the initial design stages of the 917 engine,was rejected,as their mass was unsuitable for the high rpm engine.
Two different applications,two different results,both of which excelled in their field.
https://www.google.ca/webhp?sourceid=chrome...iston%20engines
https://www.google.ca/webhp?sourceid=chrome...connecting+rods
http://www.practicalmachinist.com/vb/antiq...-merlin-306661/
http://www.craftsmanshipmuseum.com/Tomlinson.htm
http://www.speedwaymotors.com/Scat-932911-...troke,3181.html
https://rideapart.com/articles/birth-harley...on-v-twin-motor
RR Merlin crank.Forged,hollow,tubular and light.Sheffield.
http://bbs.homeshopmachinist.net/threads/4...ine-Restoration
http://www.practicalmachinist.com/vb/gener...ankshaft-73615/
The finish anvil below,one of _.
Looking to make a piston engine?
(IMG:style_emoticons/default/evilgrin.gif)
So,yeah,a flat 180-12 engine can have the cylinders inline,the boxer's must be offset.The offset distance is the thickness of the web,rod and journal,if any.
A method to circumvent the offset,with minimal complexity.:
Boxer Cranks
MercedesBenz auto V12
Bmw auto V12
Diamler Benz DB 605 V12 Crank
912 Shafts
https://www.google.ca/webhp?sourceid=chrome...+917+engine+fan
Twin Supra V12 crank,heavy man.
So,you were thinking of a flat 12 914.
http://www.enginelabs.com/engine-tech/cran...ght-crankshaft/
A passion for the 914,shared with others.
https://www.google.ca/webhp?sourceid=chrome...ahn&tbm=vid
http://forums.pelicanparts.com/porsche-911...-flat-12-a.html
http://gtspirit.com/2013/12/29/remarkable-...al-porsche-917/
911+911=flat12!
The freedom to do a build of your own,a personal vision,and version of your 914.
Mike Bellis
post Oct 17 2013, 06:56 PM
Resident Electrician
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.cdn.turner.com-10496-1382057818.1.jpg)
veekry9
post Oct 17 2013, 07:27 PM
OldMember
QUOTE(kg6dxn @ Oct 17 2013, 08:56 PM) *
Pie in the sky ramblings of malarky.
After the Cosmic Rain
The whatif of gearheads everywhere is what makes all of this wrenching so worthwhile.
Certainly,few of us here are motivated only by $$reward.Rather,we support the specialists out there.
They need the money,you need the 'stuff',
A MS Paint drawing from the '90s,to show the kids how to use the pc,called it 'Veloce'.
veekry9
post Oct 21 2013, 07:23 PM
OldMember
https://www.youtube.com/watch?v=D4IR6Ukv7gk
Isdera
Eberhard Shulz.
He started out as the Erator GTE builder and developed into a wonderful designer.I even like his first off.
There's a youtube of it being thrashed through the black forest.
A showcase of the builders dream realized.A successful talent in auto design.
https://www.youtube.com/watch?v=dr7dnobhDFI
Midengined straight-6 or V8 sports type.
Oh Yeah,
Made the cover of Road+Track.
Then Years later,tested at speed by Paul Frere,
176MPH=Stable,Tight.(Yes:176mph).As timed by R+T.
https://www.youtube.com/watch?v=TOeTKlCPOss
sixnotfour
post Oct 21 2013, 07:43 PM
QUOTE(veekry9 @ Oct 17 2013, 01:22 PM) *
So.
I recently took possesion of two(2)
merely welding sawn cases together,
then installing a custom crank
and cam.Then the problem becomes the cylinder head.
Look,if that guy out there in boonville norway can do it,
what,if only money,is stopping us?(me)
Luke,do or not do.(IMG:http://www.914world.com/bbs2/style_emoticons/default/welder.gif)
Why on earth would you bother with a push rod engine ?? (IMG:style_emoticons/default/confused24.gif)
Mike Bellis
post Oct 21 2013, 07:49 PM
Hmmmmm?!?!?!? (IMG:style_emoticons/default/blink.gif)
veekry9
post Oct 21 2013, 08:13 PM
OldMember
QUOTE(kg6dxn @ Oct 21 2013, 09:49 PM) *
Velly interestink.
I presume the 'trunk'is in the middle,or perhaps the fuel tank has been relocated to the vacant engine bay.
For lack of a better description a VW-914-T1-4.For those whose inclinations are bug-love.Does it work?
Sure.
veekry9
post Oct 22 2013, 06:10 PM
Post #21
OldMember
In the interest of keeping this a Porsche
relevant thd.
https://www.youtube.com/watch?v=w-aAMr5kySg
Conclusion:Porsche solved the vibes.Revs?Many questions.
https://www.youtube.com/watch?v=2GpMGPUMyXE
Mr Lind apparently had a Swedish Co. do his crank and cam.
http://enem.se/ib.asp
Anyone here source their parts from Sweden?
>on UAC
Type 4 Unleashed
M-Owen wrote:
Did you ever get an answer from this site?
Yes I did, and was signed up.
Two guys built this motor, Julle & Lind, it had even been upgraded to a 4.6 ltr, they had upgraded to 101.6 mm P/C's.
The motor is currently in a 914, and had been taken up to 167 mph and it still was pulling, but engine temps were climbing, so he slowed it down.
This would be a wild project.
Indeed,lessee...$/Lb.:Porsche-8 versus Lind-built T4-8
The idea Lind+Julle could run that 8 with a welded crank I think is doubtful.
Having attracted worldwide attention,would they repeat the feat for a customer?
Dave_Darling
post Oct 22 2013, 07:34 PM
Post #22
914 Idiot
How the heck do you fit that thing in a 914????
--DD
veekry9
post Oct 22 2013, 07:58 PM
Post #23
OldMember
The Question is how did he do it at all.
Likely every 3rd person who saw it under construction
had doubts of success or even completion.
Point Made.
Heavier than air machines Can Fly!!
Mike Bellis
post Oct 22 2013, 09:41 PM
Post #24
Dr Evil
post Oct 22 2013, 09:55 PM
Post #25
Send me your transmission!
That double T4-8 makes me so friggen moist (IMG:style_emoticons/default/drooley.gif)
veekry9
post Oct 23 2013, 01:15 PM
Post #26
OldMember
QUOTE(kg6dxn @ Oct 22 2013, 11:41 PM) *
Post #66806
A 914/Cayenne for the Paris-Dakar Rally.With a 959 drivetrain.OohLaLa.
https://www.youtube.com/watch?v=k2thf2NwMYE
Great idea.
veekry9
post Oct 23 2013, 08:38 PM
Post #27
OldMember
Laguna Seca
https://www.youtube.com/watch?v=bsf8S3qgwX8
sounds good.
A GT of Sicily
https://www.youtube.com/watch?v=7Albnb3xQdo
a How To.
sixnotfour
post Oct 24 2013, 06:44 PM
Post #28
QUOTE(veekry9 @ Oct 23 2013, 07:38 PM) *
Those are Not push rod engines ...
veekry9
post Oct 24 2013, 07:13 PM
Post #29
OldMember
The Evolution of Design.
A Flat 8 built today may actually be superior in every way.
Definitely Expensive.
Well,There is 1 Factory 914-8.
(corr:2 actually,thanks Dave)
Exclusive Territory.
Hmmm...
Another part for your 908 powered 914.
Dave_Darling
post Oct 24 2013, 09:27 PM
Post #30
914 Idiot
There are two of them, the silver one that was built for the Dr. for his birthday, and the orange one built for Piech.
There were rumors of a third one that was built after-hours a number of years later, but those are unconfirmed....
--DD
veekry9
post Oct 25 2013, 06:27 PM
Post #31
OldMember
I recalled an animation from a few yrs ago.
https://www.youtube.com/watch?v=wh7J8DSDZAg
edit:this animation shows the crank in an interspersed configuration.
a 4cyl crank in the middle,another split and joined at each end,hence the harmonics.
The successful 908 crank is 2 4cyl cranks joined at 90* angle.
http://www.jabiru.net.au/
Engine Features
4 Stroke
3300cc (200 cubic inches)
6 Cylinder Horizontally Opposed
1 Central Camshaft
Fully Machined Aluminium Alloy Crankcase
Over Head Valves (OHV) - Push Rod Operated
Ram Air Cooled
Wet Sump Lubrication - 4 litre capacity
Direct Propeller Drive
Dual Transistorised Magneto Ignition
Integrated AC Generator
Electric Starter
Mechanical Fuel Pump
Naturally Aspirated - 1 Pressure Compensating Carburetor
This is the 5L -8
It is,at this date out of production.
http://en.wikipedia.org/wiki/Jabiru_5100
https://www.google.ca/webhp?sourceid=chrome...8#q=jabiru+5100
The 8 sounds real good
For those who aren't moneyshy,not cheap.
High quality,aero-style.
see more:
http://www.914world.com/bbs2/index.php?showtopic=250515
animation of types:
https://www.youtube.com/watch?v=hvpFcSPtDV0
nice work.
- Lo-Fi Version Time is now: 27th December 2024 - 01:53 PM
