16 Pages V « < 5 6 7 8 > »
> PIX, Pix Of Enlightenment
7TPorsh
post Sep 16 2014, 02:16 PM
Post #111
7T Porsh
yep, 5 bolt. % in the center square, neat
veekry9
post Sep 16 2014, 02:48 PM
Post #112
OldMember
Group: Retired Members
QUOTE(3d914 @ Sep 15 2014, 10:08 PM) *
Have you seen these? Both are design built around the 914 unibody. Either would be interesting to refine/update.
Sure,a great idea,rather than purchasing an off the rack auto,make a custom.
California is a goldmine of automotive design/build talent.
Start like we all did,scratching our "Lambo"with a pencil on the back page of notebooks.Mockup scale models and when the results please you,move to full-size mounted on the recipient Fiero chassis.Beat alloy panels into shape over wooden bucks like Bertone or layup into a mold pulled from a buck.
So yeah,a huge effort is required,and at the end you may have something like a Bradley or (hopefully) a Frua 914.I suppose that is why I can appreciate the results
Eberhard Shulz attained with his Imperator 108 in the '70s.A verbatim replica of others work would not suffice,so he designed and built his own.An achievement like that requires more than a passing knowledge of design and manufacture.
It all starts with an idea,so determine what your quest is then blaze a path.
a good example of a nicely integrated design
A perfect example of meticulous,determined construction methods.
wow
http://www.gt40s.com/forum/wings-wheels-ke...0-dreaming.html
Bruce McLaren"woosh bonk...done"
veekry9
post Sep 16 2014, 08:07 PM
Post #113
OldMember
Post #70560
first look,a 356RSR,love
veekry9
post Sep 16 2014, 08:50 PM
Post #114
OldMember
QUOTE(veekry9 @ Apr 19 2014, 07:44 PM) *
As an example of how design intent can go arwry..
YellowHorror
Fat tires-check.
Flares-check
pseudo f40-check
As you observe various auto designs are you able to percieve rust and or dents
from a distance of 100 yds?Sure,so it is entirely possible to detect the shape of
the fenders of a 911rsr.Expedient measures to cover the tires range from this
to the shapely splined flanks of the 914.
The necessity drives the invention.
Post #90543
funny thing,found.
from this angle it looks better.
the addition of discrete features+nasa ducts
(edit:07/09/16)
A relic of the past,it has grown on me.
Kinda has some F40 details,V8 too.
veekry9
post Sep 17 2014, 07:31 AM
Post #115
OldMember
veekry9
post Sep 17 2014, 09:12 AM
Post #116
OldMember
QUOTE(carr914 @ Jun 29 2010, 08:13 AM) *
914 CopyCats
Nope,
Ferrari 308GT4
Maserati Bora
Maserati Merak
Fiat X19
BMW M1
DeTomaso Pantera
DeTomaso Mangusta
http://en.wikipedia.org/wiki/Pontiac_Fiero
The idea of a low powered runabout with a mid mounted transverse engine was a demonstration of technology sophistication.
The engineering that went into the stamped steel chasssis produced a rigid crash safe exoskeleton.
The only production mid of America.
Check the prices of that poor car and compare to any other mid.
(edit:05/05/16)
80 mph transverse rollover crash tests passed.
Attached Image Attached ImageAttached Image
http://www.italdesign.it/en/projects/ford-maya-iies-eng/
http://www.fiero.nl/cgi-bin/fiero/Ultimate.cgi?action=intro
All that's required is a dieman to create repair panels for the chronic rust areas.
Then add lightweight power for a decent mid sportster.
Different crash safety requirements,the reason for the 914's cancellation.
Sleepin
post Sep 17 2014, 10:39 AM
Post #117
That is AWESOME!
veekry9
post Sep 17 2014, 10:53 AM
Post #118
OldMember
The more I more I consider the cylinder heads of the 4cam 613,the more I'm inclined to think they may fit quite easily onto a Corvair shortblock.
Gears are turning here.
A flat 6 or 8 from the Carpathian Mountains.
Bolts? Sure, I've got Bolts.
http://ffilms.org/young-frankenstein-1974/
veekry9
post Sep 18 2014, 10:22 PM
Post #119
OldMember
QUOTE(veekry9 @ Oct 29 2013, 09:44 PM) *
Found some old links re:flat-8 at PerformanceForums
http://jalopnik.com/5799726/emerson-...kswagen-beetle
https://www.youtube.com/watch?v=tXKcpbFF7WI
https://www.youtube.com/watch?v=Zto2UDCUyoY
these have be online a few years.
These guys make it look easy.
Want a Flat-8,Make one.
(IMG:style_emoticons/default/smilie_flagge24.gif)
Post #92638
This is the 8 cylinder type 1 Emerson had built and raced.
went real fast
http://www.wired.com/2011/05/emerson-fitti...gine-vw-beetle/
veekry9
post Sep 19 2014, 01:30 AM
Post #120
OldMember
QUOTE(Sleepin @ Sep 6 2014, 10:42 AM) *
Add 3" to the center of the car, like this: (IMG:style_emoticons/default/welder.gif)
wow ..
split down the middle
on a boxster
veekry9
post Sep 19 2014, 04:51 AM
Post #121
OldMember
QUOTE(bulitt @ Jun 5 2014, 06:33 AM) *
Looks like the door gaps on my first tub... (IMG:style_emoticons/default/blink.gif)
Yup..
Real big air scoops
more power,more air,more drag,more power...
veekry9
post Sep 19 2014, 05:32 AM
Post #122
OldMember
Ghia by Karmann
Liked them back then,still do.
Big Sis,early 60s,had that new VW aroma.
updated headlamps
nerf bars
(edit:12/16/15)
http://www.oldbug.com/finch.htm
A more accurate report of this gorgeous Ghia.
veekry9
post Sep 19 2014, 07:11 AM
Post #123
OldMember
QUOTE(7TPorsh @ Jun 5 2014, 11:53 AM) *
Always thought this was interesting....
an attempt at sloping the headlamps to approximate the windscreen.
the chrome rings are retained
conformal
veekry9
post Sep 19 2014, 08:03 AM
Post #124
OldMember
Side view with cam tower exposed showing lifter-block registers and seats.
A custom barrel to carry a roller lifter can be fabricated to seat in the existing bore.
(Edit:10/21/14)
The stud spacing appears to be wide enough to accommodate an 90mm bore cylinder.
Visible cylinder bore is 75mm,so perhaps as much as 90mm(+15mm)
Anyone out there have real specifications of the head stud spacing?
(as resolved from drawing,102mm bcd)
http://www.914world.com/bbs2/index.php?sho...22522&st=98
edit:an 80mm(+8mm) stroke would yield 4.07 L,an increase of 1.5L .
Aircooled V8 hemispherical head 16 V pushrod alloy engine.
What's not to like?The crank is likely forged as the diesel manufacturing requires them.
All around a decent small V8 with great potential,just needs some modern tech applied to them.
(edit:11/10/15)
Have a look at these few vids.
https://www.youtube.com/results?search_quer...gine&page=1
(edit:08/06/16):
http://retrorides.proboards.com/thread/148...a-sport-v8-pics
(edit:08/08/16):
The numbers here are very close,so,a maximum bore diameter of ~90mm.
The cast iron lifter bore bodies are seen attached to the cam tower.Custom versions made to carry roller lifters would fit nicely.
At the bottom,one of the oil coolers is seated on it's seal flanges,the temperature sender at the top of the stud.
The distributor barrel is at the right.
veekry9
post Sep 20 2014, 05:23 AM
Post #125
OldMember
Isdera Erator GTE,Eberhard Shulz.
I even like his first off.
There was a yewtube of it being thrashed through the black forest,driver's view.(now removed)
https://www.youtube.com/watch?v=MyYgYho43mQ
https://www.youtube.com/watch?v=khxgb2EP5ac
https://www.youtube.com/watch?v=f2AMLaTDXAo
(edit:07/08/16)
https://www.google.ca/search?q=Isdera+Erato...QkJBa0Q_AUIBigB
https://www.google.ca/search?q=isdera+imper...UoeAFAQ_AUIBigB
(Edit:08/14/16):
veekry9
post Sep 21 2014, 11:23 AM
Post #126
OldMember
hmmm Fiero not,a Ford mockup.
veekry9
post Sep 21 2014, 11:31 AM
Post #127
OldMember
http://www.fiero.nl/forum/Forum3/HTML/000091-53.html
Looking for a new dash?
Some ideas from the custom Fiero world
Immaculate work by Amida
10/10
veekry9
post Sep 21 2014, 09:19 PM
Post #128
OldMember
QUOTE(Sleepin @ Sep 17 2014, 12:39 PM) *
https://www.youtube.com/watch?v=oZZXKIDqv2c
https://www.youtube.com/watch?v=v39Z8oFpbbE
https://www.youtube.com/watch?v=ClRqT2uoXTo...cuI_ZXOUvqXEFKA
the stuffing of an aircooled v8 into a light sports car..
https://www.youtube.com/watch?v=x3zW9uaiVNk
veekry9
post Sep 29 2014, 04:55 AM
Post #129
OldMember
Discovery!
The manufacture of an aircooled V8 integral with transmission and final drive.
The Tatra 613 V8 and
The Tatra 700 V8.
compact design places crankshaft above axle.
veekry9
post Sep 29 2014, 05:41 AM
Post #130
OldMember
85mm bore iron cylinders
77mm stroke crank
driveshaft,pinion and crown
cam carriers,top and bottom
hemi heads
it all seems familiar
- Lo-Fi Version Time is now: 26th December 2024 - 06:59 AM
