16 Pages V « < 5 6 7 8 9 > »
> PIX, Pix Of Enlightenment
veekry9
post Sep 19 2014, 04:51 AM
Post #121
OldMember
Group: Retired Members
QUOTE(bulitt @ Jun 5 2014, 06:33 AM) *
Looks like the door gaps on my first tub... (IMG:style_emoticons/default/blink.gif)
Yup..
Real big air scoops
more power,more air,more drag,more power...
veekry9
post Sep 19 2014, 05:32 AM
Post #122
OldMember
Ghia by Karmann
Liked them back then,still do.
Big Sis,early 60s,had that new VW aroma.
updated headlamps
nerf bars
(edit:12/16/15)
http://www.oldbug.com/finch.htm
A more accurate report of this gorgeous Ghia.
veekry9
post Sep 19 2014, 07:11 AM
Post #123
OldMember
QUOTE(7TPorsh @ Jun 5 2014, 11:53 AM) *
Always thought this was interesting....
an attempt at sloping the headlamps to approximate the windscreen.
the chrome rings are retained
conformal
veekry9
post Sep 19 2014, 08:03 AM
Post #124
OldMember
Side view with cam tower exposed showing lifter-block registers and seats.
A custom barrel to carry a roller lifter can be fabricated to seat in the existing bore.
(Edit:10/21/14)
The stud spacing appears to be wide enough to accommodate an 90mm bore cylinder.
Visible cylinder bore is 75mm,so perhaps as much as 90mm(+15mm)
Anyone out there have real specifications of the head stud spacing?
(as resolved from drawing,102mm bcd)
http://www.914world.com/bbs2/index.php?sho...22522&st=98
edit:an 80mm(+8mm) stroke would yield 4.07 L,an increase of 1.5L .
Aircooled V8 hemispherical head 16 V pushrod alloy engine.
What's not to like?The crank is likely forged as the diesel manufacturing requires them.
All around a decent small V8 with great potential,just needs some modern tech applied to them.
(edit:11/10/15)
Have a look at these few vids.
https://www.youtube.com/results?search_quer...gine&page=1
(edit:08/06/16):
http://retrorides.proboards.com/thread/148...a-sport-v8-pics
(edit:08/08/16):
The numbers here are very close,so,a maximum bore diameter of ~90mm.
The cast iron lifter bore bodies are seen attached to the cam tower.Custom versions made to carry roller lifters would fit nicely.
At the bottom,one of the oil coolers is seated on it's seal flanges,the temperature sender at the top of the stud.
The distributor barrel is at the right.
veekry9
post Sep 20 2014, 05:23 AM
Post #125
OldMember
Isdera Erator GTE,Eberhard Shulz.
I even like his first off.
There was a yewtube of it being thrashed through the black forest,driver's view.(now removed)
https://www.youtube.com/watch?v=MyYgYho43mQ
https://www.youtube.com/watch?v=khxgb2EP5ac
https://www.youtube.com/watch?v=f2AMLaTDXAo
(edit:07/08/16)
https://www.google.ca/search?q=Isdera+Erato...QkJBa0Q_AUIBigB
https://www.google.ca/search?q=isdera+imper...UoeAFAQ_AUIBigB
(Edit:08/14/16):
veekry9
post Sep 21 2014, 11:23 AM
Post #126
OldMember
hmmm Fiero not,a Ford mockup.
http://www.italdesign.it/en/projects/ford-maya-iies-eng/
veekry9
post Sep 21 2014, 11:31 AM
Post #127
OldMember
http://www.fiero.nl/forum/Forum3/HTML/000091-53.html
Looking for a new dash?
Some ideas from the custom Fiero world
Immaculate work by Amida
10/10
veekry9
post Sep 21 2014, 09:19 PM
Post #128
OldMember
QUOTE(Sleepin @ Sep 17 2014, 12:39 PM) *
https://www.youtube.com/watch?v=oZZXKIDqv2c
https://www.youtube.com/watch?v=v39Z8oFpbbE
https://www.youtube.com/watch?v=ClRqT2uoXTo...cuI_ZXOUvqXEFKA
the stuffing of an aircooled v8 into a light sports car..
https://www.youtube.com/watch?v=x3zW9uaiVNk
veekry9
post Sep 29 2014, 04:55 AM
Post #129
OldMember
Discovery!
The manufacture of an aircooled V8 integral with transmission and final drive.
The Tatra 613 V8 and
The Tatra 700 V8.
compact design places crankshaft above axle.
veekry9
post Sep 29 2014, 05:41 AM
Post #130
OldMember
85mm bore iron cylinders
77mm stroke crank
driveshaft,pinion and crown
cam carriers,top and bottom
hemi heads
it all seems familiar
veekry9
post Sep 29 2014, 09:25 AM
Post #131
OldMember
in fact the axle passes below the crankshaft middle main bearing journal perhaps as little as 25-30mm.
With the sump pan removed,you can see the main bearing cap that carries the axle.
Note chain driven oilpump and filter mount,starter to the right.Aluminum bearing caps are cross-bolted,the block rails extended far below the crank CL,perhaps suitable to carry structural loads.
Mounting the block in front of 901 TX seems possible although the uneeded portions of the casting create a 5-7 kg weight penalty,easily removed.
bare Y-block,differential cast integrally.Front(Rear) fan casting mounts on right,cam drive.
the stash at the wreckers,found at this link:
Obviously unaware of the huge demand for these parts.
http://www.lhotkanet.cz/mirror/aek4470.finalnet.cz/
(edit:07/31/16):
A unique design modification,to allow the use of the engine in a mid configuration.
The original driveshaft is used to drive a cv joint where the differential formerly was.
A new casting is made to carry the diff,raised from the factory position,dropping the CG,and pan to ride height.
The engine is run with a crank and cam position trigger,for coil on twin plug ignition,no dizzy.
A conversion to chain drive for the cams,and vvt takes less room at the drive end of the block.
A hyvo chain to drive a shaft going forward to a front diff,can make for a awd car.
Mike Bellis
post Sep 29 2014, 09:19 PM
Post #132
Resident Electrician
Since the axle is too far forward for a 914, you should... Weld the diff like a spool, mount the engine transversly, install a AWD drivetrain and make the first air cooled V8 AWD 914. The transmission diff will act as the transfer case.
veekry9
post Sep 30 2014, 12:11 AM
Post #133
OldMember
The original intent of the designer was to package an entire powerplant and drivetrain into a light compact discrete component.A twin engine 4x4 for example would only require installing an engine package as there are no auxilary peripherals needed,being aircooled.An engine over the axle is a design suitable for front drive and or rear drive and is suitable for adaptation to other applications.Mounting the engine in place of a 914's 4 cylinder,you gain displacement and a few pounds that theoretically at least,is easily shed.I can find no faults in the design and a few unique solutions that simplify the manufacture and maintenance of it.The engine has no inherent problems with pulling studs out of the block or bearing failures,as it's a robust ribbed casting.
here's an example with a turbo mounted,likely with stock components internally.
This is the Tatra-700-EFI:
veekry9
post Oct 5 2014, 04:24 PM
Post #134
OldMember
This is really cute,but somehow the taillights and bumper look too modern for the bug roofline.Perhaps a little Ghia,?
Stuffing an early '63 914 with a 2.5 to 4.4 Litre V8 of an aircooled design has to be OK.
Turns out there may be as few as 10 Tatra V8 engines in North America.
There may be a HotRodder in the EU who may wish to give it a go.
The 4-cam 613 could run with the heads swapped for a hot-V.
Convenient for turbocharging and intercooling plumbing.
veekry9
post Oct 5 2014, 07:35 PM
Post #135
OldMember
Outrigger TwinTurbo
928 S4
Anyone here recognize the trans-axle?(edit 05/03/15:956/962)
veekry9
post Oct 5 2014, 08:12 PM
Post #136
OldMember
Like this Outlaw POLO 356,the '63 914 has a rounded,curved house.
If the hips pinch in at the tail,and the roof-line blends into the vertical face below the trunk-line,a nice Ghia like curvature will result.Voluptuous.
Add a little sponson and the two lamp treatment.
Very 60's retro.
veekry9
post Oct 19 2014, 12:49 AM
Post #137
OldMember
Very nice Silver
A 944 windscreen+roof+hatch+spoiler
Only for those with skills in metalshaping.
veekry9
post Oct 19 2014, 08:10 AM
Post #138
OldMember
+10in (254mm) Wider overall
+4 in (100mm) Wheelbase
veekry9
post Oct 20 2014, 03:01 PM
Post #139
OldMember
Intercoolers + Turbos mid mounted
veekry9
post Oct 20 2014, 04:56 PM
Post #140
OldMember
Liquid cooled?
Requires a rad in front.
A very sophisticated look also from the 924/944/968 product lines.
Well done.I even like the color.
Raised brand logo on rocker is a nice custom touch.
edit:Nov 15/14 found this>
http://members.rennlist.com/bluethunder/coverpag.htm
- Lo-Fi Version Time is now: 24th December 2024 - 06:22 AM
