PIX, Pix Of Enlightenment |
veekry9 |
Oct 22 2013, 06:10 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
In the interest of keeping this a Porsche
relevant thd. https://www.youtube.com/watch?v=w-aAMr5kySg Conclusion:Porsche solved the vibes.Revs?Many questions. https://www.youtube.com/watch?v=2GpMGPUMyXE Mr Lind apparently had a Swedish Co. do his crank and cam. http://enem.se/ib.asp Anyone here source their parts from Sweden? >on UAC [ Type 4 Unleashed Location: Aliso Viejo, CA M-Owen wrote: Did you ever get an answer from this site? Yes I did, and was signed up. Two guys built this motor, Julle & Lind, it had even been upgraded to a 4.6 ltr, they had upgraded to 101.6 mm P/C's. The motor is currently in a 914, and had been taken up to 167 mph and it still was pulling, but engine temps were climbing, so he slowed it down. This would be a wild project. ] Indeed,lessee...$/Lb.:Porsche-8 versus Lind-built T4-8 The idea Lind+Julle could run that 8 with a welded crank I think is doubtful. Having attracted worldwide attention,would they repeat the feat for a customer? |
Oct 22 2013, 07:34 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
How the heck do you fit that thing in a 914????
--DD |
veekry9 |
Oct 22 2013, 07:58 PM
The Question is how did he do it at all.
Likely every 3rd person who saw it under construction had doubts of success or even completion. Point Made. Heavier than air machines Can Fly!! |
Mike Bellis |
Oct 22 2013, 09:41 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Dr Evil |
Oct 22 2013, 09:55 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
That double T4-8 makes me so friggen moist (IMG:style_emoticons/default/drooley.gif)
veekry9 |
Oct 23 2013, 01:15 PM
Post #66806 A 914/Cayenne for the Paris-Dakar Rally.With a 959 drivetrain.OohLaLa. https://www.youtube.com/watch?v=k2thf2NwMYE Great idea. |
veekry9 |
Oct 23 2013, 08:38 PM
Laguna Seca
https://www.youtube.com/watch?v=bsf8S3qgwX8 sounds good. A GT of Sicily https://www.youtube.com/watch?v=7Albnb3xQdo a How To. |
sixnotfour |
Oct 24 2013, 06:44 PM
914 Wizard Group: Members Posts: 10,673 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Laguna Seca https://www.youtube.com/watch?v=bsf8S3qgwX8 sounds good. A GT of Sicily https://www.youtube.com/watch?v=7Albnb3xQdo a How To. Those are Not push rod engines ... |
veekry9 |
Oct 24 2013, 07:13 PM
The Evolution of Design. A Flat 8 built today may actually be superior in every way. Definitely Expensive. Well,There is 1 Factory 914-8. (corr:2 actually,thanks Dave) Exclusive Territory. Hmmm... Another part for your 908 powered 914. |
Oct 24 2013, 09:27 PM
There are two of them, the silver one that was built for the Dr. for his birthday, and the orange one built for Piech.
There were rumors of a third one that was built after-hours a number of years later, but those are unconfirmed.... --DD |
veekry9 |
Oct 25 2013, 06:27 PM
I recalled an animation from a few yrs ago.
https://www.youtube.com/watch?v=wh7J8DSDZAg edit:this animation shows the crank in an interspersed configuration. a 4cyl crank in the middle,another split and joined at each end,hence the harmonics. The successful 908 crank is 2 4cyl cranks joined at 90* angle. http://www.jabiru.net.au/ Engine Features 4 Stroke 3300cc (200 cubic inches) 6 Cylinder Horizontally Opposed 1 Central Camshaft Fully Machined Aluminium Alloy Crankcase Over Head Valves (OHV) - Push Rod Operated Ram Air Cooled Wet Sump Lubrication - 4 litre capacity Direct Propeller Drive Dual Transistorised Magneto Ignition Integrated AC Generator Electric Starter Mechanical Fuel Pump Naturally Aspirated - 1 Pressure Compensating Carburetor This is the 5L -8 It is,at this date out of production. http://en.wikipedia.org/wiki/Jabiru_5100 https://www.google.ca/webhp?sourceid=chrome...8#q=jabiru+5100 The 8 sounds real good For those who aren't moneyshy,not cheap. High quality,aero-style. see more: http://www.914world.com/bbs2/index.php?showtopic=250515 animation of types: https://www.youtube.com/watch?v=hvpFcSPtDV0 nice work. |
Dr Evil |
Oct 25 2013, 06:41 PM
Aircraft engines are not good candidates for car engines. They do not rev the same and the cams are meant to get power in a narrow band. Same is true for a converted corvair engine.
veekry9 |
Oct 25 2013, 06:55 PM
Aircraft engines are not good candidates for car engines. They do not rev the same and the cams are meant to get power in a narrow band. Same is true for a converted corvair engine. Oh Yeah. The aircraft billet engine is for aircraft,that said,the idea that the average m/c shop equipped with modern tools can crank out specials is valid. I'm still hankering for the 4valve heads that Martin Bott developed for T4's The Jabiru from Oz isn't the only fully cnc'd engine type. https://www.youtube.com/watch?v=QsmiIeAkE-o F1?Prostock?Prototype / http://rennlist.com/forums/911-forum/93509...ne-cases-2.html / |
veekry9 |
Oct 27 2013, 07:10 PM
A fellow up here in Ontario,also known as TasmanDevil. Unrecognisable as a Fiero.TPI V8 Transverse. Gorgeous Paint(Jag BlackCherry Metallic)Full Leather. Absolutely Impeccable. http://www.fiero.nl/cgi-bin/fiero/Ultimate.cgi For those of you interested in an American MidEngine as a 2nd car,and an object of worship on the alter of the jackstands. / |
Oct 27 2013, 09:10 PM
Dr Evil |
Oct 27 2013, 09:18 PM
What pic? That link takes me to a list with no pics
Dr Evil |
Oct 27 2013, 09:19 PM
Never mind, the Fiero pic loaded in the thread. I looks like a Fiero (IMG:style_emoticons/default/confused24.gif)
veekry9 |
Oct 28 2013, 05:13 PM
UhHuh.
So it's true then,a leopard can't change it's spots. But a V8 into a 914 or Fiero can enhance your power trip. An entire aftermarket exists for your personal magic carpet. Some parts not included. Some assembly required. The lowly Fieros and 914s made new and improved. https://www.youtube.com/watch?v=UtkP5gTX6Hc |
veekry9 |
Oct 28 2013, 07:54 PM
Any Takers here?
Quote Flat 8 Porsche Engine A mate is making a flat 8 engine for a replica 908. He has used two 2.7lt magnesium blocks that we wirecut at my work and has welded them together in a jig. First time he has welded mag and it is a steep learning curve with the pre heating/jigging and post stress relieving. Here are the photos of his second attempt. He still has 1mm of bend after welding but is making a different jig that will be stronger and keep the heat more stable (he was saying 5 mins after welding and it was cool enough to handle). Unquote http://performanceforums.com/forums/showth...-Porsche-Engine from '11 |
Woody |
Oct 29 2013, 11:18 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Any Takers here? Quote Flat 8 Porsche Engine A mate is making a flat 8 engine for a replica 908. He has used two 2.7lt magnesium blocks that we wirecut at my work and has welded them together in a jig. First time he has welded mag and it is a steep learning curve with the pre heating/jigging and post stress relieving. Here are the photos of his second attempt. He still has 1mm of bend after welding but is making a different jig that will be stronger and keep the heat more stable (he was saying 5 mins after welding and it was cool enough to handle). Unquote http://performanceforums.com/forums/showth...-Porsche-Engine from '11 Why not use an aluminum case? |
Lo-Fi Version | Time is now: 24th December 2024 - 06:18 AM |
