PIX, Pix Of Enlightenment |
Dr Evil |
Oct 25 2013, 06:41 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Aircraft engines are not good candidates for car engines. They do not rev the same and the cams are meant to get power in a narrow band. Same is true for a converted corvair engine.
veekry9 |
Oct 25 2013, 06:55 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Aircraft engines are not good candidates for car engines. They do not rev the same and the cams are meant to get power in a narrow band. Same is true for a converted corvair engine. Oh Yeah. The aircraft billet engine is for aircraft,that said,the idea that the average m/c shop equipped with modern tools can crank out specials is valid. I'm still hankering for the 4valve heads that Martin Bott developed for T4's The Jabiru from Oz isn't the only fully cnc'd engine type. https://www.youtube.com/watch?v=QsmiIeAkE-o F1?Prostock?Prototype / http://rennlist.com/forums/911-forum/93509...ne-cases-2.html / |
veekry9 |
Oct 27 2013, 07:10 PM
A fellow up here in Ontario,also known as TasmanDevil. Unrecognisable as a Fiero.TPI V8 Transverse. Gorgeous Paint(Jag BlackCherry Metallic)Full Leather. Absolutely Impeccable. http://www.fiero.nl/cgi-bin/fiero/Ultimate.cgi For those of you interested in an American MidEngine as a 2nd car,and an object of worship on the alter of the jackstands. / |
Oct 27 2013, 09:10 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Dr Evil |
Oct 27 2013, 09:18 PM
What pic? That link takes me to a list with no pics
Dr Evil |
Oct 27 2013, 09:19 PM
Never mind, the Fiero pic loaded in the thread. I looks like a Fiero (IMG:style_emoticons/default/confused24.gif)
veekry9 |
Oct 28 2013, 05:13 PM
UhHuh.
So it's true then,a leopard can't change it's spots. But a V8 into a 914 or Fiero can enhance your power trip. An entire aftermarket exists for your personal magic carpet. Some parts not included. Some assembly required. The lowly Fieros and 914s made new and improved. https://www.youtube.com/watch?v=UtkP5gTX6Hc |
veekry9 |
Oct 28 2013, 07:54 PM
Any Takers here?
Quote Flat 8 Porsche Engine A mate is making a flat 8 engine for a replica 908. He has used two 2.7lt magnesium blocks that we wirecut at my work and has welded them together in a jig. First time he has welded mag and it is a steep learning curve with the pre heating/jigging and post stress relieving. Here are the photos of his second attempt. He still has 1mm of bend after welding but is making a different jig that will be stronger and keep the heat more stable (he was saying 5 mins after welding and it was cool enough to handle). Unquote http://performanceforums.com/forums/showth...-Porsche-Engine from '11 |
Woody |
Oct 29 2013, 11:18 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Any Takers here? Quote Flat 8 Porsche Engine A mate is making a flat 8 engine for a replica 908. He has used two 2.7lt magnesium blocks that we wirecut at my work and has welded them together in a jig. First time he has welded mag and it is a steep learning curve with the pre heating/jigging and post stress relieving. Here are the photos of his second attempt. He still has 1mm of bend after welding but is making a different jig that will be stronger and keep the heat more stable (he was saying 5 mins after welding and it was cool enough to handle). Unquote http://performanceforums.com/forums/showth...-Porsche-Engine from '11 Why not use an aluminum case? |
balljoint |
Oct 29 2013, 12:34 PM
Because RACECAR!! (Mag is lighter.)
--DD |
veekry9 |
Oct 29 2013, 07:44 PM
Found some old links re:flat-8 at PerformanceForums
http://jalopnik.com/5799726/emerson-...kswagen-beetle https://www.youtube.com/watch?v=tXKcpbFF7WI "Excellent, the pressure is great, Today is March 19th, 2009, and tomorrow, we will be recorded for the show, 'Auto Esporte'. Good work Marco, Good work Arlindo" https://www.youtube.com/watch?v=Zto2UDCUyoY The vids have be online a few years. These guys make it look easy.Wanted a Flat-8,Made one. https://www.youtube.com/watch?v=nF9j6G4bkZg (IMG:style_emoticons/default/smilie_flagge24.gif) |
veekry9 |
Nov 1 2013, 06:13 PM
Some headway's been made
Custom flat-8 crank from Oz. http://www.performanceforums.com/forums/sh...he-Engine/page2 Can't be cheap. Building a 908 tribute from scratch,to a fine resolution. |
veekry9 |
Apr 6 2014, 02:06 PM
Fer sail Wider to fit,with or without flares. early corsa late corsa 8 (what a '77 914/911/944 morph looks like) nice crank.corvair aero app they are able to do -8's to similar specs 2.5K+ / |
billh1963 |
Apr 6 2014, 04:43 PM
Car Hoarder! Group: Members Posts: 3,405 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Any progress on welding the 2.7 cases together?
veekry9 |
Apr 6 2014, 07:38 PM
billh1963:
I looked at the performanceforum thd recently,and from what was described the case weldment requires further welding. Magnesium castings are no doubt difficult to do to a machined tolerance.He was able to get within 1mm(0.039")runout through the mains bores, which all things considered,is a notable success.So,some layup on the mainbores and parting faces to be remachined,to straighten it up X2. A ton of very difficult work.Inspired by their efforts,a minor change in plans will be applied to my own P14. The intent was to run the 2L until I found some issues with the valve guides,and since I now have the Corvair 6's,I believe the initial cost of a 14-6 will be tolerable, originality deferred temporarily.The idea of creating a flat 8 using Corvair blocks welded and machined can't possibly be original,though the net has not revealed an attempt. The CNC shop doing the billet corvair cranks are a likely source for a 90-degree 8 pin crank.A fewer number of main bearing pins may be a serious problem for the vibration characteristics of such a long crank.More research is needed. Here is a site (edit:11/05//15(http://www.pattakon.com/))that makes balance software available. The Porsche drawing I've posted here shows the 90 degree pins interspersed with the 0 degree pins. The 2 billet cranks made in Australia appear to be the other method,which I believe is the solution Porsche used to tame the harmonic vibrations inherent with the original design. The price of a crank made to these specs is not cheap,so what to do if you're really hankering for a flat 8?Cut weld...? (IMG:style_emoticons/default/lol-2.gif) Seriously,a talented welder with some rod may git er done.A lot of work. |
veekry9 |
Apr 15 2014, 12:02 PM
OK.here's the plan.. Get 2 sets of cases,and weld them together after machining the front and rear off each respective set. Front 2 and rear 2.Makes a long case to carry 8 cylinders. Look,if the guy in Aus can weld magnesium cases,it would have to be easier to do the same to 356 T6 alloy cases. Marginally easier admittedly,but possible to achieve the exalted F-8. Fun with TIG,in an oven,inert gas flushed... / (edit:08/08/16): Samba-2-4-6-8 http://www.thesamba.com/vw/forum/viewtopic.php?t=399470 Well,the fellow in Australia has the right idea,wire edm cutting the cases to key each other together. Still,tubular shafts,ground to the mains and cam dia +0.0004"/-0 for alignment is essential. Otherwise,a near hopeless adventure,preparation of the weld groove is critical,minimum weld added. Tough job,all around.For sure a worthy aspiration,wanting -8,pushrod even.More cylinders,more better. (IMG:style_emoticons/default/biggrin.gif) Even these cases could be sixed,356-6.Custom crossflow center head too. (IMG:style_emoticons/default/evilgrin.gif) A VW Boxer Six,a neato version of the Corvair engine. Clearly,a welded crank.Note the main journal's discoloration and heat affected zone. The -8 crank is done in a similar way,two -4 cranks welded together,90* apart. http://carocha.forumeiros.com/t477-transfo...com-8-cilindros Mounted Mid in a 914,this is the right side of the engine,pretty nice looking. I want to build a few,and I know,some of you want one too. Some real expertise demonstrated here,kudos.Note the cam nose profiles,long duration,mushroom lifters,a revver. (IMG:style_emoticons/default/clap.gif) / |
rick 918-S |
Apr 16 2014, 10:12 AM
Hey nice rack! -Celette Group: Members Posts: 20,826 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I like this! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
bulitt |
Apr 16 2014, 11:17 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
There was a guy....on Ferrari chat with some amazing machinist and tig welding skills, and allot of energy. He decided to make his own 12 cylinder engine. He had a machine shop in his basement. The thread ran for years. It blew up.
So I think it is cool you are attempting this, and wish you the best of luck! You may want to try and source every existing part that would fit and design around them. Me, I would just drop an LS engine in there. But I seriously get where you are coming from! Here is the thread. It's 101 pages long. It will suck you in! And, there is no ending because some nastiness occurred and the admins shut it down. http://www.ferrarichat.com/forum/308-328/1...ion-begins.html |
veekry9 |
Apr 17 2014, 03:15 PM
Anything familiar?I hope you like the LED indicator,Anyone like? Turns out the Panamera has similar signals,fluke huh? A cleaner blue Targa 14 LeMan windscreen Less Aero glass first |
Lo-Fi Version | Time is now: 26th December 2024 - 09:27 PM |
