PIX, Pix Of Enlightenment |
veekry9 |
Oct 28 2013, 07:54 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Any Takers here?
Quote Flat 8 Porsche Engine A mate is making a flat 8 engine for a replica 908. He has used two 2.7lt magnesium blocks that we wirecut at my work and has welded them together in a jig. First time he has welded mag and it is a steep learning curve with the pre heating/jigging and post stress relieving. Here are the photos of his second attempt. He still has 1mm of bend after welding but is making a different jig that will be stronger and keep the heat more stable (he was saying 5 mins after welding and it was cool enough to handle). Unquote http://performanceforums.com/forums/showth...-Porsche-Engine from '11 |
Woody |
Oct 29 2013, 11:18 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Any Takers here? Quote Flat 8 Porsche Engine A mate is making a flat 8 engine for a replica 908. He has used two 2.7lt magnesium blocks that we wirecut at my work and has welded them together in a jig. First time he has welded mag and it is a steep learning curve with the pre heating/jigging and post stress relieving. Here are the photos of his second attempt. He still has 1mm of bend after welding but is making a different jig that will be stronger and keep the heat more stable (he was saying 5 mins after welding and it was cool enough to handle). Unquote http://performanceforums.com/forums/showth...-Porsche-Engine from '11 Why not use an aluminum case? |
balljoint |
Oct 29 2013, 12:34 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Because RACECAR!! (Mag is lighter.)
--DD |
veekry9 |
Oct 29 2013, 07:44 PM
Found some old links re:flat-8 at PerformanceForums
http://jalopnik.com/5799726/emerson-...kswagen-beetle https://www.youtube.com/watch?v=tXKcpbFF7WI "Excellent, the pressure is great, Today is March 19th, 2009, and tomorrow, we will be recorded for the show, 'Auto Esporte'. Good work Marco, Good work Arlindo" https://www.youtube.com/watch?v=Zto2UDCUyoY The vids have be online a few years. These guys make it look easy.Wanted a Flat-8,Made one. https://www.youtube.com/watch?v=nF9j6G4bkZg (IMG:style_emoticons/default/smilie_flagge24.gif) |
veekry9 |
Nov 1 2013, 06:13 PM
Some headway's been made
Custom flat-8 crank from Oz. http://www.performanceforums.com/forums/sh...he-Engine/page2 Can't be cheap. Building a 908 tribute from scratch,to a fine resolution. |
veekry9 |
Apr 6 2014, 02:06 PM
Fer sail Wider to fit,with or without flares. early corsa late corsa 8 (what a '77 914/911/944 morph looks like) nice crank.corvair aero app they are able to do -8's to similar specs 2.5K+ / |
billh1963 |
Apr 6 2014, 04:43 PM
Car Hoarder! Group: Members Posts: 3,405 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Any progress on welding the 2.7 cases together?
veekry9 |
Apr 6 2014, 07:38 PM
billh1963:
I looked at the performanceforum thd recently,and from what was described the case weldment requires further welding. Magnesium castings are no doubt difficult to do to a machined tolerance.He was able to get within 1mm(0.039")runout through the mains bores, which all things considered,is a notable success.So,some layup on the mainbores and parting faces to be remachined,to straighten it up X2. A ton of very difficult work.Inspired by their efforts,a minor change in plans will be applied to my own P14. The intent was to run the 2L until I found some issues with the valve guides,and since I now have the Corvair 6's,I believe the initial cost of a 14-6 will be tolerable, originality deferred temporarily.The idea of creating a flat 8 using Corvair blocks welded and machined can't possibly be original,though the net has not revealed an attempt. The CNC shop doing the billet corvair cranks are a likely source for a 90-degree 8 pin crank.A fewer number of main bearing pins may be a serious problem for the vibration characteristics of such a long crank.More research is needed. Here is a site (edit:11/05//15(http://www.pattakon.com/))that makes balance software available. The Porsche drawing I've posted here shows the 90 degree pins interspersed with the 0 degree pins. The 2 billet cranks made in Australia appear to be the other method,which I believe is the solution Porsche used to tame the harmonic vibrations inherent with the original design. The price of a crank made to these specs is not cheap,so what to do if you're really hankering for a flat 8?Cut weld...? (IMG:style_emoticons/default/lol-2.gif) Seriously,a talented welder with some rod may git er done.A lot of work. |
veekry9 |
Apr 15 2014, 12:02 PM
OK.here's the plan.. Get 2 sets of cases,and weld them together after machining the front and rear off each respective set. Front 2 and rear 2.Makes a long case to carry 8 cylinders. Look,if the guy in Aus can weld magnesium cases,it would have to be easier to do the same to 356 T6 alloy cases. Marginally easier admittedly,but possible to achieve the exalted F-8. Fun with TIG,in an oven,inert gas flushed... / (edit:08/08/16): Samba-2-4-6-8 http://www.thesamba.com/vw/forum/viewtopic.php?t=399470 Well,the fellow in Australia has the right idea,wire edm cutting the cases to key each other together. Still,tubular shafts,ground to the mains and cam dia +0.0004"/-0 for alignment is essential. Otherwise,a near hopeless adventure,preparation of the weld groove is critical,minimum weld added. Tough job,all around.For sure a worthy aspiration,wanting -8,pushrod even.More cylinders,more better. (IMG:style_emoticons/default/biggrin.gif) Even these cases could be sixed,356-6.Custom crossflow center head too. (IMG:style_emoticons/default/evilgrin.gif) A VW Boxer Six,a neato version of the Corvair engine. Clearly,a welded crank.Note the main journal's discoloration and heat affected zone. The -8 crank is done in a similar way,two -4 cranks welded together,90* apart. http://carocha.forumeiros.com/t477-transfo...com-8-cilindros Mounted Mid in a 914,this is the right side of the engine,pretty nice looking. I want to build a few,and I know,some of you want one too. Some real expertise demonstrated here,kudos.Note the cam nose profiles,long duration,mushroom lifters,a revver. (IMG:style_emoticons/default/clap.gif) / |
rick 918-S |
Apr 16 2014, 10:12 AM
Hey nice rack! -Celette Group: Members Posts: 20,825 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I like this! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
bulitt |
Apr 16 2014, 11:17 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
There was a guy....on Ferrari chat with some amazing machinist and tig welding skills, and allot of energy. He decided to make his own 12 cylinder engine. He had a machine shop in his basement. The thread ran for years. It blew up.
So I think it is cool you are attempting this, and wish you the best of luck! You may want to try and source every existing part that would fit and design around them. Me, I would just drop an LS engine in there. But I seriously get where you are coming from! Here is the thread. It's 101 pages long. It will suck you in! And, there is no ending because some nastiness occurred and the admins shut it down. http://www.ferrarichat.com/forum/308-328/1...ion-begins.html |
veekry9 |
Apr 17 2014, 03:15 PM
Anything familiar?I hope you like the LED indicator,Anyone like? Turns out the Panamera has similar signals,fluke huh? A cleaner blue Targa 14 LeMan windscreen Less Aero glass first |
veekry9 |
Apr 18 2014, 10:38 AM
Some Lip More Most FullFront Was Orange (iamchappy Mn) / |
veekry9 |
Apr 18 2014, 10:39 AM
There was a guy....on Ferrari chat.
Yeah. A few years ago Hemming's Exotic Cars did a cover story on the 308GT4 as an economical way to get some Stallions. (edit:05/07/16)"A few years ago"19 actually. (IMG:style_emoticons/default/dry.gif) http://www.ebay.com/itm/November-1997-Euro...x8AAOxyVaBS1IHX Bertone did a great job of integrating 4 seats and mid design transversely.The marketing department not so good. Like the 914 the GT4 was shunned by the illuminati.Paul Frere did a R+T road test in Upper Michigan in '74 and loved the car. Now stuffing a 400i V12 longitudinally and a modern 6-7 spd tapshift would wake it up. The objective being to maintain the brand of the prancing horse.Add the turbos and water+nitromethane injection ..How fast?220MPH+ fer sure. https://www.youtube.com/watch?v=Uu8qo93N1wM How to re+re your F-V12. Why I'll buy into the lottery.. (IMG:style_emoticons/default/lol-2.gif) (edit:11/05/15) https://www.youtube.com/watch?v=SZ9s3P34v9s (edit:04/24/16) https://www.youtube.com/watch?v=UMjUxqOWNSs https://www.youtube.com/watch?v=uA8poGGmPIU https://www.youtube.com/watch?v=SWwldtV9zBU http://alemala.xoom.it/alemala/ad308/body/308_upgrade.html https://www.youtube.com/watch?v=1jUz1AZKXFA https://www.youtube.com/watch?v=uO8xRNSUXkg https://www.youtube.com/watch?v=MNQBDqUkb6o https://www.youtube.com/watch?v=2WGgYN_PkIo / |
veekry9 |
Apr 18 2014, 12:24 PM
Hmmm...
Couldn't find the thd,What sitename? Lower longer..starting to look like a Can-Am with a 914 house on top. Hey,it does have a Can-Am engine.+Turbos! The large vents under the trunk floor will allow the flow of the massive heat generated by the powerplant,feeding the low pressure area behind the car at speed.Turbulent air under the car is drawn out. The width here is about as extreme as it should get. Still possible to add GT flares of narrower dimension. The reverse light is in factory position,the lens is merely wider by the widening amount. Not the easy way this is.You would need a metal surgeon to hammer and dolly the added strips of sheetmetal.The shape of the trunkline rear of the targa defines the intersecting transverse curve.The beltline then is lower.Raising the trunkline would help a lot,giving a humpier,bulging curve to the rear top quarter,sorto like the latemodel Aston-Martins. The focal length of the camera used foreshortens the image making it tricky to accurately sketch. Wider than the section cut.+2" Primordial DNA of the 914 Targa Bar. |
veekry9 |
Apr 18 2014, 02:20 PM
http://www.hollowsurfboards.com/documents/...Knistle1977.pdf
So..to shape some foam you first must use adhesive to attach it to the fenders. Then use the above methods the achieve the shape you desire. Modern epoxies and clothes are more suitable for insulation type polystyrene. If you are making your own mudgards(flares) it's possible to design,fabricate a unique look for your 914. At some point in the work-up to the LeMan '70 someone cut a washtub in half at the factory and said "yeah,that'll work". Don't get me wrong.I like the look,they were the solution of the day for the fat wheeled Porsches,the 911 too. The colour is very close to my own selection. A how-to: http://neilblanchard.blogspot.ca/ The Red-Transformer 914 is a notable design for it's outrageousness. Personally I regard this red 914 as a 10,being so well integrated. Very Nice,"Modern"EV from Switzerland. |
veekry9 |
Apr 18 2014, 06:06 PM
http://www.fiero.nl/forum/Forum3/HTML/000121-20.html http://lh4.googleusercontent.com/-D0XYb6GL...00/100_1866.JPG Need some gears? libertysgears http://www.libertysgears.com/ The scarcity of 904 mainshafts... |
veekry9 |
Apr 19 2014, 12:24 PM
[quote name='veekry9' date='Apr 18 2014, 02:24 PM' post='2026422']
Hmmm... Couldn't find the thd,What sitename?A lost reference,who? Lower longer..starting to look like a Can-Am with a 914 house on top. An incredible amount of labour and planning.A GT for LeMan,Daytona the Nurburgring.Gonna be quick. |
veekry9 |
Apr 19 2014, 05:44 PM
As an example of how design intent can go arwry..
YellowHorror Fat tires-check. Flares-check pseudo f40-check As you observe various auto designs,are you able to perceive rust and dents from a distance of 100 yds? Sure,so it is entirely possible to detect the shape of the fenders of a 911RSR. Expedient measures to cover the tires range from this to the shapely splined flanks of the 914. The necessity drive the invention. |
Lo-Fi Version | Time is now: 26th December 2024 - 07:11 AM |
