16 Pages V < 1 2 3 4 5 > »
> PIX, Pix Of Enlightenment
balljoint
post Oct 29 2013, 12:34 PM
Post #41
QUOTE(Dr Evil @ Oct 27 2013, 11:19 PM) *
I looks like a Fiero (IMG:style_emoticons/default/confused24.gif)
Yes. Yes, you do.
Dave_Darling
Post #42
914 Idiot
Because RACECAR!! (Mag is lighter.)
--DD
veekry9
post Oct 29 2013, 07:44 PM
Post #43
OldMember
Group: Retired Members
Found some old links re:flat-8 at PerformanceForums
http://jalopnik.com/5799726/emerson-...kswagen-beetle
https://www.youtube.com/watch?v=tXKcpbFF7WI
"Excellent, the pressure is great, Today is March 19th, 2009, and tomorrow, we will be recorded for the show,
'Auto Esporte'. Good work Marco, Good work Arlindo"
https://www.youtube.com/watch?v=Zto2UDCUyoY
The vids have be online a few years.
These guys make it look easy.Wanted a Flat-8,Made one.
https://www.youtube.com/watch?v=nF9j6G4bkZg
(IMG:style_emoticons/default/smilie_flagge24.gif)
veekry9
post Nov 1 2013, 06:13 PM
Post #44
OldMember
Some headway's been made
Custom flat-8 crank from Oz.
http://www.performanceforums.com/forums/sh...he-Engine/page2
Can't be cheap.
Building a 908 tribute from scratch,to a fine resolution.
veekry9
post Apr 6 2014, 02:06 PM
Post #45
OldMember
Fer sail
Wider to fit,with or without flares.
early corsa
late corsa 8
(what a '77 914/911/944 morph looks like)
nice crank.corvair aero app
they are able to do -8's
to similar specs 2.5K+
billh1963
post Apr 6 2014, 04:43 PM
Post #46
Car Hoarder!
Any progress on welding the 2.7 cases together?
veekry9
post Apr 6 2014, 07:38 PM
Post #47
OldMember
billh1963:
I looked at the performanceforum thd recently,and from what was described the case weldment requires further welding.
Magnesium castings are no doubt difficult to do to a machined tolerance.He was able to get within 1mm(0.039")runout through the mains bores,
which all things considered,is a notable success.So,some layup on the mainbores and parting faces to be remachined,to straighten it up X2.
A ton of very difficult work.Inspired by their efforts,a minor change in plans will be applied to my own P14.
The intent was to run the 2L until I found some issues with the valve guides,and since I now have the Corvair 6's,I believe the initial cost of a 14-6 will be tolerable,
originality deferred temporarily.The idea of creating a flat 8 using Corvair blocks welded and machined can't possibly be original,though the net has not revealed an attempt.
The CNC shop doing the billet corvair cranks are a likely source for a 90-degree 8 pin crank.A fewer number of main bearing pins may be a serious problem for the
vibration characteristics of such a long crank.More research is needed.
Here is a site (edit:11/05//15(http://www.pattakon.com/))that makes balance software available.
The Porsche drawing I've posted here shows the 90 degree pins interspersed with the 0 degree pins.
The 2 billet cranks made in Australia appear to be the other method,which I believe is the solution Porsche used to tame the harmonic vibrations inherent with the original design.
The price of a crank made to these specs is not cheap,so what to do if you're really hankering for a flat 8?Cut weld...? (IMG:style_emoticons/default/lol-2.gif)
Seriously,a talented welder with some rod may git er done.A lot of work.
veekry9
post Apr 15 2014, 12:02 PM
Post #48
OldMember
OK.here's the plan..
Get 2 sets of cases,and weld them together after machining the front and rear off each respective set.
Front 2 and rear 2.Makes a long case to carry 8 cylinders.
Look,if the guy in Aus can weld magnesium cases,it would have to be easier to do the same to 356 T6 alloy cases.
Marginally easier admittedly,but possible to achieve the exalted F-8.
Fun with TIG,in an oven,inert gas flushed...
(edit:08/08/16):
Samba-2-4-6-8
http://www.thesamba.com/vw/forum/viewtopic.php?t=399470
Well,the fellow in Australia has the right idea,wire edm cutting the cases to key each other together.
Still,tubular shafts,ground to the mains and cam dia +0.0004"/-0 for alignment is essential.
Otherwise,a near hopeless adventure,preparation of the weld groove is critical,minimum weld added.
Tough job,all around.For sure a worthy aspiration,wanting -8,pushrod even.More cylinders,more better.
Even these cases could be sixed,356-6.Custom crossflow center head too.
(IMG:style_emoticons/default/evilgrin.gif)
A VW Boxer Six,a neato version of the Corvair engine.
Clearly,a welded crank.Note the main journal's discoloration and heat affected zone.
The -8 crank is done in a similar way,two -4 cranks welded together,90* apart.
http://carocha.forumeiros.com/t477-transfo...com-8-cilindros
Mounted Mid in a 914,this is the right side of the engine,pretty nice looking.
I want to build a few,and I know,some of you want one too.
Some real expertise demonstrated here,kudos.Note the cam nose profiles,long duration,mushroom lifters,a revver.
(IMG:style_emoticons/default/clap.gif)
rick 918-S
post Apr 16 2014, 10:12 AM
Post #49
Hey nice rack! -Celette
I like this! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
bulitt
post Apr 16 2014, 11:17 AM
Post #50
Achtzylinder
There was a guy....on Ferrari chat with some amazing machinist and tig welding skills, and allot of energy. He decided to make his own 12 cylinder engine. He had a machine shop in his basement. The thread ran for years. It blew up.
So I think it is cool you are attempting this, and wish you the best of luck! You may want to try and source every existing part that would fit and design around them.
Me, I would just drop an LS engine in there. But I seriously get where you are coming from!
Here is the thread. It's 101 pages long. It will suck you in! And, there is no ending because some nastiness occurred and the admins shut it down.
http://www.ferrarichat.com/forum/308-328/1...ion-begins.html
veekry9
post Apr 17 2014, 03:15 PM
Post #51
OldMember
Anything familiar?I hope you like the LED indicator,Anyone like?
Turns out the Panamera has similar signals,fluke huh?
A cleaner blue Targa 14 LeMan windscreen
Less Aero glass
first
veekry9
post Apr 18 2014, 10:38 AM
Post #52
OldMember
Some Lip
More
Most
FullFront Was Orange (iamchappy Mn)
veekry9
post Apr 18 2014, 10:39 AM
Post #53
OldMember
There was a guy....on Ferrari chat.
Yeah.
A few years ago Hemming's Exotic Cars did a cover story on the 308GT4 as an economical way to get some Stallions.
(edit:05/07/16)"A few years ago"19 actually. (IMG:style_emoticons/default/dry.gif)
http://www.ebay.com/itm/November-1997-Euro...x8AAOxyVaBS1IHX
Bertone did a great job of integrating 4 seats and mid design transversely.The marketing department not so good.
Like the 914 the GT4 was shunned by the illuminati.Paul Frere did a R+T road test in Upper Michigan in '74 and loved the car.
Now stuffing a 400i V12 longitudinally and a modern 6-7 spd tapshift would wake it up.
The objective being to maintain the brand of the prancing horse.Add the turbos and water+nitromethane injection ..How fast?220MPH+ fer sure.
https://www.youtube.com/watch?v=Uu8qo93N1wM
How to re+re your F-V12.
Why I'll buy into the lottery..
(edit:11/05/15)
https://www.youtube.com/watch?v=SZ9s3P34v9s
(edit:04/24/16)
https://www.youtube.com/watch?v=UMjUxqOWNSs
https://www.youtube.com/watch?v=uA8poGGmPIU
https://www.youtube.com/watch?v=SWwldtV9zBU
http://alemala.xoom.it/alemala/ad308/body/308_upgrade.html
https://www.youtube.com/watch?v=1jUz1AZKXFA
https://www.youtube.com/watch?v=uO8xRNSUXkg
https://www.youtube.com/watch?v=MNQBDqUkb6o
https://www.youtube.com/watch?v=2WGgYN_PkIo
veekry9
post Apr 18 2014, 12:24 PM
Post #54
OldMember
Hmmm...
Couldn't find the thd,What sitename?
Lower longer..starting to look like a Can-Am with a 914 house on top.
Hey,it does have a Can-Am engine.+Turbos!
The large vents under the trunk floor will allow the flow of the massive heat generated by the powerplant,feeding the low pressure area behind the car at speed.Turbulent air under the car is drawn out.
The width here is about as extreme as it should get.
Still possible to add GT flares of narrower dimension.
The reverse light is in factory position,the lens is merely wider by the widening amount.
Not the easy way this is.You would need a metal surgeon to hammer and dolly the added strips of sheetmetal.The shape of the trunkline rear of the targa defines the intersecting transverse curve.The beltline then is lower.Raising the trunkline would help a lot,giving a humpier,bulging curve to the rear top quarter,sorto like the latemodel Aston-Martins.
The focal length of the camera used foreshortens the image making it tricky to accurately sketch.
Wider than the section cut.+2"
Primordial DNA of the 914 Targa Bar.
veekry9
post Apr 18 2014, 02:20 PM
Post #55
OldMember
http://www.hollowsurfboards.com/documents/...Knistle1977.pdf
So..to shape some foam you first must use adhesive to attach it to the fenders.
Then use the above methods the achieve the shape you desire.
Modern epoxies and clothes are more suitable for insulation type polystyrene.
If you are making your own mudgards(flares) it's possible to design,fabricate
a unique look for your 914.
At some point in the work-up to the LeMan '70 someone cut a washtub in half
at the factory and said "yeah,that'll work".
Don't get me wrong.I like the look,they were the solution of the day for the fat wheeled Porsches,the 911 too.
The colour is very close to my own selection.
A how-to:
http://neilblanchard.blogspot.ca/
The Red-Transformer 914 is a notable design for it's outrageousness.
Personally I regard this red 914 as a 10,being so well integrated.
Very Nice,"Modern"EV from Switzerland.
veekry9
post Apr 18 2014, 06:06 PM
Post #56
OldMember
http://www.fiero.nl/forum/Forum3/HTML/000121-20.html
http://lh4.googleusercontent.com/-D0XYb6GL...00/100_1866.JPG
Need some gears?
libertysgears
http://www.libertysgears.com/
The scarcity of 904 mainshafts...
veekry9
post Apr 19 2014, 12:24 PM
Post #57
OldMember
[quote name='veekry9' date='Apr 18 2014, 02:24 PM' post='2026422']
Hmmm...
Couldn't find the thd,What sitename?A lost reference,who?
An incredible amount of labour and planning.A GT for LeMan,Daytona the Nurburgring.Gonna be quick.
veekry9
post Apr 19 2014, 05:44 PM
Post #58
OldMember
As an example of how design intent can go arwry..
YellowHorror
Fat tires-check.
Flares-check
pseudo f40-check
As you observe various auto designs,are you able to perceive rust and dents from a distance of 100 yds?
Sure,so it is entirely possible to detect the shape of the fenders of a 911RSR.
Expedient measures to cover the tires range from this to the shapely splined flanks of the 914.
The necessity drive the invention.
HalfMoon
post Apr 19 2014, 06:49 PM
Post #59
QUOTE(veekry9 @ Apr 6 2014, 04:06 PM) *
Fer sail
early corsa
late corsa 8
to similar specs 2K?+
Lol!
Hey, that's my LE saved only days before the PO was going to have it crushed! It's stored in my garage until I can do a full on roto resto :-)
Cool what you did, but it'll be bone stock concourse when completed (years from now, lol)
veekry9
post Apr 20 2014, 01:53 PM
Post #60
OldMember
Lol!
Another Save!RestorationDesign has the sheetmetal replacements you desire.
A tall task on the horizon,requiring stamina and fortitude.Never give up,never surrender(Wittwickie).A polished gem at the end,close to perfection,reflecting.
- Lo-Fi Version Time is now: 24th December 2024 - 06:56 PM
