16 Pages V « < 2 3 4 5 6 > »
> PIX, Pix Of Enlightenment
bulitt
post Apr 20 2014, 02:39 PM
Post #61
Achtzylinder
Here is your thread- http://www.914world.com/bbs2/index.php?showtopic=219539
bulitt
post Apr 20 2014, 02:40 PM
Post #62
Achtzylinder
(IMG:http://www.914world.com/bbs2/uploads/post-16025-1397928741.jpeg)
veekry9
Post #63
OldMember
Group: Retired Members
Thanks bulitt.
OK,so,you need a Wider Fender...Note to self,drive-ability makes good parts.
A raised trunkline,taller from the trunk floor.
Wider lens + taller too.Starting to look like 944/968/928 pieces,fitting really,that the parts would serve a similar purpose.
Some resemblance to the family tree.
veekry9
post Apr 21 2014, 12:54 PM
Post #64
OldMember
Pushing G
914 evolved 1978?
veekry9
post Apr 22 2014, 12:27 PM
Post #65
OldMember
Merely widened fenders+doors.
Does it still evoke the 914,spoilers n all?
How bout now?3" stretch behind the targa curve.
Two tone anodized Fuchs 4-stud.A bronze/titanium,rim polished.
Polished alloy or chromed outer rocker.
LED aero turn indicator.(spoke?)
If you measure your door thickness add 3-4" for this result.
I can add the front fender vent and the engine oil cooler scoop as well as an intrusion barrier/cage bar with the extra width.Form follows funktion.
2-3"Rise at the trunk line,to accomodate intercooler opening.
Caramel pearl med metallic.
Zagato
Meringue
Scarlet
YoMaMa Blue
Ice Silver
veekry9
post May 18 2014, 12:48 PM
Post #66
OldMember
More Radical
Fatter Tires/Wheels,Taller Rear quarters.
More room for the intercoolers,placed mid.
veekry9
post May 18 2014, 12:57 PM
Post #67
OldMember
Where the idea began.As a kid,building the the scale model.
veekry9
post May 27 2014, 06:58 PM
Post #68
OldMember
SilverQuarter-9
The larger tail-lamps remove any semblance to 914 and move into the 924 family.
An exercise in fitting the rads/intercoolers amidships,without adding lumps.
17" and low profile tires fit the enlarged w-wells in a modern way.
A '66 Mustang is showing its influence,difference being the vents are functional.
This will be a long time coming,a ton of work.
veekry9
post Jun 4 2014, 10:56 PM
Post #69
OldMember
into the realm of a full custom
Some details to be determined..without the 3"stretch.Navy Targa Vinyl.
I recall one of the early "models in clay" sported headlamps of similar shape.
Mid mounted coolers do two things,eliminate long lines and retain a centralized cg.
Not really 914+944,or change for changes sake,more like what if?
In '67 a pencil and plasticine was used.
bulitt
post Jun 5 2014, 04:33 AM
Post #70
Achtzylinder
Looks like the door gaps on my first tub... (IMG:style_emoticons/default/blink.gif)
7TPorsh
post Jun 5 2014, 09:53 AM
Post #71
7T Porsh
Always thought this was interesting....
jaxdream
post Jun 5 2014, 10:03 AM
Post #72
QUOTE(veekry9 @ Jun 4 2014, 08:56 PM) *
While you are designing , why not spring for some cool 911 headlight treatments , maybe some of the MB headlight setups to the turn signal locations ??? Do away with the flip ups , relocate the turn signals to another location ??? I've always wanted to install 911 headlights in that spot , just have to do some creative fab work , but with thesee fender widening on these pics it would be very doable , but however it's your project not mine , good luck to ya !!!
Jack
veekry9
post Jun 5 2014, 11:53 AM
Post #73
OldMember
Very Neat,I haven't seen that treatment before now.
At the time,the 'new"designers were transitioning away from the "headlamp sponson"look that had prevailed for the previous 20 yrs.
Hence the truncated headlamp turnsignal of the 914.
We enjoy the look today,but in '69, it was like,so different.
The simplicity of the slab-sided spline curves provide a surface on which to sculpt some detail,to make room for coolers and larger rubber.
veekry9
post Jun 5 2014, 12:16 PM
Post #74
OldMember
While you are designing , why not spring for some cool 911 headlight treatments...
Yeah,the amount of time to make the changes to the shapes of the curves has been reduced electronically.To bang metal requires the traditional amount.
I've considered a number of headlamp designs,and really like the clearlense 914 HID look a member here has done.(edit:05/03/15 neo914-6)
As I go further,I am becoming more inclined toward a Boxster trioval shape.I agree the flip-ups now look more redundant.
A work in progress,although the raised trunk-line does it for me,transforming the 914's simple splinecurves into an aggressive look that appeals with the massive airscoops.
The GIMP software allows fast work in concept visualization.
http://en.wikipedia.org/wiki/GIMP
http://www.gimp.org/downloads/
worn
post Jun 5 2014, 12:45 PM
Post #75
can't remember
QUOTE(sixnotfour @ Oct 21 2013, 05:43 PM) *
Why on earth would you bother with a push rod engine ?? (IMG:style_emoticons/default/confused24.gif)
I believe that is a quote from Ferrari to Henry Ford. Before the race. (IMG:style_emoticons/default/av-943.gif)
veekry9
post Jun 5 2014, 01:11 PM
Post #76
OldMember
QUOTE(worn @ Jun 5 2014, 02:45 PM) *
Yeah,the pushrod has been touted as primitive,do they still make them?
Yup.
veekry9
post Aug 20 2014, 06:40 PM
Post #77
OldMember
Found today..
I've not seen this here.
It even has side inlets,
the wheelarches look unique enough.
All that's missing is a proper targa bar.
2008 model showcar.
Does this appeal to any 914 owners?
a few more
https://www.google.ca/search?q=2008+vw+road...tml%3B500%3B225
veekry9
post Sep 6 2014, 02:37 AM
Post #78
OldMember
Widebody.
Looks so right,the only one I've seen done like this.
from paul's thd Post #58160
veekry9
post Sep 6 2014, 07:28 AM
Post #79
OldMember
every time I see this car the more I like it.
anyone on board?
Cuda911
post Sep 6 2014, 07:42 AM
Post #80
A friend of mine bought this one, but it overheated and crapped out on the way home, so seller took it back.
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th December 2024 - 07:18 PM
