PIX, Pix Of Enlightenment |
veekry9 |
Sep 6 2014, 07:28 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
every time I see this car the more I like it. anyone on board? |
Cuda911 |
Sep 6 2014, 07:42 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
A friend of mine bought this one, but it overheated and crapped out on the way home, so seller took it back.
. Attached thumbnail(s) |
Sleepin |
Sep 6 2014, 08:42 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
veekry9 |
Sep 6 2014, 08:58 AM
that way you have more space between the seats,for a cup holder.
the driver even looks like me. |
veekry9 |
Sep 6 2014, 09:19 AM
Same car,right?-6 |
veekry9 |
Sep 6 2014, 09:55 AM
MoveQik |
Sep 6 2014, 04:10 PM
What size wheels can I fit? Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Same car,right?-6 Its an AZ car. I see him at a local car show now and then. Currently, it is still a 1.7. Attached thumbnail(s) |
veekry9 |
Sep 6 2014, 09:36 PM
There are so many details that appeal.
When shaving the siglamps,most don't retain them. Rolling the rockerpan looks right. I even like the colour. |
MoveQik |
Sep 7 2014, 07:32 AM
There are so many details that appeal. When shaving the siglamps,most don't retain them. rolling the rockerpan looks right. I even like the colour. Here are a few more pics from the last time I saw it at a show... Gulf 914 |
veekry9 |
Sep 7 2014, 09:53 AM
Thnks MovQuik
I guess it is the gulf colours that suit the front fender treatment. The top chop is well done,the cage is closely fitted. yup,does it for me,very nice rendition. |
veekry9 |
Sep 7 2014, 12:01 PM
veekry9 |
Sep 9 2014, 10:53 PM
http://www.gt40s.com/forum/gt40-tech-engin...v12-clevor.html http://vid398.photobucket.com/albums/pp62/...zps4d163946.mp4 https://docs.google.com/file/d/0B3S4fQeJ60C...t?usp=drive_web https://docs.google.com/file/d/0B3S4fQeJ60C...t?usp=drive_web https://docs.google.com/file/d/0B3S4fQeJ60C...t?usp=drive_web Get 2 engines,cut and rejoin to build a bigger better engine of your dreams. What could you do with a 9L 90* Ford V-12? What could you do with a 4-5L 32 valve flat-8? Found a link to an old thd here: http://www.914world.com/bbs2/index.php?sho...amp;hl=beck+gt1 2006-2012 jump,a brief interlude. so yeah,a lot of discussion of the same idea. also found the address of Mr Lind of Sweden. http://home.swipnet.se/motor/custom/ Not only can it be done ,it Should be done. A 914-8.aircooled..must have. |
Sleepin |
Sep 9 2014, 11:12 PM
If it wasn't such a boat anchor, the air cooled Tatra 8 would be cool
(IMG:http://www.914world.com/bbs2/uploads_offsite/bringatrailer.com-8357-1410325948.1.jpg) |
veekry9 |
Sep 9 2014, 11:52 PM
In Europe,the Tatra aircooled V8 has been used for many unique projects.
Traditional 90*v8 layout A lightweight v8 bike Q However, Tatra came up with some very special concepts and innovations under the hood as well. Which technical details were most significant? Ivan Margolius: The lightweight air-cooled rear engines V8 and flat 4, swiveling headlights, swing axles, forced fan-assisted cooling and flat undersides. Q Haven't looked into the aftermarket for these engines,if it exists. http://www.tatraplan.co.uk/ looks modern yup,modern An auto company with a huge history. / (edit:08/07/16): http://www.914world.com/bbs2/index.php?showtopic=61581 Some time later,more info became available. SuperBug-2.5L V8 (Bore:75mm X Stroke:72mm) Incredibly,snuggled into the behind. So yeah,with some careful measurement and mods,one could slip right in to your 914,smoothly. (IMG:style_emoticons/default/biggrin.gif) / |
veekry9 |
Sep 10 2014, 12:10 AM
veekry9 |
Sep 10 2014, 12:54 AM
https://www.youtube.com/watch?v=hfqZ2XBOVnk first on many innovations https://www.youtube.com/watch?v=A_7ISJ57ZYU sounds like a v8 https://www.youtube.com/watch?v=WJdowd5zQfU 1937 sohc hemi v8 magnesium. https://www.youtube.com/watch?v=E0UkeJb8CCE A latemodel,carbed |
veekry9 |
Sep 14 2014, 11:28 AM
at speeed. A great idea,now,where is that flat -8,pushrod even. To accommodate said long-block,a wb stretch would make a perfect fit. |
Hank914 |
Sep 14 2014, 12:00 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
In Europe,the Tatra aircooled V8 has been used for many unique projects. Traditional 90*v8 layout A lightweight v8 bike Q: However, Tatra came up with some very special concepts and innovations under the hood as well. Which technical details were most significant? Ivan Margolius: The lightweight air-cooled rear engines V8 and flat 4, swiveling headlights, swing axles, forced fan-assisted cooling and flat undersides. Haven't looked into the aftermarket for these engines,if it exists. http://www.tatraplan.co.uk/ looks modern yup,modern An auto company with a huge history. Huge history! I remember seeing Dubcek and Svoboda cruising around Praha and Bratislava in 603! And then in the 70's them orders 613 model. Only the party big wigs got to be driven in those cars. Ahhh, great memories of the utopian socialism of CSSR and CCCP! And the pivo! Don't forget the pivo! (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
veekry9 |
Sep 14 2014, 01:34 PM
Come to think of it,those highpressure dies quite likely still exist. The entire GM Corvair production diesets were scrapped in the 70's. But things are done differently there,as the dies are of great value,even now. Do you see anything you like?An alloy aircooled v8 of aircraft design philosophy. Lightweight,compact,easily manufactured,similar in design to the vw and corvair. hemi design canted valve in pushrod and dohc configuration,sophisticated. this is the H-4,chain driven sohc,1937. pushrod -4 |
Lo-Fi Version | Time is now: 25th December 2024 - 06:58 AM |
