PIX, Pix Of Enlightenment |
veekry9 |
Sep 14 2014, 02:19 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
T603 engine designed by Julius Mackerle. http://www.eurospares.com/graphics/engine/...searcheable.pdf (thanks jd74914 ) By raising the camshaft far above the crank in the valley,the rocker geometry for the exhaust valve is improved,perhaps making possible the use of common rockers throughout. Note the hemi-like chamber and wide angle canted valves.Like the VW/Porsche and Corvair,the bore diameter is restricted by the cylinder head studs. A considerable amount of weight savings would be realized by adopting LN cylinders. I believe the crank is a conventional cross plane and at a small 72mm stroke,there may be plenty of room for a much larger stroker. http://www.velocetoday.com/a-technical-history-of-tatra/ The discrete lifter-blocks allow replacement roller-lifter and barrels to be installed for low friction,high rpm operation. |
veekry9 |
Sep 14 2014, 02:50 PM
V-12 aircooled diesel,3-cam. The same designer,Doctor Prof. Julius Mackerle. Roller bearing bottom end. V-10 version https://www.youtube.com/watch?v=4S1Ft4ots7g (edit:2/23/16) https://www.youtube.com/watch?v=MCwHl885-m4 Anyone onboard able to translate his spoken words? Looks like an interesting project,a diesel conversion. / Tatra 613 unfinished project - Diesel. Unique project of rebuilding the engine T613 (aggregate) on diesel variant. At the end of the 70th century originated minuléto years so far unique project for rebuilding the engine on the T613 diesel engine with direct fuel injection into the cylinder. As a base engine was used T613 (model E) production year 1977, which had traveled 20 thousand. km. The creation of new pistons with a semicircular shape of the bottom of the piston has been redesigned combustion chamber cylinder heads were modified cabinets cam engine was devised to drive fuel injectors, all this was preceded by a complex formulation of models later casts, followed by manufacture themselves cast as pistons and various components, from which the formed parts for driving the injection pumps, produced with a special injector, it was necessary to devise and make special threaded shaft for installation into enclosures injectors cams and cylinder heads. further information only serious and technically savvy candidates. This project is a testament to immense creativity and skill of the Moravian-wise and because the owner of this concept does not want to make this engine ended up in scrap, looking for this very technical and design an efficient, technologically savvy real enthusiasts Tatrovaks heart for engines Tatra, which this project dotáhnul to successful end. The owner of both the engine and the entire project, originator of the idea itself is ready to provide serious, but it really only serious candidates all technical and knowledge support to complete this project successfully. The owner, however, asks dealers and speculators, who, on this project, they just want to earn without it without touching anything, so this video in any way responded. P.S. The video is mistakenly stated that the year of manufacture of the engine is 1997 correctly's 1,977th / |
veekry9 |
Sep 14 2014, 03:13 PM
What's not to like?An alloy hemi V8. And it's "Teutonic". https://www.youtube.com/watch?v=WEFJ9kkFGN0 6:1 comp 2.5 L aircooled V8,just add turbo. |
veekry9 |
Sep 14 2014, 04:07 PM
single seater t507 bvlv originally designed to test new aluminum V8 engine with OHV prepared personally for uozv Tatra 603 http://www.jalopyjournal.com/forum/threads...hemi-v8.484366/ A link to some q+a. |
veekry9 |
Sep 14 2014, 06:10 PM
Mid engine alloy hemi pushrod V8. model 603 2.5L,75X72mm BXS. A step up is the model 613,4cam,16v 3.5L engine. 85x77mm BXS model 700 4.4L efi produced until '9x? |
veekry9 |
Sep 14 2014, 08:19 PM
Well,someone out there in the hinterlands of the E.U. must have a handle on these lightweight V8s.
If not,an Opportunity exists to meet the demand for the unique small 4+8 zylinders. Other than auto applications,a kitplane aero app may move a few of them. Simply gather as many pieces that you can and put up an Ebay/Samba for sale sign. I'm somewhat surprised that a VW/Porsche fan from the Continent hasn't considered a powerplant of such attributes. A further question regarding the dimensions of the bore spacing and cylinder stud pattern remain unanswered. Scaling a photo may derive a close number,but only close. https://www.youtube.com/watch?v=wLUGSm6Th-Q Judging by the positive reaction on virtually every blog and posting for the last decade,a surprising number of wrenchers would like to have such engines. And to think the Ford V8 of '32 was it's contemporary. In hindsight now,it's no surprise that the ArDun head for the Fhead Ford used a similar,independent latest big breathing pentroof/crescent design. An aftermarket to develop hotrod parts for the engine never happened. Rollertip rockers,rollerlifters,modern valves,all the things you would do to your aircooled VW,Porsche,Corvair,Hirth,Rotax... I haven't seen anyone other than the factory turbo the engines,so,you could be the first. Could be fun. |
veekry9 |
Sep 14 2014, 10:57 PM
Tatra 613 4.4L DOHC 16V aircooled appears to be 6spd transaxle from a front drive vehicle,Getrag?.(edit:11/10/15)All Tatra ,6spdSuitable for 4X4,6X6. http://translate.google.ca/translate?hl=en...440%26bih%3D712 http://www.tatra603team.cz/ http://www.youtube.com/watch?v=qtzpRBuJmPw...gdTROrvzuXCZL1Q http://www.youtube.com/watch?v=GKwPoKhJh5g...L1Q&index=4 (some Sabbath involved.Heavy metal,for those unfamiliar with the genre) 4-cam valve action,sounds good.note the convenient covers between the cams,to adjust lash quickly.400hp na. A nice design from the time of Elvis. a link to the car designer's story. http://translate.google.ca/translate?hl=en...440%26bih%3D712 http://ommszem.blog.hu/2007/10/11/fiokba_zart_gran_turismo a real beauty, https://www.youtube.com/watch?v=ao5OF7EXDcw A nice one,utility,military application,Will fit nicely into a 914,a 4x4 914! Yes,a 924/944 early differential,cvs,axles,a custom upright to carry the hub. A few details and some hotrod tech,and a short stroke turbo screamer to make it all good. A good deal if you can acquire them. A quest for a European,or a source of parts for the next custom X-12. Not only possible,but imperative. |
3d914 |
Sep 15 2014, 08:08 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Have you seen these? Both are design built around the 914 unibody. Either would be interesting to refine/update.
Hispano-Aleman Or the Tapiro: Link with pics |
veekry9 |
Sep 16 2014, 12:41 AM
Frua,driven at speed. One off,elegant design. |
veekry9 |
Sep 16 2014, 07:02 AM
PX A nice airy glass house. A 6 under glass like the wheels now,always did. |
7TPorsh |
Sep 16 2014, 12:14 PM
Sep 16 2014, 12:36 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Weird. The front is definitely five-bolt, the rear looks like four-bolt.
EDIT: Looking at the pics on the website linked shows they were all five-bolt. So the four-bolt look must be an illusion. Probably the "uneven" part of the bolt pattern (where it does not match with the eight spokes) is out of sight on that rear wheel. --DD |
7TPorsh |
Sep 16 2014, 02:16 PM
yep, 5 bolt. % in the center square, neat
veekry9 |
Sep 16 2014, 02:48 PM
Have you seen these? Both are design built around the 914 unibody. Either would be interesting to refine/update. Sure,a great idea,rather than purchasing an off the rack auto,make a custom. California is a goldmine of automotive design/build talent. Start like we all did,scratching our "Lambo"with a pencil on the back page of notebooks.Mockup scale models and when the results please you,move to full-size mounted on the recipient Fiero chassis.Beat alloy panels into shape over wooden bucks like Bertone or layup into a mold pulled from a buck. So yeah,a huge effort is required,and at the end you may have something like a Bradley or (hopefully) a Frua 914.I suppose that is why I can appreciate the results Eberhard Shulz attained with his Imperator 108 in the '70s.A verbatim replica of others work would not suffice,so he designed and built his own.An achievement like that requires more than a passing knowledge of design and manufacture. It all starts with an idea,so determine what your quest is then blaze a path. a good example of a nicely integrated design A perfect example of meticulous,determined construction methods. wow http://www.gt40s.com/forum/wings-wheels-ke...0-dreaming.html Bruce McLaren"woosh bonk...done" |
veekry9 |
Sep 16 2014, 08:07 PM
Post #70560
first look,a 356RSR,love |
veekry9 |
Sep 16 2014, 08:50 PM
As an example of how design intent can go arwry.. YellowHorror Fat tires-check. Flares-check pseudo f40-check As you observe various auto designs are you able to percieve rust and or dents from a distance of 100 yds?Sure,so it is entirely possible to detect the shape of the fenders of a 911rsr.Expedient measures to cover the tires range from this to the shapely splined flanks of the 914. The necessity drives the invention. Post #90543 funny thing,found. from this angle it looks better. the addition of discrete features+nasa ducts (edit:07/09/16) A relic of the past,it has grown on me. (IMG:style_emoticons/default/smile.gif) Kinda has some F40 details,V8 too. |
veekry9 |
Sep 17 2014, 07:31 AM
veekry9 |
Sep 17 2014, 09:12 AM
914 CopyCats Nope, Ferrari 308GT4 Maserati Bora Maserati Merak Fiat X19 BMW M1 DeTomaso Pantera DeTomaso Mangusta http://en.wikipedia.org/wiki/Pontiac_Fiero The idea of a low powered runabout with a mid mounted transverse engine was a demonstration of technology sophistication. The engineering that went into the stamped steel chasssis produced a rigid crash safe exoskeleton. The only production mid of America. Check the prices of that poor car and compare to any other mid. (edit:05/05/16) 80 mph transverse rollover crash tests passed. http://www.italdesign.it/en/projects/ford-maya-iies-eng/ http://www.fiero.nl/cgi-bin/fiero/Ultimate.cgi?action=intro All that's required is a dieman to create repair panels for the chronic rust areas. Then add lightweight power for a decent mid sportster. Different crash safety requirements,the reason for the 914's cancellation. |
Sleepin |
Sep 17 2014, 10:39 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
veekry9 |
Sep 17 2014, 10:53 AM
The more I more I consider the cylinder heads of the 4cam 613,the more I'm inclined to think they may fit quite easily onto a Corvair shortblock.
Gears are turning here. A flat 6 or 8 from the Carpathian Mountains. Bolts? Sure, I've got Bolts. http://ffilms.org/young-frankenstein-1974/ |
Lo-Fi Version | Time is now: 24th December 2024 - 06:54 PM |
