FS: A/C Compressor Kit, Mounts to top of Engine |
dlee6204 |
Oct 21 2013, 10:44 AM
I'm offering for sale a complete kit in order to mount an A/C compressor on top of the motor which requires no cutting to the engine shelf. I've been running a similar setup for some time with good results. (See this thread here : http://www.914world.com/bbs2/index.php?showtopic=192917) The compressor mounts directly to a non-smog engine fan shroud with no cutting or drilling.
This kit includes: Compressor Mount Puller Adapter Plated Pulley Hardware Belt A few notes: -The compressor is currently set up to run R12. In order to run R134 the oil in the compressor needs to be changed out. I can do this for the cost of oil. -The compressor fits without any major cutting or drilling however there may be interference with the engine bay insulating pad so minor modification to the pad may be necessary. -A swivel allen wrench will be necessary to install the pulley adapter. -Cosmetically the welds didn't come out perfect as I would have liked so if I make any more, they will be at a slightly increased price. This mount is still 100% functional as is. -This kit, in theory, can be mounted with the engine in the car with the removal of the front tin. Price: $360+Shipping If you have any questions, just ask. (IMG:style_emoticons/default/beerchug.gif) |
914itis |
Oct 21 2013, 12:58 PM
Sweet, Just when I swapped my motor to a six.
Anything available for the six? |
cgnj |
Oct 21 2013, 01:04 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
You know I followed this project.
PM sent |
dlee6204 |
Oct 21 2013, 01:43 PM
bulitt |
Oct 22 2013, 04:10 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Doug- You need to post this over in the vendor section so it doesn't get lost.
pvollma |
Sep 9 2014, 09:40 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
I'm offering for sale a complete kit in order to mount an A/C compressor on top of the motor which requires no cutting to the engine shelf. I've been running a similar setup for some time with good results. (See this thread here : http://www.914world.com/bbs2/index.php?showtopic=192917) The compressor mounts directly to a non-smog engine fan shroud with no cutting or drilling. Price: $360+Shipping If you have any questions, just ask. (IMG:style_emoticons/default/beerchug.gif) I have a 1976 2.0, that originally came with an air pump, but the pump has been removed by the PO. Can this kit still work, or can it be modified to work? |
RohJay |
Oct 1 2016, 05:35 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
Are any of these components still available?
I'm interested in the Pulley with adapter and Compressor bracket. Thanks |
Guti 914 |
Feb 11 2019, 03:18 AM
I'm new here ... Group: Members Posts: 0 Joined: 9-February 19 From: Spain Member No.: 22,860 Region Association: Europe |
I want to know if you can send it to Spain (Europe), or at least that you could send me the plans with measures to do it myself here. I want to install air conditioning to my 914 and the idea that you have invented seems great to me. Thanks a lot. |
petlan55 |
Dec 15 2019, 10:48 AM
Newbie Group: Members Posts: 4 Joined: 25-May 18 From: Winfield,KS Member No.: 22,152 Region Association: None |
I'm offering for sale a complete kit in order to mount an A/C compressor on top of the motor which requires no cutting to the engine shelf. I've been running a similar setup for some time with good results. (See this thread here : http://www.914world.com/bbs2/index.php?showtopic=192917) The compressor mounts directly to a non-smog engine fan shroud with no cutting or drilling. This kit includes: Compressor Mount Puller Adapter Plated Pulley Hardware Belt A few notes: -The compressor is currently set up to run R12. In order to run R134 the oil in the compressor needs to be changed out. I can do this for the cost of oil. -The compressor fits without any major cutting or drilling however there may be interference with the engine bay insulating pad so minor modification to the pad may be necessary. -A swivel allen wrench will be necessary to install the pulley adapter. -Cosmetically the welds didn't come out perfect as I would have liked so if I make any more, they will be at a slightly increased price. This mount is still 100% functional as is. -This kit, in theory, can be mounted with the engine in the car with the removal of the front tin. Price: $360+Shipping If you have any questions, just ask. :beer2 if possibl: Hello, I am hoping to purchase a pulley addapter if that is still possible. My effort is using a serpentine belt and a micro "vane style" pump that are now available. Thanks, Peter |
friethmiller |
Mar 6 2020, 01:58 PM
Member Group: Members Posts: 463 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Doug, Can I get the kit minus the compressor?
Superhawk996 |
Mar 7 2020, 09:33 AM
914 Guru Group: Members Posts: 5,749 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Doug, Can I get the kit minus the compressor? (IMG:style_emoticons/default/agree.gif) I would be intersted in the same. Surprised the compressor is set up for R-12 with is virtually NLA . . . we'll not quite but stupid expensive none the less. Great work on putting this together. |
Literati914 |
Mar 7 2020, 11:58 AM
Senior Member Group: Members Posts: 1,437 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
This thread is from 2013 guys, Doug's not replied since then.
I'd love these items too, preferably in aluminum if possible. |
Superhawk996 |
Mar 7 2020, 12:53 PM
This thread is from 2013 guys, Doug's not replied since then. I'd love these items too, preferably in aluminum if possible. (IMG:style_emoticons/default/headbang.gif) Completely missed that! Bummer! |
friethmiller |
Mar 11 2020, 11:38 AM
I was hoping he was still active and would reply. Guys, just bought the A/C kit from Classic Auto Air for my '74. A/C isn't an option down here in TX. I'm going to have to do enough cutting as it is and I don't want to cut into the engine tin/self, if i don't have to. I didn't see anything in the vendor area. Thoughts?
BeatNavy |
Mar 11 2020, 04:09 PM
Why doesn't someone PM him? He's still active here on the World (he was logged on today). Maybe he's not paying attention to the classifieds.
Literati914 |
Mar 11 2020, 05:15 PM
BeatNavy |
Mar 11 2020, 05:53 PM
Why doesn't someone PM him? He's still active here on the World (he was logged on today). Maybe he's not paying attention to the classifieds. I thought I did, so I checked my out going PM... Nov. 9,2018 - no reply. . Well, that is curious then. Surprised he hasn't at least responded. |
914sgofast2 |
Mar 11 2020, 07:39 PM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I want to buy one of these ac kits if they are still available!!!
Mike D |
GregAmy |
Mar 11 2020, 07:42 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I've often wondered how the compressors mounted for the /4s. Good info.
76-914 |
Mar 11 2020, 08:07 PM
I've often wondered how the compressors mounted for the /4s. Good info. That is his way and it works well. He's been running his set-up for several years. Neat and logical. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 12:08 PM |
