42 Pages V « < 15 16 17 18 19 > »
> Just arrived in the garage: 1971 914-4 1.7
raynekat
post Sep 25 2017, 08:40 PM
Post #321
QUOTE(mepstein @ Sep 25 2017, 05:11 PM) *
I think Mikey / Mark still has to be set of steel reproduction 914-6 calipers. If you want alloy, you will probably need to find someone who purchased a set and stored away.
Yes, I've already got the 914-6 "reproduction" steel calipers with the spacer for vented discs.
Nice looking but awful heavy.
BTW....somehow my "reproduction" calipers have ATE on them. How's that possible? (IMG:style_emoticons/default/idea.gif)
cary
post Sep 27 2017, 08:16 AM
Post #322
Tuesday night Moonlighting ...........
Three and 1/2 hours of straight rosette welding. Round and round.
My MillerMatic 180 is working like dream. Running .023 wire at level 7 on Millermatic mode. Millermatic compensates for all my weird angles and stick out.
Back panel rosettes completed.
Sides have about 1/3 left to go.
cary
post Sep 29 2017, 06:30 AM
Post #323
Rosettes are finished. Now its time to remove the epoxy from around the edges so I can begin the seam/stitch welding. Rosettes have yet to sanded/ground down.
Looks like 5 stitches gets me to 400 degrees. 5 stitches is about an inch.
cary
post Sep 30 2017, 08:21 AM
Post #324
Spent 3 hours yesterday welding the horizontal seams. One inch at a time.
6" flapper on the back panel. Figuring out how I'm going to finish it.
Surprising how well I got the epoxy removed. Very few spots had impurities pop thru the puddle.
cary
post Sep 30 2017, 07:30 PM
Post #325
After the morning Porsche get together I snuck out to the shop and seam welded for another 3 hours. Inch by Inch ..............
I'll try and sneak back out there Tuesday night for another 3 hours. Should just about get it done.
cary
post Oct 3 2017, 08:14 PM
Post #326
Look who's in the #1 spot in the Rothsport Racing engine room. (IMG:style_emoticons/default/biggrin.gif)
Jeff said the intake/induction goes on tomorrow.
raynekat
post Oct 3 2017, 10:13 PM
Post #327
QUOTE(cary @ Oct 3 2017, 07:14 PM) *
Now that got my attention big time...
cary
post Oct 4 2017, 04:18 PM
Post #328
Cairo94507
post Oct 4 2017, 04:50 PM
Post #329
Michael
Very pretty. (IMG:style_emoticons/default/beerchug.gif)
raynekat
post Oct 4 2017, 05:03 PM
Post #330
QUOTE(cary @ Oct 4 2017, 03:18 PM) *
Jeff Gamroth, owner of Rothsport, in the flesh....
Not much this shop can't do.
cary
post Oct 4 2017, 07:15 PM
Post #331
More Rothsport porn ..................
burton73
post Oct 4 2017, 09:36 PM
Post #332
burton73
QUOTE(Cairo94507 @ Oct 4 2017, 03:50 PM) *
O yea that is a thing of beauty.
Bob B
Larmo63
post Oct 4 2017, 09:53 PM
Post #333
THAT'S not a complicated induction system.
Looks so gorgeous.....!!!!!!!
cary
post Oct 7 2017, 09:18 AM
Post #334
Now that the inner long stiffeners are welded in it's time to start crossing things off the list.
#1. Drill drain hole into new right engine shelf in Hell Hole. Your looking at it upside down on the rotisserie.
#2. Attack rust holes found in the frunk/nose panel brace.
#3. After cutting out the inside and cleaning it with a knotted brush. I found holes on the inside of the fender. (IMG:style_emoticons/default/sad.gif) Once again, I feel like the bearer of bad news.
Must have been packed with something that would retain moisture at some time.
We'll try hand forming the rounded fender portion. But I might need to create it on the mondo slip roller at Rothsport.
#4. Doug stopped by around noon and dropped of the shift that needs a couple welds.
#5. Then on to the primary project of the day. Rust sections is the frunk seal channel.
This is the section in front of the latch. The front fence section was removed first so I could get down to the lower layer.
cary
post Oct 7 2017, 08:15 PM
Post #335
Here's a see thru shot of the frunk support/front liner fender hole.
Here's a spot that I missed yesterday. (IMG:style_emoticons/default/mad.gif)
cary
post Oct 7 2017, 08:21 PM
Post #336
Onto fixing the channel in front of the latch ...............
Had to give my patch a little pinch on the shrinker to get the shape I wanted.
Onto the welding.
Gooder as new .................
cary
post Oct 7 2017, 09:07 PM
Post #337
Then onto trimming the cowl.
First thing was to pull the window frame off the donor cowl.
Then trimmed the cowl a couple times to get it to fit into its spot. Close, but we have another 1/4" to go.
cary
post Oct 7 2017, 09:11 PM
Post #338
Here's another spot on the left headlight bucket.
Will probably work Tuesday night to tackle this spot.
Cairo94507
post Oct 8 2017, 06:40 AM
Post #339
Michael
Nice work. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Oct 8 2017, 06:05 PM
Post #340
Perfect timing. I have the very same set of trunk channel rust repairs as near-term to-dos. Lots of pics, please?
- Lo-Fi Version Time is now: 25th November 2024 - 03:51 AM
