22 Pages V « < 15 16 17 18 19 > »
> Muellers Honda V6 914 project, Put 70 miles on this engine swap, now to drop broken motor
76-914
post Aug 20 2020, 09:34 PM
Post #321
QUOTE(Andyrew @ Aug 20 2020, 10:20 AM) *
QUOTE(Mueller @ Jul 31 2020, 12:06 PM) *
QUOTE(Andyrew @ Jul 31 2020, 08:57 AM) *
Which manifold is that from? Lookin good (IMG:style_emoticons/default/smile.gif)
Outboard motor (IMG:style_emoticons/default/smash.gif)
I'm really pushing this water cooled conversion using boat parts.
Woah, What witchcraft is used to keep the crank lubricated on the top cyl journals and keep the oil out of the cylinders on the bottom?
There is a write up in Apple News about that very same thing. Might have been in the Popular Mechanics section. Multiple & separate head thermostats on the Marine version as well. The guy in Alaskan waters Has different cooling needs than the guy in the Caribbean. (IMG:style_emoticons/default/beerchug.gif)
EdwardBlume
post Aug 21 2020, 06:45 AM
Post #322
Looking good Mike! Keep up the 914 therapy!
dakotaewing
post Aug 21 2020, 09:31 AM
Post #323
Looking for one of these?
https://www.racetronix.biz/p/y-block-male-1...black/yblk-1616
Andyrew
post Aug 21 2020, 11:17 AM
Post #324
Spooling.... Please wait
QUOTE(76-914 @ Aug 20 2020, 08:34 PM) *
I'll have to look that up, Very crazy!! Imagine installing an engine like that in a car!
Mueller
post Sep 14 2020, 09:48 PM
Post #325
914 Freak!
Have not touched the 914 in a few weeks, other projects around the house and such.
Decided to make my own "wye" fitting today. It also gave me a chance to learn how to threadmill NPT threads. These are 3/4-14 NPT for the fittings to connect the hoses.
It will be 2 inlet and 1 outlet going to the radiator.
The video is showing my machine cutting the threads. The same cutter can cut multiple thread pitches, internal and external.
https://www.youtube.com/watch?v=azz8zstPheM
Andyrew
post Sep 15 2020, 08:02 AM
Post #326
Thats pretty trick how it mills the threads one at a time!
How difficult is that to program and setup?
tygaboy
post Sep 15 2020, 09:27 AM
Post #327
Mike - Thanks for posting stuff like this. I love your build and your "do whatever it takes" attitude. Your one-of-a-kind parts like this are like sprinkles on the frosting! (IMG:style_emoticons/default/drooley.gif)
Keep up the great work.
horizontally-opposed
post Sep 15 2020, 09:56 AM
Post #328
That is a pretty cool video—thank you for posting it, and I too dig this thread.
Keep it up, Mike—the car is going to be super cool when you get it running. That engine sounded great in Harry's 914.
Mueller
post Sep 24 2020, 08:35 PM
Post #329
914 Freak!
Not the most ideal material, didn't have any copper and I'm tired of spending money on this car so aluminum will do for now.
Need to see if I have some delrin or see if my 3D printer still works to make a cover for it.
The 3 large 12vdc lines are for the starter (1) and the other 2 go to the Powercells.
Krieger
post Sep 24 2020, 10:59 PM
Post #330
Wow! Great design and super clean look.
Coondog
post Sep 24 2020, 11:07 PM
Post #331
Nothing wrong with aluminum as a conductor....looks great.
post Sep 25 2020, 02:57 PM
Post #332
QUOTE(Coondog @ Sep 24 2020, 10:07 PM) *
Not unless your house was wired with it. Granted it wasn't the material but the installer. You as a fireman probably know this all too well.
Mueller
post Sep 25 2020, 03:28 PM
Post #333
914 Freak!
QUOTE(76-914 @ Sep 25 2020, 01:57 PM) *
Our home AC is wired using aluminum wire, the circuit breaker kept tripping until I realized the at the box was loose. A few turns till nice and tight and no more problems.
I did look up the charts for bus bar ampacity and figured this thickness should be fine for the 914.
Mueller
post Oct 16 2020, 01:13 AM
Post #334
914 Freak!
Exhaust is back on, took some trial an error finding the correct gaskets from the headers to the down tubes. Finally found an online catalog for Walker.
The cooling system is all done, tomorrow I hope to fill it and test it. It was recommended that I drill a few small holes in the thermostat. I am using an inline unit.
In order to fit my throttle body I needed to counter bore the adapter for 2 of the screws.
post Oct 16 2020, 08:17 AM
Post #335
QUOTE(Mueller @ Sep 25 2020, 02:28 PM) *
Mike, this is the exact situation that caused the fires. Loose connections caused arcing. Arcing caused black sooted buildup which in turn causes high resistance and heat build up to the point of ignition. The preventative fix is a cheap compound that electrical supplies will have. IIRC, it is called No-Lox or something like that. Coat the wire ends at wire nuts or other junctions. It will prevent arcing. We used the stuff when changing out electric water heaters but I haven't seen any aluminum wiring in years so we no longer carry it. (IMG:style_emoticons/default/beerchug.gif)
Maltese Falcon
post Oct 17 2020, 02:41 PM
Post #336
Machinist extraordinaire!
Gint
post Oct 17 2020, 06:57 PM
Post #337
Mike Ginter
(IMG:style_emoticons/default/agree.gif) I've always enjoyed seeing what Mike was turning out of bare stock.
rick 918-S
post Oct 17 2020, 07:18 PM
Post #338
Hey nice rack! -Celette
(IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) we need a new Meuller emoji
One that is operating a lath
hcdmueller
post Oct 18 2020, 12:04 PM
Post #339
Region Association: England
New houses in my area went to stranded AL wire for 220v circuits. The solid copper is too expensive I guess. A corrosion inhibitor is a must in that situation. We noticed the lights dim when the AC kicks on less than a year into our house. Guess what the builder didn't do to the 220v connections. In the end I had to clean up all the connections in the circuits and add the NOALOX. Not sure how a 12v connection would hold up, but seems like cheap insurance.
Great build, I love the Honda v6. Eventually I'll stuff one in a Bay bus.
Mueller
post Oct 22 2020, 05:33 PM
Post #340
914 Freak!
The PO of my 914 told me the transmission is in need of internal work, I'm going to drive as is for now. (Once I do drive it)
However this 2014 WRX 5 speed with 30K miles just happened to go up for sale not too far from me. I hope I can sell the rear diff to offset the cost.
- Lo-Fi Version Time is now: 8th April 2025 - 07:21 AM
