Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
stugray |
Jun 29 2016, 02:58 PM
you can measure the valve travel without even taking the rockers off.
To actually get at the cam to change it, you have to split the case, now the "what should I replace?" comes down to 1 - your budget & 2 - what you find. In either order. You can inspect & measure all the 'pertinents' and decide if anything is worn. |
Gunn1 |
Jun 29 2016, 02:59 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Did you try the search function ?
You will find mucho Grande info on this subject there. |
Mueller |
Jun 29 2016, 03:06 PM
you can measure the valve travel without even taking the rockers off. The actually get at the cam to change it, you have to split the case, now the "what should I replace?" comes down to 1 - your budget & 2 - what you find. In either order. You can inspect & measure all the 'pertinents' and decide if anything is worn. Not really looking into splitting case, for some odd reason I was thinking cam came out without do that, been too long. Oh well, I'll still measure it yet chances are it's going to stay unless that camshaft mentioned earlier would really offer some improvements. |
JFJ914 |
Jun 29 2016, 03:11 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Jake doesn't sell parts anymore, only turnkey engines. The Type IV store is now owned by LN Engineering.
Gunn1 |
Jun 29 2016, 03:16 PM
I think Jake uses the search function .
Be like Jake....... |
rhodyguy |
Jun 29 2016, 03:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Saw that one coming 1/2 hour ago. Funny. No quotes required.
Mike, have you tried contacting LN/type4 store directly with the cam #s you have? Does the site list a phone #? Edit: I checked. you should call type4 support |
Mueller |
Jun 29 2016, 03:48 PM
Jake doesn't sell parts anymore, only turnkey engines. The Type IV store is now owned by LN Engineering. I'd think he'd still have the specs to the older stuff he sold. Cam is not listed on Store website. I could call them tomorrow, might be something not usually offered. |
Mueller |
Jun 29 2016, 03:49 PM
rhodyguy |
Jun 29 2016, 04:20 PM
Unless somebody had their NEW cam read, those details are probably proprietary knowledge.
Gunn1 |
Jun 29 2016, 05:49 PM
Chris H. |
Jun 29 2016, 06:05 PM
Senior Member Group: Members Posts: 4,023 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
If Jake doesn't see this just call Charles at LN Engineering. He owns the Type 4 Store now. phone: 815-472-2939. Super nice guy.
Jun 29 2016, 06:47 PM
Custom Member Group: Members Posts: 24,498 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Mike,
Go to Elgin camshafts and look at what he sells. Lift ramp is most of what you can change . He has one that will work. Split the case, it will make drilling out the head studs easier to jig up. Plus, you cannot replace the camshaft without doing that . |
Valy |
Jun 29 2016, 08:44 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
How long did the motor run with broken head studs?
I would suspect the cylinders are out of round. |
Mueller |
Jun 29 2016, 10:01 PM
Exhaust studs broken, not head studs.....
Jun 29 2016, 10:13 PM
stugray |
Jun 29 2016, 10:58 PM
Exhaust studs broken, not head studs..... maybe contact saigon71 and see this thread: http://www.914world.com/bbs2/index.php?showtopic=248544 |
Mueller |
Jun 30 2016, 10:57 AM
I called LN Engineering, they found the specs for the cam I have sitting around...
Lift: I .335 E .400 Duration: 290 I/E Duration @ .050: I 252 E 254 108 Lobe center. |
stugray |
Jun 30 2016, 11:23 AM
I called LN Engineering, they found the specs for the cam I have sitting around... Lift: I .335 E .400 Duration: 290 I/E Duration @ .050: I 252 E 254 108 Lobe center. That is the lift at the cam. edit - not even sure of that. The #s look wrong. Is that at the cam or at the valves? While you have his attention, could you please ask what lift he expects with that cam at the valves? |
Mark Henry |
Jun 30 2016, 01:22 PM
I called LN Engineering, they found the specs for the cam I have sitting around... Lift: I .335 E .400 Duration: 290 I/E Duration @ .050: I 252 E 254 108 Lobe center. The 290 duration number is odd. Look at the WEB 73 numbers in the link below: http://vwparts.aircooled.net/Web-Cam-Type-...72-p/00-472.htm WEB 73 is a FI grind but IIRC it has bit more lift. If you want L-Jet you need an stock based FI grind like the 73. |
Lo-Fi Version | Time is now: 28th March 2024 - 02:10 AM |
