New engine firewall pad or Dynamatt? |
carcus |
Aug 30 2016, 03:28 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
My engine pad is crumbling. I was thinking of replacing it with Dynamatt. Has anyone done this? I think it looks a little nicer and the sound deadening properties are nice. What are your suggestions?
Any pics would be appreciated. Thanks again all |
Alphaogre |
Aug 30 2016, 03:44 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Pelican parts have an option that I used, I am pretty happy with it since it fit and was easy to install.
76-914 |
Aug 30 2016, 03:48 PM
Don't be surprised at what you find when that pad comes off. I had a hole on both sides. (IMG:style_emoticons/default/beerchug.gif)
Aug 30 2016, 04:02 PM
I'm using a dynamatt copy.
JmuRiz |
Aug 30 2016, 06:58 PM
914 Guru Group: Members Posts: 5,423 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'm using nothing (IMG:style_emoticons/default/smile.gif)
If I do sound deadening it will be inside the weatherproof cabin behind the backpad. |
Cracker |
Aug 30 2016, 07:25 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I also do not use insulation or a pad on either side...no problems here. Between the two choices you listed - I'd choose Dynamat hands down.
T |
Aug 30 2016, 07:32 PM
I'm using nothing (IMG:style_emoticons/default/smile.gif) If I do sound deadening it will be inside the weatherproof cabin behind the backpad. Mine is inside the cabin. Nothing outside to trap water. |
Mblizzard |
Aug 30 2016, 07:33 PM
Saw this one that may be an option
carr914 |
Aug 30 2016, 07:52 PM
Racer from Birth Group: Members Posts: 118,181 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
DynaMat Lite on mine
Rand |
Aug 30 2016, 08:04 PM
I'm using nothing (IMG:style_emoticons/default/smile.gif) If I do sound deadening it will be inside the weatherproof cabin behind the backpad. Mine is inside the cabin. Nothing outside to trap water. +1 |
boxsterfan |
Aug 30 2016, 08:40 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
As others have stated, do some form of dynamat (or other vendor sound deadening product) on the inside. There are some good threads here on this board of people doing dynamat all throughout the interior.
Here is what was behind my engine pad: http://www.914world.com/bbs2/uploads/post-...29428_thumb.jpg |
cary |
Aug 30 2016, 08:58 PM
914 Rubber has a nice Velcro removable one. Just took it out of one of Mark's cars.
I just spent 2 days removing the residual Dynamat tar from one of the rally cars we're building at Rothsport. Nasty ................. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) |
Mikey914 |
Aug 31 2016, 01:39 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
At $86 these are the best value I've seen
http://shop.914rubber.com/Fireall-backpad-...m?categoryId=-1 This is the one Cary mentioned Attached thumbnail(s) |
Mikey914 |
Aug 31 2016, 01:42 AM
installed
914_teener |
Aug 31 2016, 08:15 AM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So I.m wondering.
I can only wonder what the engineers were thinking when they put the pad there. My quess is that it was to stop heat transfer as well as sound...with more emphasis on the former. What say the collective? |
Mblizzard |
Aug 31 2016, 08:17 AM
So I.m wondering. I can only wonder what the engineers were thinking when they put the pad there. My quess is that it was to stop heat transfer as well as sound...with more emphasis on the former. What say the collective? Heat. There is a dense rubber mat on the inside wall that would seem to be more capable of stopping sound. |
wes |
Aug 31 2016, 08:41 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I striped mine both sides and used DynaMat plus the 914rubber one shown earlier, keeps the heat out but I add Webber to my 2056 and drive mostly with the top off,, Ive got lots of good sound.
carcus |
Sep 1 2016, 12:43 AM
Thanks all. I think I might go with the 914 Rubber one.
rfinegan |
Sep 1 2016, 04:29 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Any one try a spray on sound deadening? ( Lizard skin or the likes)
Steve |
Sep 1 2016, 07:28 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Mine also had surface rust underneath it on the passenger side. I ended up just using dynamat on the inside and dumping the engine compartment one. It also gives me more clearance to get to the 914-6 fan belt.
Lo-Fi Version | Time is now: 26th April 2024 - 11:21 AM |
