Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,839 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Clean up of surrounding metal.
Attached thumbnail(s) ![]() ![]() |
Dion |
Found the bastards (IMG:style_emoticons/default/ar15.gif)
Dion |
Cut a nice clean patch and (IMG:style_emoticons/default/welder.gif)
Dion |
Cleaned up, I’ll put the seat hinge/mount back after the lower firewall and longitudinal are in fixed positions.
Attached thumbnail(s) ![]() |
Dion |
Overall floor pic. I’ll get some primer on this tomorrow.
Dion |
Couldn’t resist a test a test fit of Restoration Designs
Outer long chassis plate. Fits beautifully. Can’t wait till it’s actually welded to the chassis! (IMG:style_emoticons/default/beerchug.gif) Thanks for lookin in. Attached thumbnail(s) ![]() |
ThreeV8s |
Member ![]() ![]() Group: Members Posts: 116 Joined: 11-March 17 From: West Chester, PA Member No.: 20,915 Region Association: North East States ![]() |
Great to see the progress! I think it's safe to say that there a lot of us here who find this thread extremely interesting, motivating, and educational.
Dion |
Still wasn’t satisfied with that patch, went back at it.
Cleaned it up again finding more pinholes. I’m more pleased this round. It’s solid again. I’m finding a balance between the welding and cleaning up with the grinder. I have been taking away too much parent metal, thinning it and creating my pinholes. It’s all up to experience I guess. As I’m sure all you experienced metal workers can attest. And we have a lot of skilled peeps on this forum I’m in awe of. I’ll hit the bottom with primer, paint and undercoating as usual. Ok here’s the pics: Attached thumbnail(s) ![]() |
Dion |
Final
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Lookin' good! (IMG:style_emoticons/default/beerchug.gif) I think the grinding is as tricky as the welding. I tended to have the opposite problem of leaving too much meat on the bone.
Dion |
Your going back in the garage again?!?!
Dion |
Well yes. Tackled the engine shelf debacle.
Couple of holes welded,hit it with primer till the rest of this left side is finished. Attached thumbnail(s) ![]() ![]() |
Dion |
Left engine shelf
Dion |
Primer
Dion |
Primer and paint of left floor patch near seat mount
Dion |
Exterior of floor area in question. Primer & Paint. I’ll undercoat it when all is wrapped up
on the chassis repairs. Attached thumbnail(s) ![]() ![]() |
Dion |
Getting some fresh air.... while paints dry.
View of neighbors and some Christmas lites. Attached thumbnail(s) ![]() |
Dion |
Some surface rust lurking under the engine shelf.
I honestly don’t think it was hit with paint under here or very minimalistic amounts. Looks just primer on engine rubber seal channel area. Just sprayed some rust converter for now on the underside of shelf. All this will be sanded again when the suspension console goes in. Attached thumbnail(s) ![]() ![]() |
Dion |
Rust converter spray coating
Dion |
Definitely needs a freshening...
Lo-Fi Version | Time is now: 19th April 2025 - 05:49 PM |
