The 914 conversion, 3.3 Ltr suby upgrade |
flmont |
Sep 25 2016, 09:58 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
brant |
Sep 25 2016, 10:08 PM
914 Wizard Group: Members Posts: 11,613 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
flmont |
Sep 25 2016, 10:23 PM
Mueller |
Sep 25 2016, 10:26 PM
Should be fun!
I hope you still plan on adding radiator exhaust holes in the front trunk, those vents won't work alone that you have for the hood. |
76-914 |
Sep 26 2016, 07:27 AM
Scratch HOPE and replace with Blood, sweat & tears. (IMG:style_emoticons/default/av-943.gif) Press on. (IMG:style_emoticons/default/popcorn[1].gif)
whitetwinturbo |
Sep 26 2016, 10:47 AM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
flmont |
Sep 26 2016, 04:06 PM
Yes ,I plan to do a much larger area on the hood,or maybe a diffant style altogether Iam just sizing those up,..rad system in place already, I need to install the gas tank ( I need the line fittings yet) I need the radiator and engine cooling hoses,. the engine cradle that's (in work), and ECU finalized,.then fuel pump, ETC..
Chris H. |
Sep 27 2016, 10:22 AM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Nice! Looks like Frank has mastered posting pics! Another 3.3 conversion will be cool. I'm about to go take a lap in mine in the cool air.
A "cradle" would have to be custom made because it's tough to work it around the exhaust system. Pretty much the only Subaru engine I've seen that has that issue. I can send you some pics of my engine mount setup. Bigkat made it. Mine is an early -4 mount up front with some L shaped angled pieces welded to it and trans hangers at the back. The middle is wide open. Key is you have to have a really good welder attach the additional pieces and they have to be VERY strong metal. Most of the weight of the engine is up front. Mine's been hanging in there for 3 years. |
flmont |
Sep 27 2016, 04:24 PM
Hi Chris,..Iam going the smallcar route I think,..get there side pieces,.then weld the cross bar to match,..
flmont |
Sep 27 2016, 04:26 PM
I do need help with the fuel tank set-up I have new stainless steel lines installed but I don't have the fittings for the tank,..?? Suggestions Pls,...
Chris H. |
Sep 27 2016, 04:41 PM
You have stainless lines from Tangerine Racing? You can use rubber (or whatever it's made of) fuel injection hose to connect to the tank. That looks like a later car so both lines should be the same size. 8mm, so I think that's 5/16 at the local auto parts store. Just make sure it's HIGH PRESSURE fuel hose.
Unless you bought the ones with the screw-type AN fittings on the ends? If so post pics of what you have and where you got it. |
flmont |
Sep 27 2016, 08:14 PM
No,..not from Tangerine,..P.O installed them ,.I will get pics for tomorrow,...Thanks
flmont |
Sep 29 2016, 08:35 AM
JustinMeier |
Sep 29 2016, 09:02 AM
Member Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None |
Ooooooo... Can I come help?
Problem is that I'm gone a lot of weekends but feel free to coordinate with me if you need some help (IMG:style_emoticons/default/shades.gif) |
Chris H. |
Sep 29 2016, 09:40 AM
That's it? Just the tank fittings? No tunnel lines or anything? One is stock, the other is an -AN fitting. Really should go one way or the other. Let us know and we'll go from there.
76-914 |
Sep 29 2016, 12:35 PM
Pm Bruce Stone (Bdstone) to get the correct fitting. Rotary914 has the washers. So your going to run the pump exposed? Walbro? Some of the Suby stock pumps are Walbro.
914forme |
Sep 29 2016, 04:26 PM
I'm curious about the 300HP, not sure how an EG will get you there in a stock form. Now if you do a few tricks, proper headers, cams, E85, boost (IMG:style_emoticons/default/happy11.gif) then we get closer to 300. The last one will get you well above 300.
That being said I have tabled my power plans to blow the EG. I was going to run a blower an E85. After this weekend and not finding E85 on the roads around Okteenerfest. I really don't want to haul around a truck bed full of E85 just to be able to go (IMG:style_emoticons/default/driving.gif) So if you got a way of getting 300+ HP, I will be (IMG:style_emoticons/default/popcorn[1].gif) Even if you don't I'll be (IMG:style_emoticons/default/popcorn[1].gif) Another EG33 build (IMG:style_emoticons/default/aktion035.gif) |
flmont |
Sep 29 2016, 06:14 PM
Well, I only say 300 HP,..because I have heard u can,..the only mods I will do is new injectors,and the ZF34 mod,.and maybe cams in the future,..
flmont |
Sep 29 2016, 06:15 PM
when it comes to the gas tank fittings,.I don't know what to use,..the PO had this set up,..I need to know what to do,.??
flmont |
Sep 29 2016, 06:18 PM
Sorry Chris,..yes I have tunnel lines 2 ea,installed.I belive 1 will be blocked off due to no return line right.??
Lo-Fi Version | Time is now: 25th April 2024 - 07:04 PM |
