1970 porsche 914 wiring questions |
jfab |
Jan 22 2017, 09:03 PM
Newbie Group: Members Posts: 16 Joined: 20-January 17 From: mass Member No.: 20,767 Region Association: North East States |
long story short, the PO cannot wire cars so assume the worst
first is first, im assuming this blue wire is for the horn at the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.1.jpg) i also found this blue wire attached to the relay board under the kneeboard. guessing this goes to the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.2.jpg) it is attached to the relay board here, same spade connector as the only non corroded terminal (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.3.jpg) this disconnected wire goes to ground i assume? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.4.jpg) and lastly, what is supposed to go to the pole #6 on this connector? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140580.5.jpg) |
JeffBowlsby |
Jan 22 2017, 10:02 PM
914 Wiring Harnesses Group: Members Posts: 8,479 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached thumbnail(s) |
jfab |
Jan 22 2017, 10:18 PM
i have searched so long to find something thats a fraction as helpful as this i owe you one man, thank you so much |
larryM |
Jan 22 2017, 10:43 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
Jeff: thanks for that hand drawn diagram - might be the clue i needed i've been working on my wiring to rewire/mod a few things & fix the euro-park feature which had been reversed ever since the car came to USA, and found a disconnected gray wire near the new JWest panel - it has an oem female spade on it & looks like it ought to belong to the fuse panel - but i could not find it in my wiring chart - has no continuity to any other point that i could find so far - and does not have 12v on it anytime (it's NOT the wire that feeds the trunk & license lights - i have a different gray one for that - and fixed it after 30 yrs) i also find another cut-off gray wire & am looking for what that belongs to - same no continuity, no 12v . |
jfab |
Jan 22 2017, 10:53 PM
i just checked my harness and i found about 12 problems with it that would have left me stumped for days.
5 of the pins were in the wrong location (thanks PO) the buzzer wire seems to have been broken off (thanks PO) and now im only missing pin 1 which is not the end of the world i guess, or i can make it work and get my buzzer back making a new harness and getting these electronics finished after my check hits! im so grateful. I have to figure out where 2 more of the wires that were disconnected on my relay board go, but ill tackle that once this work is done! |
JeffBowlsby |
Jan 22 2017, 11:53 PM
Glad to help gents.
I am looking for the similar late 1971 version of this steering column that has the 14 pin connector if anyone has a decent one they can sell me. I would make similar diagram of that available as well. |
Jan 23 2017, 06:52 AM
Glad to help gents. I am looking for the similar late 1971 version of this steering column that has the 14 pin connector if anyone has a decent one they can sell me. I would make similar diagram of that available as well. I might in a little while. Once I finish taking apart my car for paint, I have a nos column to replace the old one. So give me a little time and I'll be able to contribute the old one to the cause. |
JeffBowlsby |
Jan 23 2017, 10:20 AM
Cool, let me know. I am no hurry.
jfab |
Jan 23 2017, 01:56 PM
jeff i have an entire chassis wiring harness and other wiring components from a later car, i believe it has the 14 pin. i also have a few other harnesses. when i get them together ill take pictures and send them your way
JeffBowlsby |
Jan 23 2017, 02:06 PM
jeff i have an entire chassis wiring harness and other wiring components from a later car, i believe it has the 14 pin. i also have a few other harnesses. when i get them together ill take pictures and send them your way That's superb! Thank you. Just to be clear, the 14-pin connector I am talking about is at the steering column. 1970 through early 1971 cars have a 12 pin here, later 1971 have a 14 pin steering column connector. |
jfab |
Jan 24 2017, 12:04 PM
yup, i dont know if i have the 14 pin from the steering column but at my friends house in maine i have the entire 14 pin chassis harness from a 73 i believe. as well as a bunch of other harnesses
JeffBowlsby |
Jan 24 2017, 02:40 PM
The chassis harness of all 914s have a 14 pin connector at the relay board.
Only the late 1971 has a 14-pin connector at the steering column, which is the only one I am interested in. If this is the one you have, let me know! |
Lo-Fi Version | Time is now: 26th April 2024 - 09:55 AM |
