Help... White Smoke, Rough Idle, Cut Harness |
xicema17x |
May 15 2017, 02:39 PM
Newbie Group: Members Posts: 5 Joined: 15-May 17 From: San Diego Member No.: 21,102 Region Association: Southern California |
Hi All,
Curious if you might be able to identify the pix below. The car sat for quite some time, and my assumption is the previous owner did not know how to do an oil change. **The car was spitting out white smoke, which I believe is due to an overfilling issue?** Anyhow, I took out some oil, and it helped. Now I am in the position where the car seems to run very rich, and my assumption is the cylinder head temp sensor is missing or not functioning properly. Can anyone help identify if the cut wire below, if it is the temperature sensor wire? Also, can anyone help identify the white plug below please? (IMG:http://www.914world.com/bbs2/uploads_offsite/i28.photobucket.com-21102-1494880783.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i28.photobucket.com-21102-1494880783.2.jpg) |
914_teener |
May 15 2017, 03:05 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
What year and size motor is it?
May 15 2017, 03:15 PM
The first one looks a lot like the CHS sender wire. See where it goes; if it disappears through the engine tin near the #3 spark plug, that's what it is.
The second one looks like a connector for the fuel-cut type rev-limiter, as used on 75-76 914s that had catalytic converters. No harm if it is not plugged in. --DD |
xicema17x |
May 16 2017, 07:51 PM
xicema17x |
May 19 2017, 11:44 AM
The first one looks a lot like the CHS sender wire. See where it goes; if it disappears through the engine tin near the #3 spark plug, that's what it is. The second one looks like a connector for the fuel-cut type rev-limiter, as used on 75-76 914s that had catalytic converters. No harm if it is not plugged in. --DD Thanks Dave... Found the culprit! I appreciate it... |
Lo-Fi Version | Time is now: 26th April 2024 - 12:30 PM |
