009 dizzy, The screw that holds the points |
jeffdon |
May 19 2017, 10:53 AM
Can anyone tell me the type/size of the screw that holds down the points? I have the counter sunk screw that held my pertronix in, but I know that is not correct.
URY914 |
May 19 2017, 03:59 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,199 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Real damn small and short.
mgphoto |
May 19 2017, 06:59 PM
"If there is a mistake it will find me" Group: Members Posts: 1,336 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
buy a set of Bosch points and it should be included.
same as the Pertronix but not countersunk. Mike |
Beach914 |
May 19 2017, 08:43 PM
Senior Member Group: Members Posts: 962 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
Like this. Hard to keep from losing.....
jeffdon |
May 20 2017, 10:20 AM
larryM |
May 22 2017, 11:23 AM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
throw it away & get an 034 svda 009 is wrong dizzy for our engines - just google it |
rfinegan |
May 22 2017, 11:53 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Are all the 009 points distributors Bad? I picked one up on this forum that seems run my stock 2.0 with webers pretty good...
-Robert |
ljubodraz |
May 22 2017, 10:49 PM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
If you haven't already, I would advise confirming that your dizzy is in fact the dreaded 009 that everyone hates. When I got my car, I at first thought my dizzy was a 009 because one set of numbers on it ended in 009. When I researched it I found that it was a stock desirable dizzy instead.
Lo-Fi Version | Time is now: 26th April 2024 - 11:09 PM |
