123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount |
Millerwelds |
Oct 27 2017, 01:29 PM
Pleepleus Group: Members Posts: 717 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
Just look at the comparison from stock, to Pertronix to the 123. The 123 signal is basically perfect. You should buy one!
https://www.youtube.com/watch?v=3wZ2xj6SAfI |
Mueller |
Oct 27 2017, 02:11 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Just ordered the 4R- we are well beyond the number needed for 15% off, if you're on the fence, you ought to jump on! I jumped off the fence, figured I should stay with my Megasquirt setup, it's already paid for. There would be a lot less cussing and possible AAA tows with the stock L-Jet and a 123ignition however. We'll see. |
Olympic 914 |
Oct 27 2017, 06:15 PM
Group: Members Posts: 1,708 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
On the Djet models does anyone know how the 123 Dizzy hooks up to the trigger point wires? does it have the same plug as on an original dizzy or do you have to rig up jumper wires from the ECU harness to the 123 dizzy?
Rather not cut the plug off of the harness, in case I have to reinstall the original dizzy. |
StratPlayer |
Oct 27 2017, 06:29 PM
StratPlayer Group: Members Posts: 3,298 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
The 123 D jet set up will have to small wires that will plug into the pins on the plug that plugged into you old dizzy. Will show that in the install instructions that come with the dizzy.
JeffBowlsby |
Oct 27 2017, 06:30 PM
914 Wiring Harnesses Group: Members Posts: 8,741 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
FINALLY...someone brought this up. It needs to be addressed. Looks like it is just 3 wires coming out of the dizzy body and I am not aware of any available male terminals or housing that are an easy mate to the female terminals on the standard FI harness.
SOL. Best technical solution is to find a weatherproof 2 pole quick disconnect connector, male/female and mount it to the harness/dizzy. Wire cutting is involved. Not pretty but it will certainly function and be durable. I would also wrap any exposed wires from the dizzy in heat shrink tube (the dizzy should have had this from the factory). Attached image(s) |
StratPlayer |
Oct 27 2017, 06:33 PM
My 123 dizzy for a D jet trigger points had the fittings on the end of the wires so they will plug into the harness plug, Plugged them in without any problems, been running in the car for over a year now without any problems.
JeffBowlsby |
Oct 27 2017, 06:40 PM
So it comes with 2 male pins installed on the wires?
euro911 |
Oct 27 2017, 07:32 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,858 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
It sounds like it, unless Jim had someone else install it, and they did a mod? (IMG:style_emoticons/default/confused24.gif)
If concerned about going back to the original distributor on the side of the road, splice parallel wires and an additional connector for the 123 before hand, and the OEM connector will still be intact - ready for use if needed ... (IMG:style_emoticons/default/idea.gif) |
123ignitionusa |
Oct 27 2017, 08:00 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
914_teener |
Oct 27 2017, 09:30 PM
914 Guru Group: Members Posts: 5,248 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
FINALLY...someone brought this up. It needs to be addressed. Looks like it is just 3 wires coming out of the dizzy body and I am not aware of any available male terminals or housing that are an easy mate to the female terminals on the standard FI harness. SOL. Best technical solution is to find a weatherproof 2 pole quick disconnect connector, male/female and mount it to the harness/dizzy. Wire cutting is involved. Not pretty but it will certainly function and be durable. I would also wrap any exposed wires from the dizzy in heat shrink tube (the dizzy should have had this from the factory). Can you get the grey somewhere Jeff? |
euro911 |
Oct 27 2017, 10:28 PM
Oh, and thanks for organizing the GB, Rob ... and for hosting the GB, Ed (IMG:style_emoticons/default/beerchug.gif)
Morrie |
Oct 29 2017, 09:45 AM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
Anyone have the advance curve for the Bosch 050 distributor? Wonder if one of the preset curves on the 4R is close to that... Think I'll order the 4R with 16 curve choices- don't figure I'm computer savvy enough to program the thing myself! Hell, I'm driving a 46 year old car!! The 050 isn't even a curve. It is pretty linear, which gives you less of an advance bump at low RPM than most of the stock Bosh units. The 009 is also plotted here. |
914_teener |
Oct 29 2017, 09:53 AM
Anyone have the advance curve for the Bosch 050 distributor? Wonder if one of the preset curves on the 4R is close to that... Think I'll order the 4R with 16 curve choices- don't figure I'm computer savvy enough to program the thing myself! Hell, I'm driving a 46 year old car!! The 050 isn't even a curve. It is pretty linear, which gives you less of an advance bump at low RPM than most of the stock Bosh units. The 009 is also plotted here. Are you sure rhose are the 914 part No distributor curves? |
914_teener |
Oct 29 2017, 01:04 PM
914_teener |
Oct 29 2017, 02:47 PM
Looks like these are for the 1.7.
039 part prefix is for the 2.0 from Brad Anders site. Maybe they don't exist? Given the advance noted they should be able to be plotted. The read on the retard function is interesting on over run and part load. |
Morrie |
Oct 29 2017, 06:31 PM
Anyone have the advance curve for the Bosch 050 distributor? Wonder if one of the preset curves on the 4R is close to that... Think I'll order the 4R with 16 curve choices- don't figure I'm computer savvy enough to program the thing myself! Hell, I'm driving a 46 year old car!! The 050 isn't even a curve. It is pretty linear, which gives you less of an advance bump at low RPM than most of the stock Bosh units. The 009 is also plotted here. Are you sure rhose are the 914 part No distributor curves? Those are not 914 Part numbers. Maybe I made the classic mistake of assuming that "050" was the aftermarket Bosh distributor often used in VW engines when "SKL1" asked. The "009" is also the Bosh part number of the common aftermarket distributor. The "022" and "031" are OEM distributors for Porsche 912. The "0012" is a customized "009" that Benton Performance developed. This was posted specifically in response to the "050" curve request. Apologies if I misunderstood. |
SKL1 |
Oct 29 2017, 07:12 PM
Senior Member Group: Members Posts: 1,637 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Thanks for info Morrie- that should help with selecting which of the 16 curves I'll use when I get the 4R.
Porschef |
Oct 29 2017, 07:24 PM
How you doin' Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
That DM-031 curve looks much more like something my engine would appreciate over the 050 curve.
Rand |
Oct 29 2017, 08:32 PM
Thanks for putting the group buy together. Just ordered. I was about to go through my 2.0 djet dizzy. Having this and eliminating points/pertronix, trigger points, vacuum port, advance plate and braided wire maintenance, nice and new... Is going to eliminate a lot of potential headaches!
(IMG:style_emoticons/default/smilie_pokal.gif) |
Oct 30 2017, 11:08 AM
914 Idiot Group: Members Posts: 15,060 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Lo-Fi Version | Time is now: 24th November 2024 - 05:16 PM |
