123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount |
jim_hoyland |
Oct 19 2017, 06:13 AM
Get that VIN ? Group: Members Posts: 9,435 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Do they make one compatible with L-Jet FI ? I'm guessing option 2 Jim??? Running Ljet also. (IMG:style_emoticons/default/popcorn[1].gif) ? or #1 if no vac advance ? |
McMark |
Oct 19 2017, 07:15 AM
Mueller is right in his descriptions. I added a similar list, with links to the first post. I think I also clarified the ordering process. To reiterate, order your distributor now with the code '914world' and those orders will be queued/held and will all ship together sometime in Mid-November.
I STRONGLY recommend the bluetooth unit (#4 in the first post) for ALL ENGINES, except D-Jet. It costs a little more, but if you can afford it, make the jump and get bluetooth. D-Jet users only have one choice. Another note about the bluetooth distributor, once the curve is set into the unit, you never need to connect to the device again. The unit will run autonomously for normal driving. The phone/bluetooth connection is only used when you need the change the tune. For most people this will be set it once, then forget about it and it's just a 'normal' distributor. |
nditiz1 |
Oct 19 2017, 07:31 AM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
DRPHIL914 |
Oct 19 2017, 07:33 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have been thinking about this for some time and waiting , looks like the time is now, 15% discount will be nice!
I am in for a D-jet version ! +1 for me. Phil |
DRPHIL914 |
Oct 19 2017, 07:35 AM
Hello Guys I talked to Rob and starting Monday October 23rd, and for three weeks you can use the coupon code 914world It will expire November 10 and be good for 10% off retail on any product I offer. When the amount of orders reaches 10 then the discount becomes 15% off retail. When that happens the additional 5% will be refunded to the cc of the first ten orders. Orders will be filled 7-10 after the close of the 3 week period. Hope this helps Ed he said starts Monday the 23rd I believe.... |
VaccaRabite |
Oct 19 2017, 07:41 AM
En Garde! Group: Admin Posts: 13,561 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I bought one of these for my BMW2002 when the 2002 forum did a group buy last year. I've yet to run into someone on the 2002 forums that regrets putting one of these in.
Seriously folks. Get one. If I was not running McMarks EFI on my 914, I'd be buying one of these for my 914 too. IMO, you want the bluetooth tune-able version. Its not much more money, and gives you the advantages of a tune-able spark curve. Zach |
nditiz1 |
Oct 19 2017, 07:55 AM
QUOTE he said starts Monday the 23rd I believe.... Thanks Phil - I missed that post (IMG:style_emoticons/default/rolleyes.gif) |
914_teener |
Oct 19 2017, 08:02 AM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Mueller is right in his descriptions. I added a similar list, with links to the first post. I think I also clarified the ordering process. To reiterate, order your distributor now with the code '914world' and those orders will be queued/held and will all ship together sometime in Mid-November. I STRONGLY recommend the bluetooth unit (#4 in the first post) for ALL ENGINES, except D-Jet. It costs a little more, but if you can afford it, make the jump and get bluetooth. D-Jet users only have one choice. Another note about the bluetooth distributor, once the curve is set into the unit, you never need to connect to the device again. The unit will run autonomously for normal driving. The phone/bluetooth connection is only used when you need the change the tune. For most people this will be set it once, then forget about it and it's just a 'normal' distributor. Thanks Mark and Mike. The code won.t work until Sunday. He wanted to make sure there was interest in the first five which there looks like there is. I.m running bone stoxk D-jet so I know my choice. |
mgphoto |
Oct 19 2017, 08:15 AM
"If there is a mistake it will find me" Group: Members Posts: 1,363 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
FYI page 1 Specifications
Temperature : -30 to 95 degrees Celsius I haven't confirmed if this is ambiant temp or operating. I bought it 3 weeks and I'm having issues with heat. I started a thread but haven't updated it. We have had hot weather 95 and up . With temps in the 70's she runs great but above 85 she starts pinging on hard acceleration. Been a Dr. Jeckell Mr. Hyde experience, latest test 100 octane fuel. |
VaccaRabite |
Oct 19 2017, 08:33 AM
FYI page 1 Specifications Temperature : -30 to 95 degrees Celsius I haven't confirmed if this is ambiant temp or operating. I bought it 3 weeks and I'm having issues with heat. I started a thread but haven't updated it. We have had hot weather 95 and up . With temps in the 70's she runs great but above 85 she starts pinging on hard acceleration. Been a Dr. Jeckell Mr. Hyde experience, latest test 100 octane fuel. I remember your thread. Did you ever call them and ask them about it? These dizzys are running in engines all over the place, in climates just like yours (and warmer) without issue. Yours may have an issue (defective out of the box - it does happen), or it needs to be re-tuned. You should not need 100 octane fuel and should not be pinging under what would be considered normal operating conditions. My experience with the 123 people (and others in the BMW community) is that the customer support is pretty darned good. IMO, they could not sell these things if the upper range of operation was only 95 degrees. On a moderate day, its often over 110 under the hood of a normal car. Zach |
EdwardBlume |
Oct 19 2017, 08:38 AM
Would the GB include the /6 distributor? Anybody use one for a 2.4 / 2.7 / 3.0?
DRPHIL914 |
Oct 19 2017, 08:43 AM
FYI page 1 Specifications Temperature : -30 to 95 degrees Celsius I haven't confirmed if this is ambiant temp or operating. I bought it 3 weeks and I'm having issues with heat. I started a thread but haven't updated it. We have had hot weather 95 and up . With temps in the 70's she runs great but above 85 she starts pinging on hard acceleration. Been a Dr. Jeckell Mr. Hyde experience, latest test 100 octane fuel. I remember your thread. Did you ever call them and ask them about it? These dizzys are running in engines all over the place, in climates just like yours (and warmer) without issue. Yours may have an issue (defective out of the box - it does happen), or it needs to be re-tuned. You should not need 100 octane fuel and should not be pinging under what would be considered normal operating conditions. My experience with the 123 people (and others in the BMW community) is that the customer support is pretty darned good. IMO, they could not sell these things if the upper range of operation was only 95 degrees. On a moderate day, its often over 110 under the hood of a normal car. Zach I hope Zach is right because around here in the summer its going to be on average in the middle to upper 90's - of course I don't drive the car much on those days , unless I get the A/C thing figured out bynext year. Keep us posted on your experience with this mgphoto please! |
914_teener |
Oct 19 2017, 08:52 AM
95 C is 202 F
Hunh....well it will be in the 90's this weekend. Update your thread. |
mgphoto |
Oct 19 2017, 08:54 AM
FYI page 1 Specifications Temperature : -30 to 95 degrees Celsius I haven't confirmed if this is ambiant temp or operating. I bought it 3 weeks and I'm having issues with heat. I started a thread but haven't updated it. We have had hot weather 95 and up . With temps in the 70's she runs great but above 85 she starts pinging on hard acceleration. Been a Dr. Jeckell Mr. Hyde experience, latest test 100 octane fuel. I remember your thread. Did you ever call them and ask them about it? These dizzys are running in engines all over the place, in climates just like yours (and warmer) without issue. Yours may have an issue (defective out of the box - it does happen), or it needs to be re-tuned. You should not need 100 octane fuel and should not be pinging under what would be considered normal operating conditions. My experience with the 123 people (and others in the BMW community) is that the customer support is pretty darned good. IMO, they could not sell these things if the upper range of operation was only 95 degrees. On a moderate day, its often over 110 under the hood of a normal car. Zach I know huh. |
mgphoto |
Oct 19 2017, 08:56 AM
I'm not at the debug with the manufacture yet, I'm trying to rule out all my mistakes first.
I'm just saying 95*C? European website states 100* |
914_teener |
Oct 19 2017, 09:07 AM
VaccaRabite |
Oct 19 2017, 09:08 AM
I'm not at the debug with the manufacture yet, I'm trying to rule out all my mistakes first. I'm just saying 95*C? European website states 100* 100*C is 212*F (I think. Shoot now I'm doubting my metric. I think 100*C is the point where water boils....) I checked, I'm good. So if your unit is rated to 100*C ambient, that equates to 212*F ambient. I don't care where you live, if the ambient temps can boil water, you have concerns larger then driving around. ;-) You should be well within spec. I'd still call 123 and talk to someone, or start the email conversation. As the guy who puts off doing these things (just ask McMark), I can tell you it gets easier when you just suck it up and admit when you need a bit of help. I'm STILL learning that lesson. (IMG:style_emoticons/default/slap.gif) I've wasted about 3 years on my build due to being stubborn. Zach |
914_teener |
Oct 19 2017, 09:13 AM
I agree with Zach....my coffee is kicking in.
mgphoto |
Oct 19 2017, 09:25 AM
Jett |
Oct 19 2017, 09:57 AM
Senior Member Group: Members Posts: 1,668 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I’m in for. DJet version.
Lo-Fi Version | Time is now: 5th October 2024 - 11:38 AM |
