19 Pages V « < 17 18 19
> 123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount
9144me2enjoy
post Dec 7 2019, 08:24 AM
Post #361
Rob I think your correct, I’ve tried a couple of changes in the settings and ended up with setting the initial at 1000rpms at 9.0 degrees and at 1500rpms at 10.0 degrees and 3000rpms at 28.0 degrees and 4000rpms at 28 degrees and 8000rpms at 29 degrees. Seams to idle smoothly and accelerate smooth. Will need to take it out a few times and see how its pulling under load to see if I need to readjust. Pouring down rain today (liquid sunshine), at least its above freezing! Thanks again
9144me2enjoy
post Dec 7 2019, 09:04 AM
Post #362
If any other 914World members are running a similar setup with the Raby 2270 engine or similar engine With the Bluetooth 123ignition, could Post/reply with the Advance Curve they’re using, I would appreciate it. Thanks-Happy Holidays
914-300Hemi
post Dec 7 2019, 09:13 AM
Post #363
Can anyone share the curve for a carb’d 2056 with a mild cam?
9144me2enjoy
post Dec 30 2019, 09:50 AM
Post #364
I thought I would add this for others, if it applies to there application. I have a 74-914 with a built Type 4 2270 engine with dual 44 Webers. I purchased the 123Ignition and after setting the Centrifugal Curve was wondering about setting the Map Curve if applicable. Anyhow I couldn’t get a definitive answer so I sent a message to Ed Madak with 123Ignitionusa,LLC who responded the following:
Ed Madak
Dec 29 at 4:39 PM
It is ok to set the map at 0. In actuality if you had not changed it the outcome would have been the same.Because there is no vacuum to cause the map to come live.
Hope this helps
Ed
Thanks Ed for your quick response. Happy Holidays and Happy New Year! Roy
GregAmy
post Mar 8 2020, 08:35 AM
Post #365
Hi, all. Can I get someone's known-good timing curve for a stock 2L D-Jet engine? Thanks!
mb911
post Jun 14 2020, 06:53 AM
Post #366
Anyone use these with MSD ignition? I have heard that they may not be compatible?
michael7810
post Jun 14 2020, 09:33 AM
Post #367
I had no problems with the 123 and MSD except I had to replace the MSD Blaster coil with Bosch blue coil because the impedance on the Blaster was not correct for the 123. It’s been a couple years and a couple thousand miles with no issues.
mb911
post Jun 14 2020, 10:22 AM
Post #368
QUOTE(michael7810 @ Jun 14 2020, 07:33 AM) *
That's interesting.. I might have to look at a 911 style coil..
michael7810
post Jun 14 2020, 11:48 AM
Post #369
I just checked the website and 123 recommends a coil with at least 1.0 Ohm primary resistance on 4- and 6-cylinder engines.
mb911
post Jun 14 2020, 08:11 PM
Post #370
QUOTE(michael7810 @ Jun 14 2020, 09:48 AM) *
So what coil fits into that range?
nditiz1
post Jun 15 2020, 08:42 AM
Post #371
Stock Blue bosch will work. As will the flamethrower P/N 40611 3 ohm coil.
mb911
post Jun 15 2020, 05:26 PM
Post #372
Looks like the 911 guys run with a blaster coil and trigger with the white wire from the msd.. Seems simple enough.
alexkirkham
post Jul 19 2020, 02:59 AM
Post #373
I'm going to chime into the 'what setting' debate...
I have a standard 73/74 (have never been quite sure which...) d-jet 1.7 with a retard and advance (2 pipe) distributor, and after reading the pbanders site set the 123 to '1': after all, the retard is just there for emissions and the advance will make the throttle response a bit peppier... We set the timing to 27 degrees at 3500 with the vacuum lines off.
One immediate effect was that the idle went up by around 500rpm. That's fine, it can be corrected for. But then I started getting the impression that the exhaust was smellier. Fine in the country, but in London with lots of idle, you notice it... And on reading, advancing the idle by 10 degrees might double NOX and hydrocarbon emissions...
So I just tried connecting the retard line and putting it on setting 'A', which gives factory idle retard. This seems to work nicely: smooth idle (I think because the 123 is rock solid) and to my surprise the throttle response is just fine (I don't really notice a difference with '1') and it pulls strongly and smoothly through the range. With my old distributor there was mild bogging from 1000 to 1500 and a hesitation at 2000-3000rpm. I also have a wideband AFR meter and everything is between 11.5 and 15...
So the upshot is: if you have a 74 or later, the factory correct setting is probably 'A', and actually it works really well...
alex
r3dplanet
post Jul 12 2021, 02:03 PM
Post #374
Hey guys. I'm install my 123ignition on a dual carb setup and not having much luck. It's stupid to say but I think I'm having wiring trouble for only three wires.
The engine is on a stand outside the car.
What I have connected is the red wire to coil (+), the blue wire connected to the battery (+), and the black wire disconnected per the instructions.
The LED does not illuminate. No green. No anything.
What am I doing wrong?
-m.
r3dplanet
post Jul 12 2021, 02:11 PM
Post #375
Disregard. The blue wire goes to battery negative.
jim_hoyland
post Feb 5 2023, 08:18 PM
Post #376
Get that VIN ?
Any new developments with the 1-2-3s ? Mine had worked perfect since installation
Nacho
post Feb 17 2023, 09:35 AM
Post #377
Hi
I'm interested in purchasing a 123 distributor for my 2270. Is there a point of contact on the World or a recommended website to purchase from?
Thanks
rjames
post Feb 17 2023, 10:51 AM
Post #378
I'm made of metal
QUOTE(jim_hoyland @ Feb 5 2023, 06:18 PM) *
Been running mine for a few years without any issue. Was worried that it may not last given how hot it gets, but so far so good.
NJ914
post Feb 17 2023, 03:20 PM
Post #379
I'm interested in buying one as well. Was hoping for another Group buy offer but no luck so far... (IMG:style_emoticons/default/sad.gif)
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 08:13 PM
