123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount |
Dr Evil |
Oct 18 2017, 12:16 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Wow! If they had one for a corvair motor I would jump in. Cool product.
Millerwelds |
Oct 18 2017, 12:40 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
One key feature with these is they replace the old school NLA fuel injection trigger points with an electric pulse. Way more modern and consistent signal.
Also the Bluetooth version can be set to require a code before it will allow the car to be started. A cool security feature. I have been wanting one for a while now and will commit to the group buy for sure. Jump on board everyone! Read the reviews from other cars /engines too. This is a killer set up. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Oct 18 2017, 12:53 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
ChrisFoley |
Oct 18 2017, 01:10 PM
I am Tangerine Racing Group: Members Posts: 7,960 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm in for one, maybe two.
olsib914 |
Oct 18 2017, 02:56 PM
Member Group: Members Posts: 86 Joined: 23-August 14 From: Orange, CA Member No.: 17,813 Region Association: None |
plus one for me
olsib 914 |
Morrie |
Oct 18 2017, 02:59 PM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
I am interested in a D-Jet unit, and possibly a BT unit for my 912.
mmichalik |
Oct 18 2017, 03:09 PM
MikeM Group: Members Posts: 718 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
BeatNavy |
Oct 18 2017, 03:22 PM
Certified Professional Scapegoat Group: Members Posts: 2,934 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Sorry to be thick, but I just want to be clear: the one that's D-Jet compatible is NOT Bluetooth programmable, correct? You can select from a number of pre-programmed advance curves (looks like 10 of the 16 apply to 914), but it doesn't work with Bluetooth. I guess the Bluetooth-programmable one is for non D-Jet (I assume because of the trigger points).
Someone please correct me if I've got this wrong. I'm interested, but want to make sure I understand. Thanks for putting this together, Rob. |
914_teener |
Oct 18 2017, 03:42 PM
Rob,
My understanding of the Bluetooth app is that you can see the data on your laptop and or mobile device. The D-jet version of thier distributor edit: There is only one choice: Switched. The blue tooth version is not available for Djet. On their D-jet version there are aprox 20 preprogramed curves. The bluetooth capability allows you to observe the advance curve in relationship to other engine metrics. There is a You Tube of his posted. I am not sure if this is extra....again...I.ll ask. I have a call into him just now. I.ll update the first page tonight with the interested members and models...depending on his answers... after the Dodgers win the NLCS. Rob |
123ignitionusa |
Oct 18 2017, 06:33 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
Hello Guys
I talked to Rob and starting Monday October 23rd, and for three weeks you can use the coupon code 914world It will expire November 10 and be good for 10% off retail on any product I offer. When the amount of orders reaches 10 then the discount becomes 15% off retail. When that happens the additional 5% will be refunded to the cc of the first ten orders. Orders will be filled 7-10 after the close of the 3 week period. Hope this helps Ed |
123ignitionusa |
Oct 18 2017, 06:40 PM
914 models are available in the following
Switched with no vacuum http://123ignitionusa.com/porsche-912-914-...ncludes-spacer/ Switched with vacuum http://123ignitionusa.com/porsche-912-914-...ncludes-spacer/ Switched with D-Jet http://123ignitionusa.com/porsche-912-914-...ncludes-spacer/ D-Jet is only available in the switched pre programmed model with the designation ie at the end. TUNE+ is Bluetooth using an Apple or Android phone or device http://123ignitionusa.com/bluetooth-tune-4...rated-w-spacer/ TUNE is USB connected using a pc http://123ignitionusa.com/tune-usb-4-cylin...rated-w-spacer/ They are not interchangeable. You must choose Switched, Tune+ Bluetooth or Tune Usb. Hope this helps Ed Rob, My understanding of the Bluetooth app is that you can see the data on your laptop and or mobile device. The D-jet version of thier distributor can be set either maually or via a blue tooth device. On their D-jet version there are aprox 20 preprogramed curves. The bluetooth capability allows you to observe the advance curve in relationship to other engine metrics. There is a You Tube of his posted. I am not sure if this is extra....again...I.ll ask. I have a call into him just now. I.ll update the first page tonight with the interested members and models...depending on his answers... after the Dodgers win the NLCS. Rob |
StratPlayer |
Oct 18 2017, 06:59 PM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I've been running my123 in my DJet setup for over a year now, One hellva dizzy. I love it I'm sure that the ones that purchase this dizzy won't be disappointed. Love the fact that I no longer have trigger points. Car runs great.
TJB/914 |
Oct 18 2017, 07:33 PM
Mid-Engn. Group: Members Posts: 4,358 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
I am in for one on my D-Jet F.I. engine.
Tom |
jim_hoyland |
Oct 18 2017, 08:08 PM
Get that VIN ? Group: Members Posts: 9,435 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Do they make one compatible with L-Jet FI ?
SKL1 |
Oct 18 2017, 08:47 PM
Senior Member Group: Members Posts: 1,626 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I'd be interested in the one appropriate for a carbed (and with Webcam) engine. Not sure which one that is other than one not for the FI...
Also, curious if they are a larger diameter like the Mallory- I had to modify the sheetmetal on my '71 to get it to fit. |
914_teener |
Oct 18 2017, 10:22 PM
Obviously I.ve asked Ed to speak for this as i am only interested in the D-jet model.
All models that he offers are applicable to the group buy according to Ed and as long as he has a head count by Monday we are good to go. and any questions can be addressed to Ed. I.ll keep the thread bumped if neccesarry for the next three weeks. |
Mueller |
Oct 19 2017, 12:04 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Do they make one compatible with L-Jet FI ? Jim, I might be wrong, however I believe I am correct with the following: Any of these 914 type distributors would work, however no reason to pay the extra money for the D-Jet specific version for your application. 5 different versions, priced lowest to highest: 1st. Very basic, no vacuum advance or retard (16 curves, based on factory curves and cannot be modified)(dip or rotary switch inside or on the side of distributor?) 2nd. Basic with vacuum advance (16 curves, based on factory curves and cannot be modified)(dip or rotary switch inside or on the side of distributor?) 3rd. Same as 2nd version except can trigger D-Jet injectors (thru the ECU) 4th. With vacuum and fully programmable curve for 2 curves, the second curve is "activated" by a toggle switch, curve #1 is 0vdc, curve #2 activated by supplying 12vdc to yellow wire. (I believe you can flip the switch on the fly, no mention of not being able to do that in the manual) With computer hooked up you can "tune" and play with settings and create the 2 curves. 5th. Full tilt boogie version... vac, fully programmable and Turbo or Supercharger friendly with boost retard. If I am correct, not able to change entire curve settings while motor is running, you can tune and create a curve, but not able to go from curve 1 to curve 2 while driving. Without loading the app, I would think you could create many curves to play with. Just remember that if you use the PIN feature to disable the ignition you are screwed if you loose or break your phone (you could borrow and load the app on another phone if you know your PIN I would hope) If I am wrong , please let me know so I can edit or delete. |
Porschef |
Oct 19 2017, 05:35 AM
How you doin' Group: Members Posts: 2,176 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Do they make one compatible with L-Jet FI ? I'm guessing option 2 Jim??? Running Ljet also. (IMG:style_emoticons/default/popcorn[1].gif) |
JoeD |
Oct 19 2017, 05:53 AM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
I'm running the 123Ignition on my Raby 2270 with dual carbs and have been for a year or so. I do not have the bluetooth version.
I think mine was the first build Jake did with the 123, and I know he was really happy with how he was able to fine tune it on the dyno. I've put a couple thousand miles on the car and it has been phenomenal. So far it's been bullet-proof. I'm about to buy another one for my 240Z build. (IMG:style_emoticons/default/biggrin.gif) |
nditiz1 |
Oct 19 2017, 05:56 AM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'd be interested in the one appropriate for a carbed (and with Webcam) engine. Not sure which one that is other than one not for the FI... Also, curious if they are a larger diameter like the Mallory- I had to modify the sheetmetal on my '71 to get it to fit. (IMG:style_emoticons/default/agree.gif) Also interested |
Lo-Fi Version | Time is now: 5th October 2024 - 01:51 PM |
