123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount |
914_teener |
Oct 19 2017, 10:14 AM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Okay cool.
Ed asked me to get a head count. I.ll update the first page. I.m in for sure so we only need 4 more for the 10% and then 5 more in three weeks for then extra 5%. I personally am not comcerned about temperature issues. What this means is that my new dizzy is about 4 weeks out with shipping and my plan is to install it in my 1.7 and keep the stock onenas a spare. Once the 2.0 is done I.ll swap back. I.ll update the first page when I get home from work. |
pvollma |
Oct 19 2017, 12:59 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
Obviously I.ve asked Ed to speak for this as i am only interested in the D-jet model. All models that he offers are applicable to the group buy according to Ed and as long as he has a head count by Monday we are good to go. and any questions can be addressed to Ed. I.ll keep the thread bumped if neccesarry for the next three weeks. I'm in for 1 D-Jet model. |
JeffBowlsby |
Oct 19 2017, 01:23 PM
914 Wiring Harnesses Group: Members Posts: 8,670 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So for the D-Jet model, am I to understand that:
"Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users." This means no more need for the NLA vacuum can and the advance/retard ports it would connect to on the throttle body can be capped off? This is also a replacement solution for the trigger points. Si? Please confirm. What mechanism exactly replaces the trigger points and is it electronic or mechanical (can it wear out)? Can these dizzys be repaired/rebuilt/serviced either DIY or by sending back the the mfr? If so, this sounds like a great solution for the HTF/NLA trigger points and vacuum cans. There would be no reason now to replace D-jet injection because of HTF /non-existent parts. All wear parts are available MPS, trigger points, injectors, harnesses, sensors. |
Mueller |
Oct 19 2017, 01:36 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Looking at the manual, D-Jet specific distributor can be ordered with a vacuum option, add V before the IE in the part number. No idea if needed or wanted for a D-Jet vehicle.
JeffBowlsby |
Oct 19 2017, 02:01 PM
I thought if it had 'hardcoded advance curves" a vacuum can for advance/retard would be redundant and unnecessary. My stock '74 2.0L does not have a vacuum advance, only retard, but the 73 2.0L has an advance.
Does this 123 dizzy for stock D-jet provide the advance/retard functions to replace the vacuum can? |
jd74914 |
Oct 19 2017, 02:05 PM
Its alive Group: Members Posts: 4,798 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I thought if it had 'hardcoded advance curves" a vacuum can for advance/retard would be redundant and unnecessary. My stock '74 2.0L does not have a vacuum advance, only retard, but the 73 2.0L has an advance. Does this 123 dizzy for stock D-jet provide the advance/retard functions to replace the vacuum can? This is just an assumption, but I doubt it has mechanical vacuum advance/retard. I would think there would be an integral MAP sensor which then allowed use of a 3D timing table with engine speed and manifold pressure axes vs. a 2D with only engine speed. |
mgphoto |
Oct 19 2017, 03:15 PM
"If there is a mistake it will find me" Group: Members Posts: 1,363 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I thought if it had 'hardcoded advance curves" a vacuum can for advance/retard would be redundant and unnecessary. My stock '74 2.0L does not have a vacuum advance, only retard, but the 73 2.0L has an advance. Does this 123 dizzy for stock D-jet provide the advance/retard functions to replace the vacuum can? Single vacuum port, if I have it correct the '74 D-Jet retard port only should connect to the dizzy vacuum port and switch set to B. '73 advance port connects to dizzy and switch set to #1. But I could be wrong. |
pete000 |
Oct 19 2017, 03:24 PM
pete000 |
Oct 19 2017, 03:25 PM
Sorry that project and gam-gam have to wait, I'm in the middle of a paint cycle. That looks familiar! (IMG:style_emoticons/default/welder.gif) |
914_teener |
Oct 19 2017, 04:24 PM
I thought if it had 'hardcoded advance curves" a vacuum can for advance/retard would be redundant and unnecessary. My stock '74 2.0L does not have a vacuum advance, only retard, but the 73 2.0L has an advance. Does this 123 dizzy for stock D-jet provide the advance/retard functions to replace the vacuum can? This is a great question and I had paid it particular attention. Brad Anders addressed the stock functional characteristics last year to his web page. The change came in 74 apparently. I am assuming.....and that is a BIG word that the vacuum porting is for the retard function. It also matters which port that pipes to rhe dizzy. Retard ports are in a different location as noted in your drawing Jeff. I need to also make this confirmation as well as the TB I have is a 74. I think I.m going to call Ed about this. I am curious if those that have one on Djet set up on stock system alteady can answer this? |
914_teener |
Oct 19 2017, 04:25 PM
I thought if it had 'hardcoded advance curves" a vacuum can for advance/retard would be redundant and unnecessary. My stock '74 2.0L does not have a vacuum advance, only retard, but the 73 2.0L has an advance. Does this 123 dizzy for stock D-jet provide the advance/retard functions to replace the vacuum can? Single vacuum port, if I have it correct the '74 D-Jet retard port only should connect to the dizzy vacuum port and switch set to B. '73 advance port connects to dizzy and switch set to #1. But I could be wrong. Yes you could be. |
mgphoto |
Oct 19 2017, 04:39 PM
mgphoto |
Oct 19 2017, 04:44 PM
Sorry that project and gam-gam have to wait, I'm in the middle of a paint cycle. That looks familiar! (IMG:style_emoticons/default/welder.gif) Blocked and shot with sealer, tomorrow color. Thanks pete000 Mike |
914_teener |
Oct 19 2017, 05:15 PM
[quote name='mgphoto' date='Oct 19 2017, 03:39 PM' post='2539516']
[/quote] Single vacuum port, if I have it correct the '74 D-Jet retard port only should connect to the dizzy vacuum port and switch set to B. '73 advance port connects to dizzy and switch set to #1. But I could be wrong. [/quote] Yes you could be. [/quote] From the install manual. [/quote] So for the benifit of the other readers what year is your D-jet system and what vacum port did you tap for the 123 Dizzy. Can you post picture of the distributor installed and leave the hood on another thread please? Thanks. |
rhodyguy |
Oct 19 2017, 05:19 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Who ever installed stratplayer's (Jim) should know the details. Does the 123 take the MPS out of the equation?
914_teener |
Oct 19 2017, 05:38 PM
No Kevin,
Trigger points and vacuum advance can. Two NLA items. Good idea. Jims is a stock 74 IIRC? |
914_teener |
Oct 19 2017, 06:04 PM
So for the D-Jet model, am I to understand that: "Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users." This means no more need for the NLA vacuum can and the advance/retard ports it would connect to on the throttle body can be capped off? This is also a replacement solution for the trigger points. Si? Please confirm. What mechanism exactly replaces the trigger points and is it electronic or mechanical (can it wear out)? Can these dizzys be repaired/rebuilt/serviced either DIY or by sending back the the mfr? If so, this sounds like a great solution for the HTF/NLA trigger points and vacuum cans. There would be no reason now to replace D-jet injection because of HTF /non-existent parts. All wear parts are available MPS, trigger points, injectors, harnesses, sensors. Yes Jeff. Here is the answer I got from Ed on the tempeture question and the vacuum port question: On the switch model there are five curves that have vacuum advance and five curves that have vacuum retard. It modulates the vacuum curve when a hose is hooked up to the device. If there's no vacuum it doesn't change the Curve. The 95 degrees has not been a problem with any other VW or Porsche applications. I.m getting it. |
StratPlayer |
Oct 19 2017, 06:05 PM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Mine is a 76 D Jet, 2056. The install was easy just follow the install instructions and it will be easy. I will take some pics of my setup tomorrow and post them. We set the curve on my setup to 4. Car runs like a raped ape.
914_teener |
Oct 19 2017, 06:07 PM
.....oh yea it uses a Hall Effect sensor to trigger the injectors from what I was told.
914_teener |
Oct 19 2017, 06:08 PM
Lo-Fi Version | Time is now: 5th October 2024 - 09:20 AM |
