123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount |
StratPlayer |
Oct 19 2017, 06:08 PM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Here is the dizzy that I'm using. When it was installed a new blue coil was installed with it.
https://www.123ignitionshop.com/gb/porsche/...he4rvieset.html |
914_teener |
Oct 19 2017, 06:31 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Would the GB include the /6 distributor? Anybody use one for a 2.4 / 2.7 / 3.0? Inquiring minds want to know. I also have a friend with a Fiat that would probably buy if the discount could apply. Can.t answer for -6 but the discount for any other model would apply to the discount for three weeks Pete. |
Amphicar770 |
Oct 19 2017, 07:22 PM
Senior Member Group: Members Posts: 1,205 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I will go for one. Just need to make sure that t his is the correct (and only) option for my 1974 2.0, completely stock???
http://123ignitionusa.com/porsche-912-914-...ncludes-spacer/ |
bandjoey |
Oct 19 2017, 08:09 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Can someone explain the Bluetooth part? What does it do and how does it effect the motor or drive Ability?
jd74914 |
Oct 19 2017, 09:11 PM
Its alive Group: Members Posts: 4,798 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Can someone explain the Bluetooth part? What does it do and how does it effect the motor or drive Ability? It's so you can custom tune your advance curve rather than use the preset curves, something that could be useful with a non-stock motor or if you like fine tuning. If you're not the kind of person who is going to fiddle with your exact ignition timing and just want a more reliable, modern components it's really not necessary. |
JeffBowlsby |
Oct 19 2017, 09:39 PM
914 Wiring Harnesses Group: Members Posts: 8,670 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I found the manual for these and it has a list of the advance curve presets and comparable stock dizzys but...didn't see one listed for my stock 74 2.0L 205A dizzy. What to do?
mgphoto |
Oct 19 2017, 11:20 PM
"If there is a mistake it will find me" Group: Members Posts: 1,363 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I found the manual for these and it has a list of the advance curve presets and comparable stock dizzys but...didn't see one listed for my stock 74 2.0L 205A dizzy. What to do? The 205A is Bosch # 0231 174 011 with retard only throttle body for '74. Switch position B according to the install manual page I posted earlier. |
JeffBowlsby |
Oct 19 2017, 11:28 PM
Aha! They used the Bosch PN. Muchas gracias...
euro911 |
Oct 20 2017, 12:36 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
OK, building up my wife's 71 1.7L motor to a 1.9L, keeping the stock D-jet system. I don't remember if the OEM distributor had a vacuum can on it or not ... guess I'd better locate it and take a peek.
I'm tentatively in, pending verification of which model # I'll need (vacuum option or not) (IMG:style_emoticons/default/confused24.gif) |
BeatNavy |
Oct 20 2017, 06:12 AM
Certified Professional Scapegoat Group: Members Posts: 2,934 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Placed my order this morning. Coupon code "914World" wasn't working last night but it is this morning.
Looking forward to dialing the curve to the "raped ape" setting (IMG:style_emoticons/default/smile.gif) Thanks again for getting this going, Rob. |
DRPHIL914 |
Oct 20 2017, 06:20 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
So I have a 75 2.0 but with a TB from a 73, I guess its the same non-blue tooth model, I just select the proper setting depending on whether or not I have the advance, retard or both? I have both on mine....
nditiz1 |
Oct 20 2017, 09:23 AM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Placed my order this morning. Coupon code "914World" wasn't working last night but it is this morning. Looking forward to dialing the curve to the "raped ape" setting (IMG:style_emoticons/default/smile.gif) Thanks again for getting this going, Rob. Rob - I'm right there with ya. Just ordered opt #4 from OG post. Coupon is live for those that can't wait (IMG:style_emoticons/default/drooley.gif) |
pete000 |
Oct 20 2017, 09:36 AM
Ordering today... (IMG:style_emoticons/default/smilie_pokal.gif)
914_teener |
Oct 20 2017, 10:42 AM
Order Placed.
This will be interesting. |
CMONNETT |
Oct 20 2017, 02:44 PM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
Order Placed.
TJB/914 |
Oct 20 2017, 03:15 PM
Mid-Engn. Group: Members Posts: 4,358 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
I am in for one on my D-Jet F.I. engine. Tom I just placed my order for my 1974 914 2.0 D-Jet F.I. (Original) stock with a few internal mods. combo=123/Porsche-4-R-V-IE distributor (injection) + coil +spark Plug wires (black) (IMG:style_emoticons/default/biggrin.gif) Hope I ordered the correct one for my 914. Tom |
914_teener |
Oct 20 2017, 05:16 PM
I am in for one on my D-Jet F.I. engine. Tom I just placed my order for my 1974 914 2.0 D-Jet F.I. (Original) stock with a few internal mods. combo=123/Porsche-4-R-V-IE distributor (injection) + coil +spark Plug wires (black) (IMG:style_emoticons/default/biggrin.gif) Hope I ordered the correct one for my 914. Tom This is exactly what I am building and the same one I ordered. |
TJB/914 |
Oct 20 2017, 07:16 PM
I am in for one on my D-Jet F.I. engine. Tom I just placed my order for my 1974 914 2.0 D-Jet F.I. (Original) stock with a few internal mods. combo=123/Porsche-4-R-V-IE distributor (injection) + coil +spark Plug wires (black) (IMG:style_emoticons/default/biggrin.gif) Hope I ordered the correct one for my 914. Tom This is exactly what I am building and the same one I order 914-teener, Thanks for your confirmation. (IMG:style_emoticons/default/pray.gif) I was hoping someone would comment on my concerns. It was based on our expert 914 opinions (Bowlsby-Beat Navy-Etc-Etc) to select this combo. Hey Bowlsby I also selected black spark plug wires (IMG:style_emoticons/default/laugh.gif) Tom |
914_teener |
Oct 20 2017, 08:23 PM
I am in for one on my D-Jet F.I. engine. Tom I just placed my order for my 1974 914 2.0 D-Jet F.I. (Original) stock with a few internal mods. combo=123/Porsche-4-R-V-IE distributor (injection) + coil +spark Plug wires (black) (IMG:style_emoticons/default/biggrin.gif) Hope I ordered the correct one for my 914. Tom This is exactly what I am building and the same one I order 914-teener, Thanks for your confirmation. (IMG:style_emoticons/default/pray.gif) I was hoping someone would comment on my concerns. It was based on our expert 914 opinions (Bowlsby-Beat Navy-Etc-Etc) to select this combo. Hey Bowlsby I also selected black spark plug wires (IMG:style_emoticons/default/laugh.gif) Tom Well...I don't know if I'm an "expert" but I have read a lot on the curves on the stock distrubutors. Last year I had gathered what I thought was a workable distributor that I could use for a 2.0 build that will use a 74 stock D-jet setup. Turns out the distributor parts are all worn out and two ....NLA. All the other components besides the MPS were workable. Jeff Bowlsby did rebuild the MPS and it has been tested. So after doing a LOT of reading I had decided to contact this company about their product and talked to a few members that already have it. I want everybody to know...and I don't know how it was done...but I didn't edit my first post in this thread making the recommendations. I thoroughly read through the brochure and did contact Ed personally with several phone calls. According to my notes and conversations this is the one for a 74 D-jet system. The vacuum port is optional. Last year Brad Anders wanted to know where the curves were published and then did a pretty good addition to his website on the history and operation of the distributors. If you haven't read it, makes for a good understanding of the advance theory and why Porsche changed it through the years. Dave Darling also published a chart on the distributors on the Bird Board. As Murphy's law would have it...I had the 205B with a question mark on the reference table. So, unknown. What I can tell you is, that if you have a 74 D-jet setup, I have purchased the same one you have. I started the thread to save a few bucks and help others whom might be enthusiasts like me struggling to find parts for these cars and still try to emulate the stock look or performance. I think you'll be just fine. Rob |
McMark |
Oct 21 2017, 10:30 AM
I want everybody to know...and I don't know how it was done...but I didn't edit my first post in this thread making the recommendations. I thoroughly read through the brochure and did contact Ed personally with several phone calls. According to my notes and conversations this is the one for a 74 D-jet system. The vacuum port is optional. Whoops, that was me. I thought it would be helpful to put all the info up front. Your post above has made me rethink that practice. I should have at least PM'd you. (IMG:style_emoticons/default/pinch.gif) Sorry! (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 5th October 2024 - 07:31 AM |
