FS: Fuel tank, seats, brake lines, Maintenance items, service kit, fuel lines, bulbs, fuses, etc |
bixs |
Dec 10 2017, 04:37 PM
Newbie Group: Members Posts: 9 Joined: 11-May 11 From: Irvine, CA Member No.: 13,061 Region Association: None |
Everything came off a 1970 914 that was likely pieced together with parts. I no longer have the car so I'm just trying to clean out my parts surplus.
*Update: 3/10/2018 ADDED a bunch of smaller items* 1. Fuel tank, SOLD 2. Seat bracket SOLD 3. Seats SOLD 4. fuel cap SOLD 5. fuel filler neck SOLD 6. Fuel tank straps SOLD 7. Cunifer brake lines, (Product page says: Porsche 914 all except 75-76) SOLD ---------------------------------------------------------------------- Service kit from AutoAtlanta (was $100) Asking $60 1. Oil filter 2. Fuel filter 3. Continental alternator belt 4. Bosch spark plugs 5. Bosch contacts 6. Bosch rotor 7. Bosch distributor cap 8. o ring for distributor 9. Ignition condensor 10. 2 cork valve cover gaskets ---------------------------------------------------------------------- Victor Reinz Fuel Injector base seals and tip seals, $1 for 8 total seals SOLD ---------------------------------------------------------------------- Genuine Porsche Tapered Fuel Hose for Connection at Fuel filter, 70-74 1.7/1.8/2.0 SOLD ---------------------------------------------------------------------- VDO Fuel Tank sending unit gasket 1.7/1.8/2.0 (1970-76), SOLD ---------------------------------------------------------------------- Victor Reinz Intake Manifold gaskets 1.7/1.8 1970-1975, $7 for 2 gaskets ---------------------------------------------------------------------- Stainless Steel Tunnel Fuel Line Set (one 8mm and one 9.5mm), 914 (1970-74), SOLD ---------------------------------------------------------------------- Stainless Steel Engine Compartment Fuel Line Set (NOTE: 1970-74 cars also use tapered fuel hose 914-356-525-00-M100), 914 (1970-76), SOLD ---------------------------------------------------------------------- Victor Reinz cork valve cover gaskets, $5 for 2 ---------------------------------------------------------------------- Fuse Kit - 911, 912, 930, 924, 928 1978-84, 944 1982-85.5 914 Fuse Assortment SOLD Bulb Kit - Assortment $3 |
bdstone914 |
Dec 11 2017, 05:37 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What does that tank look like inside? Outside looks pretty rusty. I would try to remove those aluminum nuts on the bottom.
bixs |
Feb 24 2018, 05:22 PM
(IMG:style_emoticons/default/icon_bump.gif) Bump! I included two pictures of the inside of the gas tank and drastically reduced all prices. Prices are still negotiable.
bixs |
Mar 10 2018, 12:29 PM
bump!
Psw1811 |
Mar 10 2018, 03:54 PM
Newbie Group: Members Posts: 21 Joined: 12-November 17 From: England Member No.: 21,595 Region Association: England |
I would like the brake lines if you would consider posting to the UK - PM sent
bixs |
Mar 10 2018, 06:25 PM
Added a lot of smaller sparts + fuel lines
---------------------------------------------------------------------- Service kit from AutoAtlanta (was $100) Asking $60 1. Oil filter 2. Fuel filter 3. Continental alternator belt 4. Bosch spark plugs 5. Bosch contacts 6. Bosch rotor 7. Bosch distributor cap 8. o ring for distributor 9. Ignition condensor 10. 2 cork valve cover gaskets ---------------------------------------------------------------------- Victor Reinz Fuel Injector base seals and tip seals, $1 for 8 total seals ---------------------------------------------------------------------- Genuine Porsche Tapered Fuel Hose for Connection at Fuel filter, 70-74 1.7/1.8/2.0 $10 ---------------------------------------------------------------------- VDO Fuel Tank sending unit gasket 1.7/1.8/2.0 (1970-76), $2 ---------------------------------------------------------------------- Victor Reinz Intake Manifold gaskets 1.7/1.8 1970-1975, $7 for 2 gaskets ---------------------------------------------------------------------- Stainless Steel Tunnel Fuel Line Set (one 8mm and one 9.5mm), 914 (1970-74), $45 ---------------------------------------------------------------------- Stainless Steel Engine Compartment Fuel Line Set (NOTE: 1970-74 cars also use tapered fuel hose 914-356-525-00-M100), 914 (1970-76), $25 ---------------------------------------------------------------------- Victor Reinz cork valve cover gaskets, $5 for 2 ---------------------------------------------------------------------- Fuse Kit - 911, 912, 930, 924, 928 1978-84, 944 1982-85.5 914 Fuse Assortment $3 Bulb Kit - Assortment $3 |
danoswork |
Mar 11 2018, 10:50 AM
Newbie Group: Members Posts: 1 Joined: 21-September 14 From: oregon Member No.: 17,930 Region Association: Pacific Northwest |
I will take the fuel filler neck. email danoswork@aol.com re payment and shipping costs
My zip is 97224 Thanks, Dan |
koozy |
Mar 11 2018, 11:04 AM
Senior Member Group: Members Posts: 646 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
Interested in the fuses
kahluver |
Mar 11 2018, 09:05 PM
Newbie Group: Members Posts: 49 Joined: 3-October 14 From: Huntington Beach, ca Member No.: 17,973 Region Association: Southern California |
PM Sent - I'll buy all of the fuel tank parts, fuel lines and seat brackets if available.
type47fan |
Mar 12 2018, 12:11 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
PM sent
dakotaewing |
Mar 12 2018, 10:00 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Based on the ad, looks like you have 2 stainless fuel line sets.
I'd like one of the 2 sets if they are not both spoken for... Please send me a PM - Thanks, Thom |
cooper951 |
Mar 13 2018, 10:38 AM
Member Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
Do you have the back pad?
bixs |
Mar 13 2018, 12:03 PM
bixs |
Mar 13 2018, 12:04 PM
I've added some PENDING to the original post, if I don't have arrangements or PM chat with you, it's been spoken for (IMG:style_emoticons/default/smile.gif)
Jonathan Livesay |
Mar 13 2018, 12:30 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
I'll take the seats. Sending PM
Mike D. |
Mar 14 2018, 12:52 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
second on the seat set. pm sent
thanks |
Lo-Fi Version | Time is now: 26th April 2024 - 04:37 PM |
