| DRPHIL914 |
Feb 18 2023, 06:20 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,952 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Yes we have to. I have the leather done. We were having issues locating the correct stainless polished, but I think we may have that finally solved. Here's the straps in the correct color. It's not a red. Compare to an original. I think we did good on this. I can do up a run of the gaskets in the next week or so, just ahve a fe wother items I'm juggling. Look closely we emulated the embossed pattern and the hardware is really close. It's a different manufacturer but almost identical. The width is the same, yes it looks wider but it's camera placement. Otherwise it wouldn't fit in the hoops. -Mark @Mikey914 Hey Mark, do you have any of these leather straps?? |
| Mikey914 |
Feb 18 2023, 06:56 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yes we have to. I have the leather done. We were having issues locating the correct stainless polished, but I think we may have that finally solved. Here's the straps in the correct color. It's not a red. Compare to an original. I think we did good on this. I can do up a run of the gaskets in the next week or so, just ahve a fe wother items I'm juggling. Look closely we emulated the embossed pattern and the hardware is really close. It's a different manufacturer but almost identical. The width is the same, yes it looks wider but it's camera placement. Otherwise it wouldn't fit in the hoops. -Mark @Mikey914 Hey Mark, do you have any of these leather straps?? Yes, I can get you some this next week. Mark |
| DRPHIL914 |
Feb 18 2023, 07:45 PM
Yes we have to. I have the leather done. We were having issues locating the correct stainless polished, but I think we may have that finally solved. Here's the straps in the correct color. It's not a red. Compare to an original. I think we did good on this. I can do up a run of the gaskets in the next week or so, just ahve a fe wother items I'm juggling. Look closely we emulated the embossed pattern and the hardware is really close. It's a different manufacturer but almost identical. The width is the same, yes it looks wider but it's camera placement. Otherwise it wouldn't fit in the hoops. -Mark @Mikey914 Hey Mark, do you have any of these leather straps?? Yes, I can get you some this next week. Mark (IMG:style_emoticons/default/chowtime.gif) |
Lo-Fi Version | Time is now: 20th July 2026 - 12:00 PM |
