O.t. Hydro dipping, Anyone done this ? |
sb914 |
Aug 8 2018, 09:02 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Just wondering if anyone has diy
or had it done and does it last? |
914forme |
Aug 8 2018, 12:05 PM
I take it we are talking about paint transfer methods. Have not done it, but seen it done every cool. Just looking to clarify the conversation.
(IMG:style_emoticons/default/confused24.gif) each their own hope they have matching boots |
sb914 |
Aug 8 2018, 12:48 PM
I take it we are talking about paint transfer methods. Have not done it, but seen it done every cool. Just looking to clarify the (IMG:style_emoticons/default/confused24.gif) each their own hope they have matching boots Yes! but this is what I was referring to. |
VaccaRabite |
Aug 9 2018, 09:29 AM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I've had it done.
Not as durable as powder coating. Think of it as paint. If something would scratch paint, then its going to scratch whatever got dipped. A friend of mine has made a business dipping wheels and other stuff. Some of the interior trim on my WRX has been dipped and looks great. I also had a deer skull dipped and it looks awesome. As with anything else, its ALL about prep. the surface has to be clean, and has to have some base color applied. after the item is dipped my guy will go back in with an airbrush and get all the hollow areas the film can't reach into, so you don't just have base color showing through. Finally, a couple coats f clear are applied for durability. Zach |
VaccaRabite |
Aug 9 2018, 09:32 AM
Robnxious |
Aug 9 2018, 11:19 AM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
jsaum |
Aug 9 2018, 01:56 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
Yes it’s basically ink on a plastic sheet that dissolves in water as the printed ink is reactivated with a solvent. The pattern floats on the water and you dip the parts so the ink conforms to the shape of the part. You tube hydro graphic dipping and you should see how it’s done. You’ll need to put a clear coat over it. It’s as durable as a good clear coat depending on what environment it’s in. The company in Southern Cali I would contact is Shmaze.
carl k |
Aug 9 2018, 07:30 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
Lo-Fi Version | Time is now: 26th April 2024 - 03:13 PM |
