FS 911 suspension parts package, front. Shipped. |
rhodyguy |
Aug 19 2018, 11:27 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,061 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
L&R 911, I think T, strut housings with 3" caliper bolt spacing.
2 Aluminum hubs. 2 NEW Zimmerman vent rotors. Rotor retaining hardware and used bearings. I do not have the backing plates or the strut covers. $600+shipping ONBO. Attached thumbnail(s) |
bdstone914 |
Aug 19 2018, 01:36 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What type struts ?
Pinch bolt ball joint or taper pin ? What is the part number on one of the strut tubes ? Interested pending verification of the struts. Bruce |
Aug 19 2018, 02:49 PM
Kevin - if the bottom of the strut where the ball joint shaft has a slot, it’s a pinch bolt strut (early). No slot = tapered pin (late). Either one works fine but it needs the corresponding ball joint.
Strut dust covers are the same as 4 cylinder. Good price for this package. Oh, if you do end up shipping, go to the big box store, buy a 22 - 27 quart yellow and black plastic tub, pack and zip tie the top on. The tub cost a couple dollars but it holds up much better than cardboard boxes. |
rhodyguy |
Aug 19 2018, 05:09 PM
I will post a picture of the the balljoint area tomorrow. Thanks for the heads up guys! BIG shed cleanup over past 2 days. I'm clean and tired. Funny how an ancient tiller that doesn't run, is left out by the street with a 'free' sign on it disappears. Crap cheap yard carts too. Already on the plastic tote bus. (IMG:style_emoticons/default/wink.gif)
rhodyguy |
Aug 21 2018, 07:16 AM
it seems 12 zip ties gets the job done. btw, round hole with threads on one side for the balljoint.
bdstone914 |
Aug 21 2018, 07:52 AM
Sounds like pinch bolt type struts. I will pass. You should make that clear in the initial listing so a non knowing buyer ends up with having to back date to inferior ball joints.
Bruce |
Aug 21 2018, 08:05 AM
Sounds like pinch bolt type struts. I will pass. You should make that clear in the initial listing so a non knowing buyer ends up with having to back date to inferior ball joints. Bruce They really aren’t that bad. Used on thousands of 911’s, 912’s, 914 fours and sixes and probably many other cars. You just have the keep the nut tight and it all works fine. You can play the upgrade game to infinity but there’s always something that you don’t expect that will go wrong. |
rhodyguy |
Aug 21 2018, 08:31 AM
Gee, thanks Bruce. (IMG:style_emoticons/default/huh.gif) For nothing. Perhaps the company you work for should'nt sell shit parts.
76-914 |
Aug 21 2018, 08:38 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,491 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Sounds like pinch bolt type struts. I will pass. You should make that clear in the initial listing so a non knowing buyer ends up with having to back date to inferior ball joints. Bruce They really aren’t that bad. Used on thousands of 911’s, 912’s, 914 fours and sixes and probably many other cars. You just have the keep the nut tight and it all works fine. You can play the upgrade game to infinity but there’s always something that you don’t expect that will go wrong. A 914 Truism. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/icon_bump.gif) for a great deal. |
TravisNeff |
Aug 21 2018, 10:57 AM
This is a good deal
rhodyguy |
Sep 9 2018, 12:04 PM
Thanks guys. Bump #1. Anticipate shipping to run $35-45 via FedEx. I'll cover any amount over the $45 conus.
euro911 |
Sep 10 2018, 01:59 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Kevin, What's up with the driver's side strut? ... looks like the control arm has been re-welded (IMG:style_emoticons/default/confused24.gif)
rhodyguy |
Sep 12 2018, 10:51 AM
Do you mean the gob of stuff on the strut on the left?
euro911 |
Sep 12 2018, 11:57 AM
gob - lol.
Yes |
rhodyguy |
Sep 12 2018, 12:57 PM
Saran Wrap is tied in the hole. I had to unwrap the assems for pictures. 0 welding. 80% of the prep work is done. No need to burn thru 3 or 4 cans of spray cleaner (and dealing with the rest of the mess) or a bath in a parts washer just to get started. The rust you see is just light on the surface.
Thanks for asking Mark. I was oblivious to the crap on the arm. |
RSR |
Sep 13 2018, 10:32 PM
Newbie Group: Members Posts: 14 Joined: 20-April 17 From: Occidental Member No.: 21,036 Region Association: Northern California |
Pm sent
RSR |
Sep 14 2018, 06:48 PM
I see you sent me a pm but I can’t read it.
rhodyguy |
Sep 15 2018, 01:56 PM
Did you get the one I sent about 1/2 hour ago? If you're not logged in you can't read pms. BTW, the threads are fine. Ran a bolt thru both holes. The BJ post holes look good too.
Lo-Fi Version | Time is now: 26th April 2024 - 06:08 PM |
