Ivory 1970 914/6 Build, Shake down before delivery |
UROpartsman |
May 15 2020, 02:23 PM
Member Group: Members Posts: 292 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
@uropartsman I can't tell you how pleased Glenn and I have been with the URO parts we have been using for this build. It has all fit very well and is close to stock in appearance. I know you probably have multiple suppliers with varied levels of quality and fit, but thus far we have not been disappointed. Thank you for your feedback Targa70, we're thrilled to be a part of your amazing restoration! |
gms |
May 16 2020, 01:22 PM
Advanced Member Group: Members Posts: 2,706 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
gms |
May 16 2020, 01:23 PM
gms |
May 16 2020, 01:40 PM
Attached thumbnail(s) |
gms |
May 16 2020, 01:41 PM
gms |
May 16 2020, 01:42 PM
gms |
May 16 2020, 02:03 PM
I received an email with questions:
Wanted to know the color light ivory what brand of paint was that ? there’s so many brands. Although I did not paint the car I know they used PPG (some prefer Glasurit paint) OEM code 131,L80E - HELLELFENBIEN also the under body and fender wells I see the texture on it what type did you use on that under coating then painted over it with the ivory ? The texture is achieved using Wurth Body Schutz |
Tman914 |
May 17 2020, 02:38 PM
Member Group: Members Posts: 136 Joined: 9-December 04 From: "Livermore, Ca" Member No.: 3,247 Region Association: Central California |
Hello nice build btw I just have a few questions on the paint light ivory what style paint / brand there’s so many brands out there now
Also the under coating texture paint Thanks for your time Tman914 |
Tman914 |
May 18 2020, 11:02 AM
Ok thanks for the response
Tman914 |
RoadGlue |
May 18 2020, 12:36 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Bartlett 914 |
May 18 2020, 02:28 PM
You! All you have to do is turn on the lights and start it up. |
gms |
May 19 2020, 06:37 AM
gms |
May 19 2020, 06:47 AM
Last week I encountered a very strange malfunction while assembling the final switching and wiring. The “start” mode of the ignition switch would turn on the headlights and when in “run” mode the headlight switch engaged the starter…yes you read that correctly! I said the STARTER!
My first assumption was a faulty ignition switch because I did not think the wiring harness would be at fault, I was wrong. After installing the new ignition switch the symptoms remained. Sunday I found that the ignition switch connection that was supposed to go to the relay board was in fact connected to the headlight switch somehow. Yesterday I enlisted the help of Mark Kinnaman @Bartlett 914 After a couple hours we were able to find the wire that connected to the relay board, it was erroneously connected to the turn signal switch. While running thru the fuse panel a couple other wires were found to be incorrectly connected. I will put together a report and hopefully Kroon can prevent this from happening on future harness builds. Thanks Mark! |
gms |
May 19 2020, 06:49 AM
Luke M |
May 19 2020, 07:38 AM
Senior Member Group: Members Posts: 1,394 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hi Glenn,
I'm glad you figured out the issue. When was your harness made? I hope that my new Kroon harness doesn't have this issue. |
gms |
May 19 2020, 07:42 AM
Hi Glenn, I'm glad you figured out the issue. When was your harness made? I hope that my new Kroon harness doesn't have this issue. @Luke M I can walk you thru a check of your harness |
Luke M |
May 19 2020, 08:10 AM
Hi Glenn, I'm glad you figured out the issue. When was your harness made? I hope that my new Kroon harness doesn't have this issue. @Luke M I can walk you thru a check of your harness Sounds good. I'll send you a pm. |
gms |
May 19 2020, 08:37 AM
Bartlett 914 |
May 19 2020, 09:17 AM
I would add that when you turned on the lights. The starter would engage. Real fun!
gms |
May 21 2020, 01:16 PM
@Bartlett 914 and I got after the wiring fix last night, headlights work and starter only work when ignition switch is in "START" position. Tracking down the horn issue and then wiring in fog light switch because they setup to run only when high beams are on.
Lo-Fi Version | Time is now: 25th November 2024 - 07:13 AM |
