Suspension and Brake Refresh, New Wheels and Suspension Adjusted |
Tbrown4x4 |
Nov 15 2019, 01:14 PM
Senior Member Group: Members Posts: 706 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
The shoulder on the hub will bottom out on the inner bearing race. The hub doesn't go ALL the way through. The hub and the stub axle traps the inner races when you torque the axle nut. (To the proper torque, of course.)
TargaToy |
Nov 15 2019, 02:32 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 706 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
914werke |
Nov 15 2019, 03:35 PM
"I got blisters on me fingers" Group: Members Posts: 11,005 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If you look at the process for installing either the various Delrin / poly or the OE replacement rubber versions it is typically necessary to "clearance" the plastic ones, & use a special tool to draw the tight rubber over the shafts for the fitment.
The .01 removed to clean any corrosion isnt significant enough to adversely effect fitment. IF you are going Polybronze they (Elephant) provide new shafts with their kit. |
TargaToy |
Nov 15 2019, 03:59 PM
If you look at the process for installing either the various Delrin / poly or the OE replacement rubber version it is typically necessary to "clearance" the plastic ones, & use a special tool to draw the tight rubber over the shafts for the fitment. The .01 removed to clean any corrosion isnt significant enough to adversely effect fitment. IF you are going Polybronze they (Elephant) provide new shafts with their kit. Gotcha. That makes sense. |
Mikey914 |
Nov 15 2019, 06:19 PM
The rubber man Group: Members Posts: 12,739 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Actually when Elephant made their rods they used a standard size tube that was not metric line the OEM. The bushings they made are to go with their rod, so they don’t work well with the stock rods (and the ones I made).
914werke |
Nov 16 2019, 12:21 AM
Actually when Elephant made their rods they used a standard size tube that was not metric line the OEM. The bushings they made are to go with their rod, so they don’t work well with the stock rods (and the ones I made). (IMG:style_emoticons/default/confused24.gif) why would you bother with used OE ones if you are getting new ones as part of their (elephant) kits? |
tvdinnerbythepool |
Nov 16 2019, 07:05 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Mikey914 |
Nov 16 2019, 11:22 PM
Actually when Elephant made their rods they used a standard size tube that was not metric line the OEM. The bushings they made are to go with their rod, so they don’t work well with the stock rods (and the ones I made). (IMG:style_emoticons/default/confused24.gif) why would you bother with used OE ones if you are getting new ones as part of their (elephant) kits?Yes but you can't use the rubber without their shafts. It will not fit correctly as they made a non standard size. |
tvdinnerbythepool |
Nov 23 2019, 12:54 PM
With the back pretty much wrapped up it's on to the front.
Ripped it all out and have a pretty good plan of action. New A Arm Bushings/Install Tool (914 Rubber + Ian's Video should help) Bilsteins on the way to match the rears New Rotors, Pads, Bearings, Ball-joints New Stainless soft lines Rebuilding Calipers (Rears went well so here is round 2 for me) Tie Rod Ends (Stock not turbo upgrade for me) Bought the install tool for the ball joints, got the old ones out with the air chisel in about 10 seconds surprisingly! Bushings were totally shot, out of round and a mess. Anyways, guidance as always appreciated. Have most of the parts on hand if not already shipping to me so I'm hoping to keep the momentum between trips. |
tvdinnerbythepool |
tvdinnerbythepool |
Nov 23 2019, 12:55 PM
Nov 23 2019, 01:31 PM
914-6 GT in waiting Group: Members Posts: 19,635 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Heat up the fittings that hold the bushings until you see some smoke and then twist them off by inserting a large screwdriver and turning. Wear leather gloves. Propane works fine for this. MAP is just faster.
Nov 23 2019, 01:36 PM
Starting to see some progress and feeling like I didn't ruin everything and she may drive once more. Lol! I'm curious about the rear shafts. None of the ones I've taken apart seem to have washers on the ends of the shafts. Is that correct? Attached image(s) |
tvdinnerbythepool |
Nov 23 2019, 02:07 PM
Starting to see some progress and feeling like I didn't ruin everything and she may drive once more. Lol! I'm curious about the rear shafts. None of the ones I've taken apart seem to have washers on the ends of the shafts. Is that correct? @mepstein I put the washers on there...it just feels wierd to not! Should I take them off? Was there a reason to NOT use a washer? |
Nov 23 2019, 02:10 PM
Starting to see some progress and feeling like I didn't ruin everything and she may drive once more. Lol! I'm curious about the rear shafts. None of the ones I've taken apart seem to have washers on the ends of the shafts. Is that correct? @mepstein I put the washers on there...it just feels wierd to not! Should I take them off? Was there a reason to NOT use a washer? No, I'm not saying you are wrong. I put a washer there as well. I'm just wondering why Porsche didn't (IMG:style_emoticons/default/confused24.gif) |
DRPHIL914 |
Nov 23 2019, 02:34 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Looks nice , did you put the spring retainer clip at the top space?
tvdinnerbythepool |
Nov 23 2019, 03:13 PM
@mepstein I was thinking the same thing! (IMG:style_emoticons/default/confused24.gif)
tvdinnerbythepool |
Nov 23 2019, 03:14 PM
@DRPHIL914 Hi! Not sure what that means...can you clarify?
DRPHIL914 |
Nov 23 2019, 04:47 PM
There are 6 I think slots for the retainer that holds the spring retainer clip. It looks like you are set at the very top one ( grooves on the yellow billestien shock) it ma be a bit too springy and high at that setting, at least that was my experience. Mine is at the third slot down, seems about right for height and feel, but every car is different |
tvdinnerbythepool |
Nov 23 2019, 05:06 PM
@DRPHIL914 gotcha! Thanks for clarifying. Yes It's at the top spot.
I'm having to kind of do a reset on the car. I bought it about 18 months ago and i'm trying to under the fuckerage and get it back to stock-ish. It has been "Modified" by the last guy who did a piss poor job on everything. Missing alignment shims to the wrong ECU, everything has been done wrong on this car. I'm totally open to pulling the springs out and changing notches. The more pressing issue with the lower ride height is the Rivieras (I believe, correct me if i'm wrong) have tires too large for my car and their offset 195/60/R15. With the saggy old springs there was about a piece of paper clearance between the tire and the fender (That includes the fact that the PO rolled the Fender Lip to try and make clearance). Any guidance on tire size for these? I'd like to buy Fuchs at some point and have been contacted, but this thing is like a money pit at the moment, lol! (I'm sure it always will be) |
Lo-Fi Version | Time is now: 17th December 2024 - 01:04 AM |
